Like Tree24Likes
Old 03-05-2015, 01:18 PM   #631
mes
Originally Posted by jpcopeland1 View Post
Why they even bother with the one piece front axle still mesmerizes me. Such a bad design.....
Why?! I bought a simaliar axle as an option part for my Firebolt, and I like it much better than the original version with the plastic hex. You can tighten your wheel nut without having bearing issues. The B4 generation AE hex wheel front axles with the c-clip were really bad, thank goodness JConcepts came out with their version.
mes is offline   Reply With Quote
Old 03-05-2015, 03:50 PM   #632
mangler64's Avatar
I don't care what it has on it .. I just want it in my grubby little hands !!!! LOL!!
Misdelivered Racing
SC5M, B5M FL, T5M
mangler64 is offline   Reply With Quote
Old 03-05-2015, 04:10 PM   #633
AGREED, have parts waiting for it.
ALIEN3T is offline   Reply With Quote
Old 03-05-2015, 04:21 PM   #634
+2 trying to locate the 8.5mm hexes for it when it arrives.
Kyosho: 2x-RB6.6, ZX6.6, RT6, SC6
HW XR-StockSpec x4
Sanwa MT4S
wrutherf is offline   Reply With Quote
Old 03-05-2015, 09:18 PM   #635
slashdad's Avatar
Trader Rating: 33 (100%+)
Originally Posted by mes View Post
8.5mm are the correct ones in the rear. 4 and 5 mm are possibly tuning options when using the separate front axles, i.e. not the kit one-piece steel axles.
Are you referring to wheel hexes? (confused)
Can you guys clarify if I can run my present t4.2 hexed rears wheels on the t5m? Assuming that they are still 12mm hexes?
B5M, T5M, B44.2, B4.2, DEX210v2, SC10B, Xray T3 2012.
Savox : Spektrum : Proline : JConcepts : Turnigy : Trackstar Gen II's
Knox OFF Road RCC member, waiting for toddler to grow up...
Please explain roll centres to me one more time...
slashdad is offline   Reply With Quote
Old 03-05-2015, 10:14 PM   #636
Yes, the t4 hexes are 12mm, but the center hole is 3/16. The t5 axle is 5mm.
Cautrell05 is offline   Reply With Quote
Old 03-06-2015, 01:07 AM   #637
mes
12mm is the diameter of the hex, 8.5/5/4mm is just the width. Yes, T4.2 wheels will fit.
Old 03-06-2015, 02:58 AM   #638
slashdad's Avatar
That clears that up.
Now. Talk of slipper upgrades from the stock AE version supplied:
What are the options? Amain links or codes please, gents.
Old 03-06-2015, 03:01 AM   #639
slashdad's Avatar
PS. Thanks to all for your clear responses to my queries.
Right, onto the slipper upgrade and the relative merits of each and WHY?
Old 03-06-2015, 03:37 AM   #640
mes
Originally Posted by Chris Gierse View Post
Get the Avid or Schelle and be done with it.
Easy to install and adjust, very tunable by mixing red and white slipper pads, does not heat up like the VTS. I prefer the Triad Evolution over the Schelle Nova as you don't need the conical washers. If you want to use them, they are still included
http://www.amain.com/avid-rc-mod-tri...1t-84t/p241375
for modified or
http://www.amain.com/avid-rc-stock-t...2t-76t/p241376
for stock.
Old 03-06-2015, 07:23 AM   #641
mangler64's Avatar
for modified or
for stock.
+1 on this.
Misdelivered Racing
SC5M, B5M FL, T5M
Old 03-06-2015, 07:40 AM   #642
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
for modified or
for stock.
Yes, I dont like the conical washers either. They always want to escape from my pit bench. less small parts is better.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-06-2015, 11:24 AM   #643
slashdad's Avatar
Thanks for the feedback.
I run mod class, outdoor clay 27 sec med grip track.
What else will I 'need'?
Turnbuckles, tick.
D block, tick.
Old 03-06-2015, 12:50 PM   #644
Turnbuckles, tick.
D block, tick.
order wheels seams no one has any in stock. even associated was all of the suddne out. (same as 2.65 turnbuckles)
Old 03-06-2015, 01:07 PM   #645
aeRayls's Avatar
Jconcepts has wheels. I just ordered this week.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
