Like Tree1Likes
Old 02-01-2016, 06:05 PM   #316
Originally Posted by edgeverse View Post
How many runs did you get before this happened?
Mine did it seconds after plugging in and prepping to run this truck for the first time. (same day it arrived)
I have about 6 2s packs through it. I was nearly done with a 3s pack when it smoked... It was a huge cloud. Does this esc not have an over temp shut down? It should......
java230 is offline   Reply With Quote
Old 02-01-2016, 06:10 PM   #317
edgeverse's Avatar
I believe it does.
HPI Blitz / Helion Dominus 10SCv2 / EMaxx / Ofna Hyper 10SC
Edge1RC.com - Reviews and More
edgeverse is offline   Reply With Quote
Old 02-01-2016, 08:05 PM   #318
I believe it does.
Nothing in the manual I can find.
Anyone know if this esc is supposed to be 3s capable?
Old 02-02-2016, 02:50 PM   #319
I looked at the tower hobbies manual for the Speed control part# TOWM3000
it just says "LiPo cutoff 6.4v" nothing about 2s or 3s
so it safe to say stick with 2s for a long ESC life
imusa76
imusa76 is offline   Reply With Quote
Old 02-02-2016, 03:56 PM   #320
edgeverse's Avatar
I do know that people have ran it on 3s. Thats dude Vas from Aussie RC Playground did a video of it.
Old 02-03-2016, 10:39 AM   #321
Yeah says nothing. I emailed Tower, they didn't know.... But its safe to say with the 17/54 and a 3s, watch your ESC temps...
Old 02-03-2016, 05:18 PM   #322
might have go down on teeth when on 3s.
chris555 is offline   Reply With Quote
Old 02-03-2016, 06:06 PM   #323
I think to run the 3s you have to stick with the stock 11/62 or 11/54 due to the ESC temps.
now the HPI Timberwolf which is what this car is, under the specs it lists
"Waterproof 80A Brushless ESC - 2S or 3S capable "
And in the Timberwolf manual here is what it states for the ESC:
MSC-29BL-80WP Features:
1. Water-resistant* and dust-proof. The ESC has been designed to
work in wet conditions.
a.*Please remove the cooling fan when using the ESC very wet conditions.
b.*After using the ESC in wet conditions, please clean and dry it to avoid
the oxidation to copper connectors
2. 2-3S Capalable (for 3S you must change the standard 5V
cooling fan to a 12V cooling fan, or supply the 5V cooling fan from
the receiver 5-6V);
3. Compatible with sensorless brushless motor.
4. 3 running modes (“Forward with brake” mode,
“Forward/Backward with brake” mode, and “Rock Crawler” mode).
5. Proportional ABS brake function with 4 steps of maximum brake
force adjustment, 8 steps of drag-brake force adjustment.
6. 9 Punch modes from “Soft” to “Very aggressive” to be suitable for different chassis, tires and tracks.
7. Multiple protection features: Low voltage cut-off protection for Lipo or NiMH battery / Over-heat protection /
Throttle signal loss protection / Motor blocked protection.
8. Easily programmed with the “SET” button on the ESC or with the LED Program Card.
Model MCS-29BL-80WP
*Continuous Current 80A
*Burst Current 540A
*Resistance 0.0004 ohm
*Application 1/10 scale On-Road and Off-Road
*Motor Limit 2S LiPo / 6 cell NiMh
*On-Road: ≥ 5.5T
*Off-Road: ≤ 6000Kv
*3650 Size Motor
*3S LiPo /9 cell NiMh
*On-Road: ≥ 8.5T
*Off-Road: ≤ 4000Kv
*3650/3660 Size Motor
*Battery 4-9 cells NiMh or 2-3S LiPo
**1) For 4-6 cells NiMH or 2S Lipo: You needn’t change the 5V cooling fan on the ESC;
**2) For 7-9 cells NiMH or 3S Lipo: You must change the original 5Vcooling fan to 12V cooling fan, or supply the 5V cooling fan from the receiver (5-6V);
*Built-in BEC 6V/2A Linear
*Program Port Multiplexed with cooling fan port
*Motor Type Sensorless Brushless
*Dimension 46*34*35mm
*Weight 82g
imusa76
Old 02-08-2016, 07:01 PM   #324
Replacement esc is in! Different than the stock one, has overheat protection mentioned in the manual! But still needs a fan swap for 3s.
I think I will get the parts to power the fan from the receiver.
Old 02-16-2016, 08:24 PM   #325
edgeverse's Avatar
I checked the status of my esc replacement via towers site and it shows pending. Was filed last november.
Old 02-20-2016, 02:02 PM   #326
Damn, email them. They forgot to ship mine when they got the order in apparently. The replacement seems like a nicer unit. Has a decent manual anyway...
Old 02-28-2016, 05:59 PM   #327
denon's Avatar
First post on the truck. Out of the box I thought it would have more speed. Reading through the threads here we changed to the optional spur it came with and changed the pinion to a 14t. It went from 22mph to 32mph (Used a phone GPS). So much faster. It was night and day. So far we have had the bumper break twice. It just rips out of the bottom two screws. Has anyone found a workaround? I guess workaround 1 will be to not nosedive at the track as much .
denon is offline   Reply With Quote
Old 02-28-2016, 06:10 PM   #328
edgeverse's Avatar
I did the same thing went to a 14t pinion and swapped out the installed 62t spur and used the optional 54t. Huge difference in speed. Great truck.
Old 02-28-2016, 06:11 PM   #329
edgeverse's Avatar
Update: Emaild Tower's HobbyServices dept and they are shipping mine out sometime Monday. I will keep you posted.
Old 03-26-2016, 06:52 PM   #330
I ordered all the parts to make 2 center diffs for a quick swap out, one set running the stock 11 p 62 s, and an optional 15 p 54 s for Speed.
I love the speed of the 15p 54s gives, but the 11p 62s has better small area handling, Now I can easily swap out depending on the area I'm bashing in or racing.
Both center diffs are running 300,000 wt oil, its VERY thick, but it helps keep the 4x4 always engaged, great for rough terrain.
Also as an upgrade I bought the ProLine 2017 Raptor body, it look GREAT!!! I'll post up some pictures when I get a chance.
the only Mod I had to do to make it fit was add extensions for the front body mounts, and quick and simple mod ($3.00 on Ebay.)
imusa76
