Like Tree30Likes
Old 04-07-2015, 03:26 PM   #1141
Gigasipke's Avatar
Originally Posted by air8 View Post
What does the truck do to cause you to want to raise ride height?
One of the features caused a bounce roll if I tried to turn before letting it settle. I did not have to do this with my T4.2. When I raised it a little, things got better. One other T5M was on the track and had a little more ride height and had no problem with the feature (we had the same shock setup). I could stiffen up the suspension more, but it was only this one spot. I may go up on the springs anyway since I just used the Thielke setup directly.
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 04-07-2015, 05:34 PM   #1142
303slowdown's Avatar
Trader Rating: 24 (100%+)
A guy at my track just got a t5m and his does the bounce land pretty bad. I tried raising his ride height and it made little difference . I thought about having him add a little weight to the back but not sure if that's the right move. Let us know if you get it fixed.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 04-07-2015, 06:22 PM   #1143
mjbtaco's Avatar
Got an accurate weight of the truck rtr. 1884g and 1762g with no body.
mjbtaco is offline   Reply With Quote
Old 04-07-2015, 06:33 PM   #1144
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
Assume this is a shorty, sounds about right, anything else?
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 04-07-2015, 06:40 PM   #1145
mjbtaco's Avatar
Shorty, 3 gear, schelle slipper, exotek motor plate, ti turnbuckles, and some plastic shaved off on the inside. Does have a bunch of the aluminum upgrades though so those add a little weight. Ae hubs, schelle/ae rear arm mounts, ae rear ball stud mount, ae front hinge pin brace.
Old 04-07-2015, 06:49 PM   #1146
Trader Rating: 485 (100%+)
Got my T5M built Friday and raced it Friday and Sunday. Its great, no issues. Unlike my normal routine, I built it box stock side from a gear diff and I don't have any immediate plans to do anything else. Its really good out of the box just like the B5 and B5M. If you ask me, the truck needs nothing. We run stadium truck as an unlimited class so weight is not an issue. I'm running a hobbywing v3.1 & D4 13.5 maxzilla. It was very stable and held the track very well. I'm super happy.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 04-07-2015, 07:01 PM   #1147
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Are the front wheels and rear wheels the same?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-07-2015, 07:05 PM   #1148
lbckevin's Avatar
Trader Rating: 91 (99%+)
Yes
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 04-07-2015, 07:08 PM   #1149
I used left over t4.2 wheels. They fit perfect.
Old 04-07-2015, 07:27 PM   #1150
1/4milecrazy's Avatar
Found a slightly strange issue, was wondering if anybody else has the same. At full lock in ether direction the wheels are rubbing the ball cups. I am using JConcepts Mono wheels. I could just turn the steering EPA down a bit but am trying to avoid that because I like a lot of steering.
Apparently "equal" and "partners" means different things to different people.
1/4milecrazy is offline   Reply With Quote
Old 04-07-2015, 08:23 PM   #1151
BaBaBaBen's Avatar
Just pulled the trigger on AMain. My first car was a T4 and now that I'm getting back into the hobby why not start with a T5m?!
BaBaBaBen is offline   Reply With Quote
Old 04-07-2015, 08:26 PM   #1152
Suspended
What trail is the front end set to?
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-07-2015, 08:56 PM   #1153
Trader Rating: 42 (100%+)
This thing handles like a dream!! Your going to love it.. I put the Thielke setup on mine and didn't touch anything except turning the motor up. Running on a large indoor (23 seconds ave lap) med/high bite..
Bartman42 is offline   Reply With Quote
Old 04-07-2015, 09:38 PM   #1154
Kit setting.
Old 04-07-2015, 09:53 PM   #1155
xyzracer's Avatar
don't know for sure cause I don't have one yet but I heard if the cups are on upside down they will rub the wheel. couple others have reported rubbing as well so I would assume that's the problem.
xyzracer is offline   Reply With Quote
