Like Tree16Likes
Old 03-19-2015, 07:59 PM   #451
Waflet's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Crazy Carl View Post
I believe in order to run a clutch set up, you will need a special motor mount. Trying to find out any info on this. If anyone knows anything please post it .
Hideeho
http://www.teknorc.com/shop/tkr40000...atent-pending/
You will also need their motor mount
http://www.teknorc.com/shop/tkr4142x...ors-lightened/
& your choice of shoes & bell
"Just leave me alone, I know what I'm doing."-Kimi Raikkonen
Mugen MBX7R Eco/Tekin RX8g2/Savox 2274/SMC 1900kv/Aitronics mt-4/promatch
Mugen MSC7(1/10 pro4 sct)/Tekin RX8g2/Savox 2274/Tekin Pro4HD 4300kv/Airtronics mt-4/SMC
Waflet is offline   Reply With Quote
Old 03-20-2015, 07:19 AM   #452
jannedwr's Avatar
So here´s my solution. All the binding is gone! If you need longer travel for springtension (i.m.o totaly wrong spring) there is allways the old MBX5 and MBX6 spring shims to use!
Originally Posted by jannedwr View Post
Some examples of other brands:
Tessmans HB
Haras Sworx
Tebos Kyosho
Quagraines JQ
and so on....!
Here you can see some rubbing from the spring on the threds:
Battles MBX7
Mugen MBX7R ECO *Mugen MBX7R *X-Ray X12 2016 *X-rayM18Pro *Tekin*Sanwa Super Zero*Sanwa M12
Our tracks in Uppsala, Sweden
http://storvretarc.blogspot.com/
http://rorkenrc.blogspot.com/
jannedwr is offline   Reply With Quote
Old 03-22-2015, 10:31 AM   #453
I have the car all stock, kit setup. 20 or so packs through it. I cannot get rear ride height lower than 29, even with the adjustors all the way up. Any ideas?
klithgow416 is offline   Reply With Quote
Old 03-22-2015, 03:06 PM   #454
Fast410's Avatar
Trader Rating: 42 (100%+)
i have had mine as low as 25 in rear for the in door high bite clay track i run at . something has to be wrong .. are you checking it with a battery in it? any binding?
GRUDGE RACING $$ PROMOD KUSTOMZ real race car fabrication and custom painting -airbrushing CHICAGO WISEGUYS RACE CIRCUT-1/4 mile Door Slammers @ 200mph plus
Fast410 is offline   Reply With Quote
Old 03-22-2015, 04:27 PM   #455
rcgod's Avatar
Trader Rating: 27 (100%+)
It depends which hole the rear hub hinge pin is in too. If you want a lower ride height use the lower hole if you have to use the stock springs.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 03-22-2015, 07:41 PM   #456
Yes battery in, body on, track ready. Nothing is binding. I don't understand. This is my third Mugen car, never seen this before.
Old 03-23-2015, 01:57 PM   #457
Fast410's Avatar
I thought he said he built it kit set up which is on lower hole .
He may want to double check that could be his problem.
Old 03-23-2015, 02:22 PM   #458
rcgod's Avatar
The setup sheet that came with my kit shows upper hole.
Dialed RC Hobbies
Old 03-26-2015, 04:04 PM   #459
Fast410's Avatar
So has anyone ran drakes set up yet ?
Old 03-27-2015, 05:34 PM   #460
debocurl5.0's Avatar
Originally Posted by wreckya View Post
Can u tell me what parts I need for the under drive? Thanks.
Sorry I Just Seen This Message I'm NewTo The ForuM. And just realied this phone is caping everything to lol. But this is a gear change in rear to make the front a bit faster to make it track straighter on acceleration.
debocurl5.0 is offline   Reply With Quote
Old 03-28-2015, 01:30 AM   #461
joykiller44's Avatar
42 th ring gear and a 12 tooth pinion nitro RC has them in stock
joykiller44 is offline   Reply With Quote
Old 03-28-2015, 09:09 AM   #462
Fast410's Avatar
I GUESS NO ONE YET ??
Old 03-29-2015, 06:42 AM   #463
egobrkr's Avatar
Trader Rating: 26 (100%+)
I have ran some of his setup plus the weight on the rear. For me the changes were very good. I'm more of a " go big or go home" kinda driver. It smoothed out the steering and gave me more rear traction and I was able to push harder then I was able to do with stock setup.
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 03-29-2015, 08:58 AM   #464
Fast410's Avatar
Yea I'm a aim and shoot driver I go hard in and out of corners I'm mostly stock set up . What I want to make better is out of a bigger corner push I start on inside but end up outside at corner exit on power . Off power it turns on a dime
Old 03-30-2015, 02:11 AM   #465
My MBX7r Eco suffers from oversteer, each exit from turns.
Could you please tell me what to do to mitigate the problem ?
I have the default box setup
Thanks in advance
Emmeth is offline   Reply With Quote
