Like Tree1Likes
Old 12-23-2015, 07:30 AM   #241
Anyone running diff oil front or rear, what weight?
Losi shocks do look good, but I found a good quality 40wt helped the stock ones immensely. They actually feel decent.
java230 is offline   Reply With Quote
Old 12-23-2015, 10:49 AM   #242
Took it out to a local park by my office. I'm happy to report that with the 17/54 and 40 wt in the shocks, the noise stayed up jumping. Shocks were a bit soft and it bottomed out a few times however.
It traction rolls very easy, and was endoed a number of times.
I made a spray shield that wraps around the front of the tub, seems to help keep the big chunky stuff off the ESC. Hosed the mud off and its drying now!
Old 12-23-2015, 04:02 PM   #243
edgeverse's Avatar
@Ross, thanks for the tips on slash bodies. Knowing that, losi xxx sct bodies would fit as well. I used to run a losi xxx sct body on nmy slash and it fit perfectly, body mount holes and all.
@Java, sounds like you are liking the truck.
HPI Blitz / Helion Dominus 10SCv2 / EMaxx / Ofna Hyper 10SC
Edge1RC.com - Reviews and More
edgeverse is offline   Reply With Quote
Old 12-23-2015, 04:15 PM   #244
Yup so far so good. My daughter drove it too! Reverse doesn't seem to work very well, and I think I bent either a wheel or axle shaft..
Old 12-23-2015, 04:21 PM   #245
edgeverse's Avatar
The reverse issue may be the esc needing a good calibration.
Old 12-23-2015, 05:04 PM   #246
Hmmmm I didn't see any mention of a calibration in the manual, details?
Old 12-23-2015, 05:19 PM   #247
edgeverse's Avatar
I found the esc manual via tower's website.
http://www.towerhobbies.com/manuals/...000_manual.pdf
Old 12-23-2015, 05:23 PM   #248
my reverse is a hit or miss as well. i had programmed it out. but put it back the other day and still may remove it again.
chris555 is offline   Reply With Quote
Old 12-23-2015, 05:55 PM   #249
Saw that too, don't see any calibration info
Old 12-23-2015, 06:00 PM   #250
edgeverse's Avatar
I noticed its kind of vague (much like the manual in the box for the truck itself) as far as calibrating goes.
Old 12-23-2015, 06:49 PM   #251
i think it a safety feature to not go full forward to reverse. safe guard the motor kind of thing. i know i have to go brake back to neutral and then reverse.
Old 12-23-2015, 07:10 PM   #252
edgeverse's Avatar
Well, normally, when going forward, you tap the brake once for braking, twice for reverse.
Old 12-23-2015, 07:48 PM   #253
Yes, and then it makes weird noises instead of going in reverse...
Old 12-23-2015, 08:06 PM   #254
amospetrie's Avatar
So my center rear drives haft keeps falling out its like it's to short anyone else have this problem?
amospetrie is offline   Reply With Quote
Old 12-23-2015, 08:24 PM   #255
he's to hoping the thunderstorms don't show up.
