Like Tree24Likes
Old 04-01-2015, 10:57 AM   #961
Default How's the arms and fit in finish of the parts
Originally Posted by ridgerunner1 View Post
Got my T5M all done i went ahead and just built it inline like my buggy since it works so well i figured i may as well run this the same way, it all went together great and all the parts were there...lol anyway here are a couple pictures, you don't have to cut into the waterfall there is enough room for the ECS i am going to start with the battery back ESC forward and see what happens we will see this Friday.
how's the fit and finish of the plastic parts tight or did you have to use washers to take up slack
StanTheManRC is offline   Reply With Quote
Old 04-01-2015, 12:02 PM   #962
Suspended
Trader Rating: 61 (100%+)
Originally Posted by StanTheManRC View Post
What brand would you recommend! Not sure if CRC makes them but really like there 64pitch
TLR pinions are VERY hard to beat.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-01-2015, 12:12 PM   #963
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
+1 some of mine are a year old and show no wear.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-01-2015, 01:57 PM   #964
ridgerunner1's Avatar
Trader Rating: 21 (100%+)
The fit is good they included washers for the slop in the rear arms not like my B5M were in had to shim it my self.
Mike Craig
A&E B5M - Viper ESC
New Home Track Tacoma TRCR http://www.tacomarc.com
RIP Beremerton RC race way
ridgerunner1 is offline   Reply With Quote
Old 04-01-2015, 02:26 PM   #965
AE-Reedy
The shims on the rear arm are for an additional WB adjustment.
Sean Cochran is offline   Reply With Quote
Old 04-01-2015, 02:35 PM   #966
air8's Avatar
I use the Losi pinions also but just cause the LHS has them. Like Wildcat said, i have several that are years old and down to just one year old. They last long time if you keep dirt and stripped spur gear dust to a minimum.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 04-01-2015, 02:37 PM   #967
What do you think on durability ?any parts I need to get as extras
Old 04-01-2015, 02:38 PM   #968
Default Sounds good will buy the tlr
Old 04-01-2015, 02:57 PM   #969
AE-Reedy
Only thing I saw broke at Cactus was 1 front arm and 1 rear arm, but they were serious hits.
Kit parts are more durable than the hard ones.
Old 04-01-2015, 03:04 PM   #970
3srcracing's Avatar
Trader Rating: 25 (100%+)
Hoping someone local will have one of these put together to try. Want to see if it's better then the RT6.. That RT6 is pretty dialed just heavy!
3srcracing is offline   Reply With Quote
Old 04-01-2015, 09:48 PM   #971
Originally Posted by Wildcat1971 View Post
how are you guys liking the updated ball cups?
I don't know about anyone that's built theirs but I just finished my kit and the damn ball cups bind up just like they did on my B5M. I thought this was fixed in the T5M.
flintTRDTC is offline   Reply With Quote
Old 04-01-2015, 10:19 PM   #972
air8's Avatar
It's not too bad to set the ball cups. Just put a ball stud in and pinch them with pliers of some sort. When you pinch the sides the ball cup will oval slightly. Let loose with the pliers and the ball cup will go back to shape...only looser. Do that once or twice, maybe a third time and perfect.
--"U Ain't Fast!!"
Chris Pearce
Old 04-01-2015, 10:30 PM   #973
Jpdanger's Avatar
I never had ball cup issues on my B5M, but every cup on my T5M was tighter than a _____ on ______ night.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 04-01-2015, 11:31 PM   #974
Anybody else notice the length for the front camber turnbuckle in the manual seems to be way too short or is it just me?
Edit: nevermind just realized my calipers kept zeroing themselves and throwing me off.
handyalbert11 is offline   Reply With Quote
Old 04-02-2015, 12:38 AM   #975
Dstreelm's Avatar
Front camber was fine, or at least close...the rear camber links in the kit setup were WAYYYYY off...following the kit resulted in like -5 degrees of camber. I used the kit hole locations and adjusted the turnbuckles for -1 rear camber
Dstreelm is offline   Reply With Quote
