Like Tree25Likes
Old 04-16-2015, 11:20 AM   #1381
I have the +4 mount with stock hexes right now it is really stable
Neverstop is offline   Reply With Quote
Old 04-16-2015, 11:33 AM   #1382
Trader Rating: 42 (100%+)
Originally Posted by vito View Post
i got the de racing speed line ones for a t4.2 ones is it the same wheel offset front to rear on the 5t
Yes
Bartman42 is offline   Reply With Quote
Old 04-16-2015, 11:51 AM   #1383
Cole Tollard Spring classic
https://www.youtube.com/watch?v=feS76OygnKk
His setup
http://www.teamassociated.com/pdf/ca...ng_Classic.pdf
Old 04-16-2015, 12:16 PM   #1384
aeRayls's Avatar
Originally Posted by Socket View Post
Their shipping cost is absurd though. IIRC it was $12 to ship 1 set.
Absurd would be to order only one package of anything online. Just have a shop or track order it then. Atleast the JC wheels come 2 pair per package.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 04-16-2015, 12:31 PM   #1385
Originally Posted by lbckevin View Post
I use the T4/B4 front bumper, its a direct fit.
http://www.amain.com/rc-cars/team-as...asc9562/p21077
You could also use the RPM version, part #RPM80232.
Associated B6D, HobbyWing XR10 Stock Spec, Schurr Speed 17.5, Sanwa MT-44, Savox 1258TG
Associated T5M, HobbyWing XR10 Stock Spec, Schuur Speed 17.5, Sanwa MT-44, Savox 1258TG
Associated B64D, HobbyWing XR10 Pro, Schuur Speed 13.5, Sanwa MT-44, Savox 1258TG
Cueball22 is offline   Reply With Quote
Old 04-16-2015, 01:31 PM   #1386
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Shipping 1 set of truck wheels from FL to CA...
USPS First Class: $2.68
USPS Priority Mail: $7.15
Seems pretty reasonable to me.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-16-2015, 01:41 PM   #1387
Suspended
Trader Rating: 61 (100%+)
You got me there - that's decent. I mixed up with one set of tires. Those are $15 for ups ground. Yes usps is cheaper, but I would like to actually get it as well.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-16-2015, 02:03 PM   #1388
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Free on ebay in most cases.....none of our lhs have any....ae doesnt even have yellow wheels in stock right now.....that's why I ordered online, one set Adam...lol :-)
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 04-16-2015, 02:12 PM   #1389
Haven't had a failure in USPS yet, and that's shipping things world wide lately. USPS stuff to me been perfect. USPS has taken twice as long. or wrong truck had my items cause people loading not paying attention. USPS i was still getting 2 day priority packages from Opposite side of US (nj to me in CA) in 2 days.
Bought my wheels on the BAy before truck release. was i think just under 15 shipped a little high. I know my local track has a ton of DE since the owner of DE stops in a lot. and don't think is to far away.
ALIEN3T is offline   Reply With Quote
Old 04-16-2015, 02:21 PM   #1390
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Bartman42 View Post
Someone should tell that turn marshal that some of us are trying to watch the race
HB D815v2 (Nova Mito4) / HB D8TTE (Nova Mito7)
HB E817 (Hobbywing XR8 and 1900kv motor)
Associated B6D (Orion and Schuur Speed)
SEF is offline   Reply With Quote
Old 04-16-2015, 03:40 PM   #1391
Originally Posted by Gigasipke View Post
Our outdoor season kicks off this Sunday. The track is medium to low grip, quite level though. It is watered between each round, so on the tone it starts slick goes to best grip after a few laps, then by the end it is dry. If you are in the groove it is medium grip, but if you fall out of the groove it is low to loose grip. Very dynamic changes minute to minute, hour to hour. The best grip is always early rounds of quals and by mains is the loosest conditions.
So are there any good setups available for Med to Low grip outdoor tracks? The 4 on the Associated site don't match, although the Thielke may be where I start but need to dial in traction. Any ideas?
I have been running similar to Thielke setup on outdoor, dusty, loose and bumpy australian track. I went with 2 rear limiters instead of 1 but used the 3 in the front. Works really well even on low grip, been running holeshots but they don't last long, went with suburbs which worked better, still plenty of grip but small window for error, if you get offline it's obviously slippery.
I'd start with that setup like I have done, if need more grip maybe keep the brass C block on hand. Use that a lot in buggy in Australian conditions
MattK101 is offline   Reply With Quote
Old 04-16-2015, 03:50 PM   #1392
Gigasipke's Avatar
I will give the limiters a try. The Double D's are the go to tire in Stadium track on this track, the cool thing is that tire wear is minimal. I however have a new set of super softs on order to maximize grip. I don't have the brass C block but will order one once I see how this setup works. Thanks,
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 04-16-2015, 04:31 PM   #1393
You probably won't need the C block, but it's good to have just in case. The truck out of the box had more grip than i expected.
Let us know how you go, will be good to see how it goes on another loose track.
It's easier to add more limiters than what you think you will need, you can test less limiters by just unscrewing the shock end a full turn.
Old 04-16-2015, 06:26 PM   #1394
I'll measure the wheel inside diameter and offset tonight and report back.
DE Speedline wheels measure 2.100" ID and from the bottom of the hex to the lip measures 1.395"
Old 04-16-2015, 09:32 PM   #1395
No 2.5/1 Arm Mount included in 91532. Anyone know what arm mount cole used? I currently have 3/1 installed.
Micah123 is offline   Reply With Quote
