Like Tree25Likes
Old 04-16-2015, 07:43 AM   #1366
Trader Rating: 42 (100%+)
Originally Posted by Neverstop View Post
Must be some difference between the de wheels and team associated ones with the exact same settings the ball cups hit the wheel.
I'll measure the wheel inside diameter and offset tonight and report back.
Bartman42 is offline   Reply With Quote
Old 04-16-2015, 08:10 AM   #1367
Jason Baliban's Avatar
Are you guys using any other wheels besides the AE ones? The AE ones are at the bottom of the sea, apparently.
Thanks!
jB
High Sundry Productions
B5M | MBX-7Re | T5M | TC3 | RC10 "Graphite"
Jason Baliban is offline   Reply With Quote
Old 04-16-2015, 08:30 AM   #1368
I'm running the stock AE wheels (PN 7852) and there is plenty of clearance for the hubs and ball cups. I don't have a set of 5mm hexes to try but I'm not seeing how they would cause a problem on my truck.
Are you sure your rear camber is set to something reasonable? I can kinda see where excessive negative camber "might" cause an issue with the narrow hexes.
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 04-16-2015, 08:36 AM   #1369
Anyone using the +4mm arm mount yet with the 7mm hex? Curious to see opinions, will be trying it on weekend. Also what is reason for new 7mm hexes for b5m/t5m if stock hex for b5m is 7mm anyway?
MattK101 is offline   Reply With Quote
Old 04-16-2015, 08:56 AM   #1370
My camber is -1
Neverstop is offline   Reply With Quote
Old 04-16-2015, 09:01 AM   #1371
Gigasipke's Avatar
Our outdoor season kicks off this Sunday. The track is medium to low grip, quite level though. It is watered between each round, so on the tone it starts slick goes to best grip after a few laps, then by the end it is dry. If you are in the groove it is medium grip, but if you fall out of the groove it is low to loose grip. Very dynamic changes minute to minute, hour to hour. The best grip is always early rounds of quals and by mains is the loosest conditions.
So are there any good setups available for Med to Low grip outdoor tracks? The 4 on the Associated site don't match, although the Thielke may be where I start but need to dial in traction. Any ideas?
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 04-16-2015, 09:01 AM   #1372
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
Thanks!
jB
I also use the JC wheels, they are fine.
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 04-16-2015, 09:06 AM   #1373
vito's Avatar
i got the de racing speed line ones for a t4.2 ones is it the same wheel offset front to rear on the 5t
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 04-16-2015, 09:07 AM   #1374
aeRayls's Avatar
The reason for the new 7mm hex is because of the new slightly larger diameter HD axles.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 04-16-2015, 09:43 AM   #1375
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
I found yellow ae wheels and AKA st inserts on ebay @ red rock hobbies...also found m4 ions @ Horizon in ebay.
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 04-16-2015, 09:44 AM   #1376
Thank you
jB
Old 04-16-2015, 09:45 AM   #1377
aeRayls's Avatar
White and yellow wheels have been instock at jconcepts.net forever now... Just sayin.
Old 04-16-2015, 10:25 AM   #1378
Suspended
Their shipping cost is absurd though. IIRC it was $12 to ship 1 set.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-16-2015, 10:26 AM   #1379
Originally Posted by Kraig View Post
The hand written copy of this sheet I have seen has the 3 gear box filled in.
Same with the one on ae website. Wanting to know if the setup will be good for a 4 gear tranny.
Micah123 is offline   Reply With Quote
Old 04-16-2015, 10:58 AM   #1380
Jpdanger's Avatar
Anyone else snapping ball studs? So, far, I've snapped two off. I'm using kit balls, cups, and turnbuckles.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Swcc94lude
