Like Tree1Likes
Old 12-08-2015, 04:03 PM   #151
edgeverse's Avatar
https://www.youtube.com/watch?v=qiLsipMbwlc
Try this link above.
HPI Blitz / Helion Dominus 10SCv2 / EMaxx / Ofna Hyper 10SC
Edge1RC.com - Reviews and More
edgeverse is offline   Reply With Quote
Old 12-08-2015, 04:33 PM   #152
much better !
https://www.facebook.com/kyrcrc/
slowsrc is offline   Reply With Quote
Old 12-08-2015, 05:18 PM   #153
edgeverse's Avatar
I think this weekend, after I install the rear swaybar kit (front is done already), I may swap the 62t for the 54t spur and go with a higher pinion and se what I can get out of her.
Old 12-08-2015, 05:36 PM   #154
i'm running 54t spur. i don't nose in much. i have a 16t pinion waiting to go in and the turnbuckles as well. what size battery is everyone running. i have 1 25c 4000, and two 25c 5000 on the way. my friends son runs 40c lipo and his box stock prosc kills me in a straight line. i can out handle him so i can keep him in reach.
chris555 is offline   Reply With Quote
Old 12-08-2015, 06:04 PM   #155
edgeverse's Avatar
chris555, thanks for chiming in.
I am running 2s 5400mah 40c batteries in mine. Stock gearing (11t/62t).
I also ordered the turnbuckle set. I was going to use slash 4x4 links but the servo link is much too short.
Did you change the shock oil or anything?
Old 12-08-2015, 09:14 PM   #156
no, i don't exactly understand all that yet. i do have the front shocks adjuster almost all the way down, and the back about half way. does not ride level. nose as high as i get it. left front has rubbed the body clear. not sure why. gonna rise body post location on the front. Went out to a track over in nj with a friend. getting better at driving. Still yet to break anything, other then crack in back of body where it goes over rear bumper. Gonna take some of my wives nail polish and make a visual aid on the adjusters so i can count turns to keep my adjustments equal. waiting on a camber gauge to come UPS before i throw the turnbuckles on. then i sent toe- in and camber, do the pinion. I have been real happy with the truck overall. I'm a real low budget guy, so i know i'll never be able to get or have the best out there. so it fits what i want to do.
Old 12-08-2015, 09:16 PM   #157
thinking i should have got 2 40c or 50c lipo's. guess we shall have to see what the future holds.
Old 12-09-2015, 03:44 PM   #158
edgeverse's Avatar
I haven't done a thing with the shocks or diffs. Running mine stock pretty much.
A camber gauge is always a good thing to have. I use the Losi one.
Old 12-09-2015, 05:05 PM   #159
well turnbuckles are in as well as the pinion. notice one of the front arms is way stiff even with nothing attached to it. also it doesn't sit as low as the opposite one. the stiffer one is on the opposing side from the body rub. by stiffer i mean it does not move as freely. wish i could find a way to set the front toe, i do have to change supplied toe blocks in the rear. it was dark by the time i got the turnbuckles in, so no road test.
Old 12-09-2015, 05:43 PM   #160
Originally Posted by superotto80 View Post
So I took mine out this weekend on my little homemade track and here are my initial reactions. First, the conditions were loose, damp dirt so traction was not great which made the truck a little tough to drive for a 4x4. Not sure if it was the tires or conditions. Second the servo is very slow, will need to be upgraded eventually. I actually was a little surprised with the speed, I read everywhere how slow it is on 2s, but I did not think it was that bad. The one very minor annoying element of the truck is the battery location is tight, getting a battery in then trying to get the velcro straps is annoying.
Overall, I really like the truck, it is solid and seems like it can take a beating. I do not plan on racing it so I will only upgrade as I break something.
I think if they pulled the buckles out a little bit so they don't keep getting under the shaft it would be best
Old 12-09-2015, 05:43 PM   #161
edgeverse's Avatar
I am unsure why the front arm would not be moving freely with nothing attached (I am assuming you mean when the shocks aren't attached).
Maybe someone can chime in on this matter.
Old 12-09-2015, 05:57 PM   #162
Im thinking there is crap in the hinge point, might just need to tear it down and clean it up. anyone got any ideas on bearing lubricant? noticed bearing on center diff going to front seems to have build up of crud, well they all seems to. going to tear diffs down once the weather goes to hell here for the season, which isn't far off.
Old 12-09-2015, 05:59 PM   #163
Noticed it after I got shocks and both linkages off that i was replacing with turnbuckles.
Old 12-09-2015, 06:04 PM   #164
edgeverse's Avatar
I would say try taking the arms off and look over the hinge pins.
Old 12-12-2015, 10:20 AM   #165
anyone getting any trigger time today?
