Like Tree16Likes
Old 06-06-2015, 12:07 AM   #781
Photocycler's Avatar
Trader Rating: 34 (100%+)
Thoughts on batteries, I am running a Tekin Rx8 with 1900kv. I am thinking I do not need a high C rating and the 4500-5000mah is the sweet spot for weight and capacity.
Considering one of the two batteries
5000 20c
http://www.hobbyking.com/hobbyking/s...arehouse_.html
4500 30c
[evan b]
Timezone I & II | RoseCityScaleRacing | Premier RC Raceway
Photocycler is online now   Reply With Quote
Old 06-06-2015, 05:56 AM   #782
idbdoug's Avatar
Trader Rating: 33 (100%+)
5000 20c
4500 30c
I run a 1800 KV and I do have a high C battery but its overkill. As matter of fact, my sponsor switched to Lower C 4 cell lipos. If you are looking for a larger capacity battery check out Fantom's website. Between these 2 you posted, just decide if you need ROAR approved battery or not
idbdoug
www.serpentamerica.com
www.r1wurks.com
www.falconsekido.com
idbdoug is offline   Reply With Quote
Old 06-07-2015, 10:22 AM   #783
Having an issue today removing one of the rear wheel nuts, it seems to keep spinning and won't come off.
Any idea what's going on and how to get off?
Old 06-07-2015, 12:45 PM   #784
anyone running a t8i 1950?
worm304 is offline   Reply With Quote
Old 06-07-2015, 02:46 PM   #785
werner sline's Avatar
you mean the 17mm nut ?
is the wheel ok ? if not, put a screwdriver through the universal joint to keep it from turning. you should be able the screw the nut out.
If the thread in the aluminium is dead, you might have to use some force !
maybe with strong pliers you can force it to follow the steel thead of the shaft.
if this doesn't work, you might have to cut it carefully out !
werner sline is offline   Reply With Quote
Old 06-07-2015, 06:07 PM   #786
side question. what length senor wire is required for the standard set up? 100MM?
Old 06-07-2015, 07:23 PM   #787
Gpeters66's Avatar
I set up my buggy with Adam Drakes standard set up. Changed everything to match the sheet exactly. The gearing for that setup is 44/16. I ran this at the track today and when I temped my Tekin 1900 it was 209 degrees, ESC was 135. Anyone else running this gearing?
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 06-07-2015, 07:23 PM   #788
Suspended
Trader Rating: 440 (99%+)
5000 20c
4500 30c
I have bought around 50-60 of the hardcase 5000mah turnigy packs. All have worked great. I've ran them in buggies and truggies with 1800-2600kv motors and I never felt like I needed a higher C pack.
MattP is offline   Reply With Quote
Old 06-08-2015, 05:07 AM   #789
That's what I run. For me that's the perfect amount of power and she does get hot. I run the SMC 1900, that's the temps i pull after a longer practice or a hard run main on a smallish sized indoor or outdoor. My temps are better tho on a medium sized track.
Dont Hack Me is offline   Reply With Quote
Old 06-08-2015, 07:32 AM   #790
Trader Rating: 17 (100%+)
[QUOTE]
I did the exact same you did with my MBX7R-ECO, under the assumption it would make my current setup better and run cooler. NOT SO GOOD. switched to 44T/16 and my motor came off blazing hot, and per Randy Pike 220F+ was too hot. My advice is to take those setups they post with a grain of salt because they may or may not work. For Adam, maybe the 44T/16 is great, but for me the 44T/15 keeps my temps under control. I can run for 10 minutes with the 44T/15 combo and maybe get as hot as 186F. If I run the 44T/16, 5 minutes will put me upwards of 200F. If I start going down on the pinion too much it will heat up also, so the key is finding the sweet spot and staying there. It seems to me there is no such thing as BETTER with the gearing, its the sweet spot or worse..
diamonddawg21 is offline   Reply With Quote
Old 06-08-2015, 09:41 AM   #791
Gpeters66's Avatar
Thanks guys!!
Old 06-08-2015, 10:11 AM   #792
Trader Rating: 19 (100%+)
I ran one in mine geared 17/46. It runs warmer than I'd like (230 after a 10 min main), but the power and speed is perfect. So much tamer than running a standard sized motor, I feel that I can pick up the throttle sooner and harder than a lot of other guys. Ideally I'd like to get the temp down 15-20, but I'm not noticing any fade in power at all. If the motor makes it through the season at those temps, I'll be happy. The only place I feel any disadvantage from a power standpoint is the start of the race from a standstill. That same motor ran similar temps in my DEX8, which is what its going back into as I like the feel of that car better than the Mugen.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 06-08-2015, 10:24 AM   #793
mxnickj's Avatar
Trader Rating: 51 (100%+)
hey guys, I'm almost done building my kit. I built it by the book setup which is typically what I do to get a base feeling of what the "normal" car feels like then adjust from there. My question though is what are some "must haves" as far as upgrades (springs/pistons/etc)? I know Drake has a few setups put there, is that what is becoming a pretty good go-to? I race on larger, medium grip, outdoor tracks. I also saw his one setup had 10k/10k/6k I believe in the diffs. How is that working for those that have tried it?
mxnickj is offline   Reply With Quote
Old 06-08-2015, 11:36 AM   #794
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
5000 20c
4500 30c
Stay away from low C rated packs. They can and often will damage the esc not being able to sustain the load.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 06-08-2015, 12:29 PM   #795
right on! I picked up that motor with intentions of running super light, then I had a change of heart and am about to pull the trigger on the mugen. I sold 2 others cars to finance my next one and have been struggling with the decision. if the motor isn't going to cut it, I may just go eb48sl. i already have the eb48.2 so i want something different. i love 1/8 buggies!
