Like Tree24Likes
Old 02-17-2015, 12:55 PM   #526
Originally Posted by rctinman View Post
The AE three gear tranny does not reverse motor rotation.
It does and it doesn't. It does not reverse the motor rotation in the sense that you need to reverse the rotation in your ESC or change motor phasing. It does in the sense that the motor is rotating opposite in relation to the car direction.
otter is offline   Reply With Quote
Old 02-17-2015, 01:17 PM   #527
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by JDM_DOHC_SiR View Post
Little bit more data on the +4mm D mount
• Used for B5M/T5M
• Makes rear pivot 4mm wider (requires flipping insert in D plate)
• Gives improved stability
• Recommended to use with #91609
yeah, there was something about the HD axles changing the width also. I dont understand all of these changes and why. what are they fixing on the car? Is all of this just to use the HD axles?
#91608
• Used for B5M/T5M
• Makes rear pivot 4mm wider. (requires flipping insert in D plate)
#91609
• Used for B5M/T5M
• Requires HD rear axle (71019)
• Reduces vehicle width by 4mm from stock width
• Recommended to use with #91608
Part #: 71019
Heavy Duty CVA Axle
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-17-2015, 01:26 PM   #528
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
I dont think that the HD axles are changing the width of the car...but you have to use the AE 7.0mm offset hexes with the HD axles due to the increased diameter of the HD axles (this is on the B5m).
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 02-17-2015, 01:35 PM   #529
Matt, so what do you think the net gain is?
Old 02-17-2015, 01:42 PM   #530
Super Moderator
I've never really messed around with the wide pivot vs std pivot. It was a kyosho thing that was used with the Rb5/6 series.
Old 02-17-2015, 01:45 PM   #531
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Questions?? Same Bearing
The bearing size is the same 6x13x5.. B5M/B5M Lite... and possible the same for the T5M since the axle is the same..
Maybe the HD axles are heat treated....??
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-17-2015, 01:49 PM   #532
Super Moderator
You can see that they taper down after the bearing. I dont believe that the HD axles taper down until the thread.
Old 02-17-2015, 01:55 PM   #533
Looks like that step is gone on the HD Axle...hmmm.
B5/B5m Axle
B5m Lite/T5m Axle
Old 02-17-2015, 01:57 PM   #534
Super Moderator
They look thicker as they go out to the thread compared to the old
Old 02-17-2015, 02:32 PM   #535
Trader Rating: 137 (100%+)
Shiney....
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 02-17-2015, 03:18 PM   #536
Suspended
Trader Rating: 61 (100%+)
Won't matter much to me about the axles. I've had great luck with the Ti units.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 02-17-2015, 07:00 PM   #537
Suspended
Old 02-17-2015, 07:25 PM   #538
Old 02-17-2015, 07:35 PM   #539
Originally Posted by Socket View Post
what are we looking at?
Old 02-17-2015, 07:39 PM   #540
Tanner Denney's T5M ... it the non box form
