Like Tree30Likes
Old 02-18-2015, 11:50 AM   #541
Originally Posted by dbowen View Post
Ya it does that is the whole reason they went to the 4 gear in the first place so that the motor rotation went the same way as the tires to generate more on power traction from the torque of the motor rotation. I do not mean the the car goes in reverse when you hit the throttle I mean the motor spins the opposite way as compared to the four gear.
The AE 3 gear tranny motorplate is mounted on the opposite side of the buggy than a 4 gear mm tranny. Motor rotation is the same as 3 gear rm and 4 gear mm the motor rotates the same direction as the wheels.
rctinman is offline   Reply With Quote
Old 02-18-2015, 12:10 PM   #542
dbowen's Avatar
I am sorry I don't quite understand what you are saying are you saying that the motor rotates the same as the wheels in the 3 gear? Because if so that is incorrect it does not rotate the same direction as the tires in the 3 gear. It does in the 4 gear which is the whole reason why they added another idler gear or the car would go in reverse when you hit the gas.
Again I recommend anyone who doesn't understand or disagrees with what I am saying to read this article:
http://www.petitrc.com/setup/durango...gurationGuide/
B5M Fantom IonV5 Short Stack 17.5 Hobbywing 3.1 Stock Spec Fantom Batteries
T5M Fantom Ion V5 9.5 Hobbywing ESC Fantom Batteries
Proud To Represent: Fantom Racing - Schelle Racing - FastTraxx Hobbies
dbowen is offline   Reply With Quote
Old 02-18-2015, 01:00 PM   #543
I understand how mm works its been around since the 80s. Yes i am saying the motor and wheels spin the same direction on the AE 3 gear mm.
The durrango 3 gear mm is a different set up the motor spins the opposite direction of the wheels because it uses a 3 gear motorplate and gearbox.
AE has flipped the motorplate so it mounts on the other side of the gearbox so you dont need a extra idler gear and the motor spins the same direction as the wheels.
Look at pics of what side the motorplates are mounted on the b5m and b5m lite.
Old 02-18-2015, 01:26 PM   #544
Aaron P's Avatar
The rotor does NOT rotate the same direction as the wheels in the ae 3 gear MM.
It's the same as a RM, only the motor is in front of the gearbox.
Aaron P is offline   Reply With Quote
Old 02-18-2015, 01:47 PM   #545
Trader Rating: 14 (100%+)
Not sure why you think it is different than the Rango. Trust me i have the 3 gear in my car and it is the same as the illustration in the link of the 3 gear MM.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 02-18-2015, 01:50 PM   #546
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
haha, people just drive The 3 gear takes away rear bite on power. I like it in my B5M for high bite 17.5 racing. The ST has HUGE tires. I suspect the effect will be lessened in ST. In any case, 3 gear is something to try when you have rear grip to spare.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-18-2015, 01:53 PM   #547
jmcelroy42's Avatar
I made a little diagram showing the directions of the gears.
Motor and wheels spin in opposite directions on 3 gear RM & MM
Motor and wheels spin same direction on 4 gear MM
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 02-18-2015, 02:28 PM   #548
Jmuck69's Avatar
Oh dear lord not this again....
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 02-18-2015, 02:44 PM   #549
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Anyone know why my ball cups are tight? Is that better?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-18-2015, 03:11 PM   #550
Jmuck69's Avatar
NOOOOOOOOOOO!!!!!! Why does the movie Groundhog Day come to mind...?
B6D | B64D
Old 02-18-2015, 04:12 PM   #551
Lord forgive me for opening my mouth...
Here goes, with the three options that associated gives you, rear motor 3 gear, mid motor 4 gear, and mid motor 3 gear, the motor itself never reverses rotation. It always spins the same direction in regards to the shaft and the can.
Rear motor 3 gear, and mid motor 3 gear, both have the pinion and spur on the right hand side, with the pinion shaft rotating opposite direction of the tires.
Mid motor 4 gear, has the pinion and spur on the left hand side with the pinion shaft rotating in the same direction as the tires.
The shaft always spins the same direction inside the motor itself. I do not understand why this is so hard for everybody to follow along with it.
Cautrell05 is offline   Reply With Quote
Old 02-18-2015, 04:15 PM   #552
staab08's Avatar
It's really not hard to follow along with. I understand that some people just really aren't very mechanically minded. But you would also thing that anyone racing R/C cars would have a little mechanical knowledge.
*John Staab* Russell,KS
staab08 is offline   Reply With Quote
Old 02-18-2015, 04:37 PM   #553
Flyintaco138's Avatar
Trader Rating: 9 (91%+)
Originally Posted by Socket View Post
Did he buy every part separately to make a kit?
Flyintaco138 is offline   Reply With Quote
Old 02-18-2015, 04:55 PM   #554
Super Moderator
Kraig's Avatar
Sponsored drivers kits come without a box.
Old 02-18-2015, 04:56 PM   #555
Jmuck69's Avatar
3 gear - high traction (carpet, sugared tracks, black groove)
4 gear - everything else.
that's all you need to know. No need to overly complicated and study the nuances of 3 vs. 4 gear. Honestly, 4 gear will work on all surfaces.
B6D | B64D
