Like Tree16Likes
Old 02-09-2015, 04:11 PM   #286
Hi there I just brought a mbx7r eco and takin 2050 combo I just like to know what pinion do I need to run on my buggy and what percent current limited I need to set on rx8 as I run on alarge lose dirt track outdoors
coombes is offline   Reply With Quote
Old 02-09-2015, 04:15 PM   #287
egobrkr's Avatar
Trader Rating: 26 (100%+)
I go between a 13t and a 14t. I use the 13t 75% of the time. Current limit set at 40
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 02-11-2015, 03:07 PM   #288
rcgod's Avatar
Trader Rating: 27 (100%+)
Just got done building my buggy, and the front has a ton of camber. Like 4 degrees. I used the 1mm spacers top and bottom like the manual shows. Is that the normal amount for this car?
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-11-2015, 03:28 PM   #289
alvinsmith75's Avatar
Trader Rating: 38 (100%+)
I think mine ended up about 3ish. That's normal but more than I'm used to.
alvinsmith75 is offline   Reply With Quote
Old 02-15-2015, 08:44 AM   #290
harley4me's Avatar
Trader Rating: 24 (100%+)
Talking Question about Mugen MBX7R ECO????
I have 2 question about Mugen MBX7R ECO. What size are the inner hinge pins in mm and why do people use an underdrive rear diff set??? Thanks!!!
Charles Dukerich
Team BUST'D NUTZ
Team Xray XB2 Carpet
financial support from my wife Karen
and out of pocket support
harley4me is offline   Reply With Quote
Old 02-15-2015, 09:49 AM   #291
Before I tear a shock boot, can anyone tell me if you can pull it over the shock bottom without tearing it or are they supposed to be installed before the shock bottom. Instructions appear to have them going on after?
MBX7 Eco, MBX7R Eco
SC10 FT, Tekin RS, Fantom Ion 3
Southern Cross Guest Ranch
www.southcross.com
Dmann33 is offline   Reply With Quote
Old 02-15-2015, 01:11 PM   #292
Waflet's Avatar
Trader Rating: 30 (100%+)
Hideeho
I don't have my buggy in front of me to measure the hinge pin, sorry.
The under drive in the rear gives more rear traction under acceleration with the same dif oil weight. I.e. Running 7k rear dif, no under drive feels similar to running 3k rear with under drive. The benfit is lower oil weight allows it to go around a corner with less scrub (one wheel sliding due to different speeds), but it will still pull out of corners by the front end.
Waflet is offline   Reply With Quote
Old 02-15-2015, 01:13 PM   #293
Waflet's Avatar
Hideeho
It is possible, but VERY tricky. I put a drop of oil on mine to get it done. Next time I will pull the end off.
Old 02-15-2015, 01:17 PM   #294
egobrkr's Avatar
I install the boot be for I put the shock shaft into the body.
Old 02-15-2015, 01:18 PM   #295
rcgod's Avatar
Has anyone tried different piston/oil combos? Started with stock setup but shocks have way too much pack. Went all the way down to 32.5 losi oil before they started feeling right.
Dialed RC Hobbies
Old 02-15-2015, 01:18 PM   #296
harley4me's Avatar
Default Question about Mugen MBX7R ECO????
looking to buy a hinge pin reamer so i am wondering if they are 3mm or 4mm
Charles Dukerich
Team BUST'D NUTZ
Old 02-15-2015, 01:18 PM   #297
egobrkr's Avatar
The hing pins are 4mm
Old 02-15-2015, 01:20 PM   #298
egobrkr's Avatar
I use mugen 600cst front and mugen 550cst in rear. I just ordered the 5x1.3 16mm pistons to try.
Old 02-15-2015, 01:22 PM   #299
harley4me's Avatar
thank you! are there any hop ups or tricks that i should do to buggy as i am just getting back at it after a 10 year vacation from rc
Charles Dukerich
Team BUST'D NUTZ
Old 02-15-2015, 01:45 PM   #300
egobrkr's Avatar
The kit needs nothing. You only need to buy tuning opinions if you want the kit to drive different from stock.
