atv postion on xp3-ss with rx8 gen1 wheb calibrating?
I'm trying to calibrate my rx8 gen1 with my xp3-ss radio but should the trim be at min mid or full?
Trim should be in the middle, or zero position. Not min or full.
I know trim should be 0. But atv on this radio is end point adjustment s. What should those be at
ATVs normally would be middle or 100% to start with, although some like to turn them all the way up. Then adjust brake to suit if separate adjustments are offered (assuming racing with no reverse).
if i calibrate atv high at min and have more power when i turn it to max as opposed to calibrating at max
