Mugen MBX7R Eco thread!
#586
Here attached another photo showing where it's hitting the diff case...
#587
Finished her up yesterday. It is not as easy to do a build with a 3.5 year old boy at home but I got her done regardless. Waiting on delivery of a few sets of AKA wheels/tires and a new futaba rx and she will be ready for a test run. Still need to order a black servo arm (blue was all I had in my pit box) and a transponder. Would have liked a black rx8 case and still might get one but that is me being a little ocd. Was trying to avoid the 1/8th scale bug, but I got bit.
#588
#590
After going over the car after a track session, I found that the steering pivot bushings C0801H were hitting the gear diff casing. See attached photo. My EPA was set at around 80-85%. Now, I've had to set the EPA to around 60% in order to avoid the bushing hitting the case. Does this sound normal?? Surely such a low epa % is too low?
Either I built it incorrectly (which I can't see that I have), or it's a design floor?
#593
#594
Relief to know its normal. So do you guys just set the epa until before it touches the case? Or let it dig in? My endpoints are around 60% just before hitting the case...which seems low.
#597
I have been running the 16T with my SMC 1900KV motor. After running hard for 10 min I am getting to about 150 + or - a few degrees. But the ambient temps have not been very hot yet. Pretty dang fast but I want to try the 17t pinion to see what it does. It is a bit slower on the big straits compared with the nitro buggies, It seems pretty comparable to the other e-buggies. It does really well against the nitro buggies in the more technical portions of the track.
One thing I can state for sure is this is a very durable buggy. It has been a few years since I last drove, and I am very hard on it. The only thing I have broken other than a severely abused body and wing has been a front shock end when It came in contact with a object that did not move.
#598
Hideeho
p.s. You could also use a small 4s like this:
http://www.amain.com/rc-cars/protek-...101-15/p423774
& the phantom would clear that with no issue. The problem then becomes the motor sits to high. The motor in the ebug sits higher than anything in the nitro buggy (other than the cooling head). It will rub the body, but won't be any where near as big of an issue as a standard size 4s is.
Oh yeah, no I'm not guessing at any of this. There are numerous guys at my local track that run mugen (it's the car of the week until the new AE comes out) & the phantom & have tried the body on my car (I REALLY like it, but do not want to deal with the fitment issues).
#599
I am not expert at setup but have been learning quickly.
