Old 09-20-2005, 11:09 AM   #16
Aaron Waldron's Avatar
Well, then it's probably not the diff...if you loosen the slipper a little bit,
Does the truck pull to one side, like a bearing is going out? Does the top shaft, idler gear shaft, and diff stay put without wobbling inside the tranny case? Grinding is USUALLY gears.
Aaron Waldron - LiveRC
Aaron Waldron is offline   Reply With Quote
Old 09-20-2005, 11:43 AM   #17
Originally Posted by jbrow1
Carpy, sometimes if you have a roasted diff, it'll work when it's cold. And you can't really tell if it's blown if you're not experianced with the mechanical side of rc yet because everything is pretty much locked together. But when it gets warm or hot the parts unlock and just spin. You probably have to take apart your tranny and see if that's the case. Best thing is to just use the manual and tear it down.
Thank, I'll figure out which bit is the tranny and take it apart. lol.
Carpy is offline   Reply With Quote
Pinion gear grinding darkness Electric On-Road 7 02-07-2006 02:54 PM
Crank grinding, who to....... rcfoolz Onroad Nitro Engine Zone 11 11-03-2005 06:49 PM
grinding gears stevie605 Nitro On-Road 3 02-03-2005 07:12 AM
Grinding a 7 port sleeve revzalot Onroad Nitro Engine Zone 4 02-02-2005 04:54 PM
new here, but my 4-tec is grinding...? t3guy Electric On-Road 12 05-24-2004 12:01 AM
SEO by vBSEO 3.5.0
