Like Tree16Likes
Old 02-23-2015, 08:39 AM   #346
cyba888's Avatar
Originally Posted by rcgod View Post
That's how mine looks too.
+1
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 02-23-2015, 02:48 PM   #347
egobrkr's Avatar
Trader Rating: 26 (100%+)
Originally Posted by dengor View Post
As per the attached photo of the rear upright shaft...is that normal to have a big space between the upright and the shaft nut?
Yes this is normal
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 02-23-2015, 11:29 PM   #348
MBX7R Nitro owner. New to electrics, however. I race at a medium-sized indoor track with high traction. Looking at the following ESC/motor combo. Will the 2000kV motor be suitable?
http://www.amain.com/lrp-ix8-esc-dyn...2000kv/p291943
kookeez is offline   Reply With Quote
Old 02-23-2015, 11:55 PM   #349
It should be more than enough. Probably need to turn down power level at ESC and Radio.
I run 4s/1900kv on large outdoor track with no problem.
ramctd is offline   Reply With Quote
Old 02-24-2015, 12:36 AM   #350
How would it compare to the 2200kV?
Old 02-24-2015, 02:19 AM   #351
I currently have the Tenshock X802 v2 (2100kv) from my previous buggy, and still need to buy an esc for the mugen. I've been set on getting the Xerun 150a, but have been reading that the Xerun SCT-PRO would also be an option. Any advice on which one I should use for the mugen?
dengor is offline   Reply With Quote
Old 02-24-2015, 03:41 AM   #352
egobrkr's Avatar
I use a tekin 2050kv in mine with a 13t pinion on a similar track as you and it works great. I only adjusted the current limiter in the esc down to 50.
Old 02-24-2015, 05:42 AM   #353
rcus3r's Avatar
150a vs SCT PRO. Had them both running 1900kv.
150a is big and quite a bit heavier. Barely fit in my x6. Ran great. No complains. If you ever plan on running more than 4S, you're set.
SCT PRO is smaller, lighter, fits better, and has plenty of power. I like it better for the size and weight reasons.
rcus3r is offline   Reply With Quote
Old 02-24-2015, 05:57 AM   #354
Good to know, thanks. I just checked my x802 v2 has a max amps of 130a. Does that mean a 120a esc won't be able to handle it?
Old 02-24-2015, 06:48 AM   #355
Do you think the 44T spur with the 14T pinion is a good starting point with a 1900KV motor? What batteries is everyone running? I bought a couple of the SMC 4S 60C 6500MAH packs. Is that a good choice? I thought about buying a one of the SMC 4S 70C 4600MAH packs to play with.
Just got all of the pieces so I am going to start putting it together.
Thanks for any advice.
Al_T is offline   Reply With Quote
Old 02-24-2015, 11:37 AM   #356
Also interested in battery choice. I just ordered the ProTek 4S 100C 6700mAh. But confused as to which charge cable goes with it.
http://www.amain.com/protek-rc-4s-su...700mah/p271105
Old 02-24-2015, 01:35 PM   #357
rcgod's Avatar
Trader Rating: 27 (100%+)
Sct pro will handle it no problem. The mamba max pro handles ebuggy fine and it's rated at something below 100 amps.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-24-2015, 01:41 PM   #358
Davidka's Avatar
Trader Rating: 76 (100%+)
2200kv = way more than needed. I run a 1700kv on 4s. More power than any nitro, maybe a couple mph slower on top if you're running on a really big track.
Sounds like guys are running really big batteries (6500mah+). If you're doing 20+ minute runs then that's fine but if you're going 10 minute mains, think about running smaller packs. I make 15 minute mains on my setup with 4500mah packs, which are several ounces lighter.
Old 02-24-2015, 02:42 PM   #359
wreckya's Avatar
Originally Posted by cyba888 View Post
Which shock air remover are you guys using? I have one for 1/10 onroad but the canister is too small
Never heard of such a thing but interested can u point me in the direction to get one? Thanks
Tekno SCT410.3, Kyosho MP9E TKI , HB D413, Losi 22SCT 1.5
wreckya is offline   Reply With Quote
Old 02-24-2015, 05:55 PM   #360
RumbleBeeAL's Avatar
Trader Rating: 55 (100%+)
Result of my MBX7R Eco w/ Tekin's RX8 and 1900kv combo build:
Mugen MBX7R Eco thread!-mbx7r-eco-3a.jpg   Mugen MBX7R Eco thread!-mbx7r-eco-6a.jpg
Gordon
(It's pronounced Gor-don...)
Futaba 4PX | MBX7R Eco| MBX7R Nitro | MBX7T Nitro
RumbleBeeAL is offline   Reply With Quote
