Like Tree1Likes
Old 01-29-2017, 08:29 AM   #421
motoj550's Avatar
Trader Rating: 22 (100%+)
Nice job on the front skid TMan! looks like that will work just fine. I've had mine for over a year now and have not had one problem with my front bumper yet (knock on wood) but i only race mine at the local indoor clay track and at home on my outdoor track only.
XR10 A Higher Plane Of Existence
motoj550 is offline   Reply With Quote
Old 01-29-2017, 09:34 AM   #422
amospetrie's Avatar
Originally Posted by TMann View Post
Here is a prototype part for the front skid mount. I was going to make that swivel mount part out of aluminum, but the washer mod has been holding up pretty well. So I am just going to make up some re-enforcement plates. It's a lot less work to make a plate than that part! This one is 2.25mm thick or .88" It is a little thin for the Flat head 3mm screws, the head is 2mm deep. So I may try and find some 2.5 thick .1" 6061 aluminum.
Sweet plate.. the part u have the top of the skid plate screwed into is what I have broke and can not get from tower.. anyone have suggestions? I tried to post pic but won't upload
amospetrie is offline   Reply With Quote
Old 01-29-2017, 03:57 PM   #423
I think you are talking about the little skid mount that swivels. Its part of the front bumper set. Tower still has some in stock, $8.99.
TMann is offline   Reply With Quote
Old 01-29-2017, 04:06 PM   #424
I've got a big problem, today I was driving my cutback and I gunned it full throttle, then tried to brake, and it didn't brake. It ended up going full throttle off the track into the woods about 150 feet away. Some cactus stopped it. The whole Time was trying to stop it, I even turned off the transmitter and it wouldn't stop. I ran up to it and it the motor and wheels were still going full throttle. LOL. I know I have a short in the off and on switch if I do a big jump it will turn the truck off. I did reset the neutral fail safe a few days ago on the receiver. I didn't want to risk it going crazy again so I packed up and left. Think it might be the ESC?
Old 01-29-2017, 05:33 PM   #425
Probably yes. Is it still the stock one? Hate to say I told you so but I strongly suggested a while back that you get a new ESC. Mine did all sorts of strange things (that I posted bout) before it went up in flames and luckily didn't burn down the whole truck. Your loss of power may not be the switch. Mine shut off a few times and would work again after a power cycle.
rhodesengr is offline   Reply With Quote
Old 01-29-2017, 06:56 PM   #426
t's weird, but I don't remember the steering working at all either when it when it was going. I don't trust the RX and TX either. Its on its second transmitter according to the guy I bought the cutback from.
I bench tested it tonight and couldn't create the problem again.
Looking at CC SV2 SCT esc, same as the sidewinder 3, just has a fan $53. Also looking at the HK 100A esc $40, and the HW EzRun MAX10 SCT $65.
Also looking at the TTX300 Tactic TX/RX combo, Futaba 3PRKA combo and the Spectrum DX2E combo.
Old 01-29-2017, 08:07 PM   #427
well maybe the RX/TX was causing problems. I had already switched to a Spektrum DX4S which came with two RX's; one with AVC and one without. The ESC did the same things with the Spektrum RX/TX. So at least in my case, the RX/TX seemed OK.
Old 01-29-2017, 08:09 PM   #428
I mean get a real RX/TX if you want but you may want to just put a new ESC in first and see how it goes.
Old 01-30-2017, 05:00 PM   #429
amospetrie's Avatar
I ordered a front bumber a couple months ago.. that part wasn't In there.. guess I should call tower..by any chance do you know what the part is called on the chassis that the little swivel skid plate screws into.. screws are broke off in it. Thanks
Old 01-30-2017, 05:42 PM   #430
Weird I have ordered it and it was in there. They jipped you!
Also, google part# MV29116
Old 01-31-2017, 05:46 AM   #431
amospetrie's Avatar
I'll just reorder it and hopefully I comes in the package this time.. thanks tmann
Old 01-31-2017, 05:51 AM   #432
amospetrie's Avatar
Default Hpi timberwolf
So we all know the Cutback is really a hpi timberwolf.. being worried the timberwolf would be discontinued (to order parts from the uk) since the Cutback was.. I emailed uk hpi.. here's what they said
The HPI Timberwolf is still available and a current line. There is no plans to discontinue it.
Unfortunately you can not buy direct from ourselves, so if you contact someone like ModelsportUK or Wheelspin Models then they will be able to help you, and they ship worldwide.
So looks like we will be able to get parts.. just more in shipping.. for instance from modelsportuk a front bumber is 8 bucks shipping.. so not to bad
Old 01-31-2017, 07:07 AM   #433
Yeah not bad, there's a few sellers on ebay too with Timberwolf parts.
I'm seriously considering a Hobao hyper 10SCe for a second truck.
I've been trying to re-create the problem I had, but all attempts have failed. There is some kind of issue with the RX or ESC, or both. Probably going to have to shell out for new electronics...
Old 01-31-2017, 07:51 AM   #434
amospetrie's Avatar
I bet it's the esc. I took out the tower esc and put it in my prosc 4x4. using the associated rx/TX. It only did it once but it took off once by itself wouldn't stop till it hit something and flipped over.. also while hitting jumps it will just stop. Have to turn off and back on to get it running again witch sounds like the same issue u have..
Old 01-31-2017, 08:14 AM   #435
I turned off the TX towards the end, and it was still going full throttle, which leads me to believe its not the transmitter. Im pretty sure the servo was not working either, so that tells me the RX was not giving it signal.
I was going on a strait away full throttle, coming up to a turn... I braked and turned, but it kept going strait and full throttle. So both the servo and esc were not working correctly.
Maybe the ESC was not giving the servo power?
