Like Tree16Likes
Old 03-12-2016, 06:13 PM   #1501
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Originally Posted by Mlhayes View Post
Hey guys sorry, I know this was covered multiple times but I can find it listed. I'm just trying to see what percentage of the mbx7 Eco crosses over to the mbx7r Eco. I know most of the rear geometry is different and different chassis but is the rest mostly the same? I currently have a mbx7r Eco and love it. I have a chance to get a good deal on a clean mbx7 Eco and would use it as a parts car. Trying to decide if it's worth it. Thanks for the help.
It's worth it, the shocks and the rear tower is the biggest difference.. Oh, and the uni's
hairymuffin is offline   Reply With Quote
Old 03-12-2016, 09:39 PM   #1502
Thank you.
Matt
Til the wheels fal alf.
Mlhayes is offline   Reply With Quote
Old 03-13-2016, 11:43 AM   #1503
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
Will these fit for center? http://www.ebay.com/itm/Kyosho-Infer...EAAOxycmBSzuLd
Mugen Seiki \\ Dialed RC \\ Tekin \\ SMC \\ AVID\\ AKA \\ Futaba
OfnaJoe is offline   Reply With Quote
Old 03-13-2016, 02:27 PM   #1504
werner sline's Avatar
the size is written right below :
Kyosho 1/8 Inferno MP9 TKI3 Buggy (Model KYO31788B)
Center Front Universal Shaft (Part # IFW430)
84mm
Center Rear Universal Shaft (Part # IFW431)
110mm
but where did they measure exactly ?
werner's bunch of RC freestyle: werner's new video : hobao hyper MT trailer 2 : HIGHER!
https://youtu.be/CLPFyAtPCY0
werner sline is offline   Reply With Quote
Old 03-13-2016, 04:34 PM   #1505
OfnaJoe's Avatar
84mm
110mm
I know, those measurement are longer than Mugen, but where do they get there numbers from
Old 03-14-2016, 10:24 AM   #1506
nitro2be's Avatar
took the most flashiest colour in the shop ( they didn't have any neon colours...)
did someone say pumpkin ?
by the way , note the proline trifecta wing : looks great ! I added the decals and it's really a nice RC piece !
wheels are premounts from Conrad : cheap but too stiff... I will use them for mild bashing and not jumping
PUMPKIN. LOOKS GOOD
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 03-14-2016, 03:05 PM   #1507
yeah I'm going to smash some pumpkin !
Old 03-17-2016, 11:36 PM   #1508
fifi's Avatar
I was told that some people were using tlr diff on the mugen for more traction.
Anyone tried? which one all 3?
fifi is offline   Reply With Quote
Old 03-18-2016, 12:47 AM   #1509
Default Mbx7r Eco Tekin 2050 Gearing?
I just bought my first buggy and I'm trying to understand what the best spur / pinion gear to go with. I'm running the Tekin 2050 motor with 14t / 46t. What's the most common setup for this motor?
TCrutcher is offline   Reply With Quote
Old 03-18-2016, 02:21 PM   #1510
nitro2be's Avatar
14t and stock spur is what I found to work just about anywhere and I have 2050 tekin factory settings.
Old 03-19-2016, 08:58 PM   #1511
Trader Rating: 120 (100%+)
Anybody using the M2C Chassis and if so can you give me some feedback on it good or bad. Thanks.
B6D
B64D
Tekno EB410
JoeC is offline   Reply With Quote
Old 03-21-2016, 07:37 AM   #1512
mxnickj's Avatar
Trader Rating: 51 (100%+)
Originally Posted by mxnickj View Post
For those guys running the clutch/traktion drive system, could someone please tell me or show me how you modified your center diff mounts to get the diff flipped around? I have seen some pictures of Drake's buggy but none were close enough to really tell what was going on there. Thanks guys!!
OK, so I modified diff mount and flipped it but the biggest problem I see is the spur gear rubs the chassis. I tried the 46t and 44t and they both rub. Are people making a spacer for under the diff mounts? I got everything to work except that.
mxnickj is offline   Reply With Quote
Old 03-21-2016, 12:56 PM   #1513
rcgod's Avatar
Trader Rating: 27 (100%+)
CA glue 4 washers to the bottom of the diff mounts.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 03-22-2016, 11:29 AM   #1514
rcgod's Avatar
Also make sure you use the metal spur gear with the clutch. The plastic gear gets hot with the clutch and will strip out easier.
Dialed RC Hobbies
Old 03-27-2016, 04:09 PM   #1515
Are any of you running the VRP pistons and if so can you give me some feedback please. Thanks
B6D
B64D
Tekno EB410
