Mugen MBX7R Eco thread!
#1936
Use the velcro on the sides?
#1938
You could also try some hobby store foam under the shell between the body and posts
#1939
We have the Tekin RX8 esc. I noticed the cooling fan was not working so ordered some new fans. Now the fan runs a couple of seconds when initially turned on then stops. Is that normal? Is there a heat sensor that activates the fan or should it run continuously? Thanks.
#1940
No need to reply. Called Tekin..they explained. Thanks anyway.
#1943
Yeah it happened to me twice at pnb while using pro-line wheel nuts.the left rear wheel nut came off in my first qualifier while running 2nd on the last lap. It came loose in another qualifier but didn't fall off . I ended up buying some more wheel nuts. And haven't had a problem since.I don't think it was a problem with the pro-line wheel nuts. But the ones I bought are more aggressive.
#1944
Tekno ones have agressiv teeth ! those won't come loose !
#1945
On older software default was "fan auto on" which turns the fan on as needed. On the latest software and units, it's defaulted to "always on" which is required to use the new Hotwire 3.0.
#1946
Thanks. It is not gen 2 so seems to be operating correctly.
#1947
#1949
Stock diffs w/ underdrive gears are treating me well. I don't run on high traction w/ 1/8th so I have no intentions on getting the new diffs. I thought I heard the new diffs really shine on high traction. I did about 8 races over the last 4 months w/ out changing the diff fluid/bearings and my diffs were full and bearings were still smooth. Tough to beat that, once work slows down I'll change the fluid every other race or before any important race.
#1950
Anybody have issues with center diff outdrives? I just noticed the pins on mine have major flat spots, and the outdrives are worn. I've put maybe 30 packs through the truck.
The front and rear outdrives are in great shape, no noticeable wear, and pins are good. I'm just curious if this is normal for the center to wear so quickly?
