Like Tree30Likes
Old 04-20-2015, 06:56 AM   #1411
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by Micah123 View Post
Do not see on teamassociated.com. Anyone know where we can get a wing replacement without having to purchase the entire body?
You will have to cut it slightly different but this should work:
https://www.jconcepts.net/shop/finni...gurney-spoiler
Or you could just cut your own out of a sheet of lexan.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-20-2015, 10:20 AM   #1412
Trader Rating: 486 (100%+)
I'm running my truck with a square pack all the way forward and with just a 13.5 I occasionally lift the front tires off the ground. I have fantastic traction. I'm running a mostly kit set up with slightly heavier oils and a gear diff w/3k. Its really easy to drive and I'm turning faster laps than I do with any of my B5Ms regardless of motor. When I first got the truck I decided to run the chassis stock as long as possible. Its been really good. The only chassis mod I did was a CF strap....just because I had it. So far the T5M has been an excellent buy.
**Edit. I run outdoor bluegroove. Running Proline X2 Suburbs with open cell foam. Once the temps outside are consistently over 80 I will run the AKA red foams. I have not broken the truck yet.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 04-20-2015, 03:00 PM   #1413
Gigasipke's Avatar
On Sunday we kicked off our outdoor race season. Stated this earlier but, the track is medium to low grip, quite smooth though. It is watered between each round, so on the tone it starts slick goes to best grip after a few laps, then by the end it is dry. If you are in the groove it is medium grip, but if you fall out of the groove it is low to loose grip.
So I used Thielke as my base setup. I followed MattK101's suggestion to use 2 rear limiters instead of one. When I first got onto the track to practice I was really worried, the truck wouldn't turn and had no traction. Part of this was the fact that the only surface my truck has seen is carpet, basically traction rich. After a few minutes the groove developed and I stuck to it. It was all coming back to me about throttle control and staying in the groove/racing line. For the most part you can drive anywhere on carpet. My biggest problem was steering. Low speed was fine but with any speed I could turn and just wait about 5 feet before the fronts would hookup. I have two sets of fronts and found the best for the track. They were the same ones I used on my T4, so I must have figured that out before. After talking to one of the setup experts, he doesn't race truck but is a good resource, he said to try going to a softer front spring. So I went from Blue fronts to Grey. I still had a push but got some steering back. And the medium speed sections of the track, as long as I stayed in the groove, were awesome.
One thing I didn't figure out from the Thielke setup was the rear hubs. I have the stock and guessed at what would match his rear stud mount location. I went with the A inserts UP and the center Hole. I think that matches.
So one other T5M was at the track and he TQ'd. He was running Red's in the front and Greys on the rear. He didn't say what oils or limiters but the shock mount locations matched mine.
I just loved running the truck on dirt though. If I can get more steering it would be dialed.
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 04-20-2015, 04:33 PM   #1414
thecman26's Avatar
Trader Rating: 99 (100%+)
Easy, just get a J Concepts T5M Finnisher body! They actually sell replacement spoilers! I've asked Proline and they say theres no interest...
So they want to make you buy the body!
Added benefit, they're $6!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 04-20-2015, 06:06 PM   #1415
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thumbs up
T5M PUCK System should be ready this Wednesday ...
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 04-20-2015, 08:06 PM   #1416
chonchachencho's Avatar
You're set up guru sent you in the wrong direction. The guy that tq'd probably had the same issues as you but then addef a stiff front spring. With the front end stiff you gain high speed steering and you lose slow speed steering. Vise versa.
chonchachencho is offline   Reply With Quote
Old 04-20-2015, 08:08 PM   #1417
Suspended
Trader Rating: 61 (100%+)
http://www.petitrc.com/reglages/Basi...ing/index.html
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-20-2015, 09:07 PM   #1418
HBRob's Avatar
Send a message via Skype™ to HBRob
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 04-20-2015, 10:48 PM   #1419
building... need titanium turnbuckles what ones to get?
iMarky is offline   Reply With Quote
Old 04-20-2015, 10:53 PM   #1420
jconcepts if you can find them
Micah123 is offline   Reply With Quote
Old 04-21-2015, 08:21 AM   #1421
To a certain extent I don't think it matters. Buy whatever is available. The JCs are good but Lunsfords are just as good. If AE has FT versions those will be the least expensive and have a nice blue sheen but will have the lowest quality.
Old 04-21-2015, 08:29 AM   #1422
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Im using ae ft b4.2's on my buggy and they've been flawless after many days of practice/racing.......Will the ae ft t4.2 links work on our new truck...I assume they will?
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 04-21-2015, 08:42 AM   #1423
Super Moderator
4 of the T4 links are 2.8"...the T5 calls for 6 2.6" links. I had my T4 links still and just took a little off each end with a dremel and they work fine.
Old 04-21-2015, 10:01 AM   #1424
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Other than style, they are identical. Lunsford makes JC's turnbuckles.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-21-2015, 10:03 AM   #1425
Super Moderator
Desperately needed! My T5m is more than 200grams over weight with a shorty, TI buckles, and Slipper elim. Need to shave more!
- RCSpecialties -
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
