Old 02-26-2016, 12:27 PM   #76
targetingxmod's Avatar
Any rims in any size benefits for balancing...i have a video on my Losi Mini8 that balance rims are so smooth and so butter free from vibrations that i can gas all the way and nothing vibrates on the rc besides the shafts!!
NEWS:
Allright....i am dumb!! Well i had to try it!!
I am out of this 32T and 35T spur things...
Now i understand why those record speeds have only one pass....in first person!!
That's not for me. Over and out.
I am on the market now for a 40T spur... no less!
It thermal shutdown's after past 2minutes and both esc and motor are hot. ESC is hot to touch for 2 seconds and motor is just hot.
This is stupid. I do not want this. I just want to have peace of mind to empty the packs....
Learned something new today!! :P
Nevertheless i will make a video when everything is done (wheelie bar and front wing with the 32T, but that's it....) To play the entire pack is impossible. We got to know where the limit's are... this is pure death of eletronics... OUT!!
Key now is to find the sweet spot... the 45T pinion is allright with 46T spur...tested that and there is no heat after pack done!
Maybe a 40T spur will be ideal?
Oh Lord, save me from those "internet warriors" typing from mom's basement's... :P
targetingxmod is offline   Reply With Quote
Old 02-27-2016, 12:09 AM   #77
tyre balancing is critical. I ran unbalanced tyres on my nitro truggy once, and it looked like it was being shaken to pieces.
aussiercracer is offline   Reply With Quote
Old 02-29-2016, 11:53 PM   #78
Thumbs up
Ok guys,i going to make something with Some bearings from work or just buy a cheap tire balancer on the "vorza thread" i've showed the truggy wheels i want to go with.i will run them,and then balance them and try again.
Indeed Targetxmod i was still waiting for ordening the 22t/40 flyratio set
But i thought "damn,there is also a 35t spur set" but if they give heat issues with your motor,i certainly going to burn mine.
40t will be the best to empty packs!
Some like to have one pass with a motor that goes straight into danger hot zone,just for youtube speed Numbers.and i also read that the magnets always lose part of their force if going into "heat danger zone". i rather find a testing different setups quite amusing.heat vs driving time -) always a challenge!
Anthonytoyo is offline   Reply With Quote
Old 03-01-2016, 12:48 AM   #79
Dr_T's Avatar
35T spur works fine if you just do the math before you select the gearing - don't start off blindly gearing for 200 km/h, and you'll be fine .
2S is for servos, 4S is for minis.
Dr_T is offline   Reply With Quote
Old 03-01-2016, 01:52 AM   #80
Thumbs up
also a cool thread D'r.T...i'm clearly not as advanced in knowledge as you guys.
My big problem imo is prob that my vorza is far to heavy (i think one of the heaviest buggy's stock),then i added heavier 8s esc,heavier 4092 sss motor and now beginning testing gearings at 6s.
Your cars are all less heavy,it would also take more money to put into lightweight parts. But i'm enjoy now adjusting little things and learn from all The info i get
Old 03-05-2016, 01:20 AM   #81
Yah, he's a Jedi Master in math's....
I am not!! A garbadge master in math's :P
"Gear ratio" reconfiguration
-44T / 13T instead of 46T / 10T...
-500k on front and rear diff....
Also some bling...
Old 03-07-2016, 03:05 AM   #82
Another step up.nice!
Where did you found that 44diff gear and 13t pinion?
Old 03-07-2016, 06:25 AM   #83
USA. No customs :P "got lucky"
Old 03-18-2016, 11:09 AM   #84
Ah, that angle... NO MORE!
-Straight as an arrow! :P
Old 06-02-2016, 06:35 AM   #85
-Front wing, preparations!
-Done!
-Thanks "Lizard" for the foams!
Now let's see what this thing can do...
Well...not yet...waiting for my customs again for a central diff "thing"... dam...2 months...what are they doing in there?
Old 07-07-2016, 01:20 PM   #86
So after the "customs" wait, got my central diff.
-Now with a 44T plastic spur!
-Some test's to find out what pinion size to use, to empty packs without heat..more down to earth sizes!! :P
-The 43T was heavy compared to the new one!
-The smaller is a 35T that is the winner even less weight!
-On this, my wife eard the noise of the cutting machine and asked what i was doing.... :P
-And for what? To cut rubber, love! Making new holes for the fish line to not balloning...
"she turned the face and walked away...:P"
-Even with the 2 fish lines on the middle, it still ballon on the sides!!
Not anymore!
This truck makes "childreen" run away....and adults scrath their heads, thinking dam, wth? It's scary!
Also got new CNC alloy pieces for it! Not yet on photos
Old 07-13-2016, 12:10 AM   #87
The 44 plastic spur will make a huge difference in sound!
Can you Pm me if your pinions like 35-40ish are available for 5mm shaft?
I love it when children come and see the 1/8rc's and when you go full throttle,the run away
Wish i had a 10th scale when i was 15.
Old 07-19-2016, 09:58 AM   #88
Pinions for this motor are 8mm bore! Expensive shippment! Well what isn't on RC!
Latelly i didn't have the patience to make videos...but this thing rocks. Not to much tire balloning now
And yah, the stickers, cause it's a Kyosho! :P lol
Old 07-28-2016, 03:43 AM   #89
A little more bling...
-Front & rear chassis brace, with center diff tower. (the other side of the motor mount)
-Also now it got a big brother to take care! :P
Old 07-29-2016, 02:29 AM   #90
Very cool new truck! Very curious what your plans with it
I have my eye on the kyosho scorpion bxxl,looking forward to upgrade motor ,etc...
But just yesterday i bought an awesome hitec charger set.so hobby funds are low now,but i will never need another charger again
