Like Tree24Likes
Old 02-16-2015, 01:24 PM   #511
Trader Rating: 89 (100%+)
Thx Aerayls....BTW like the "better off dead quote" in your Sig...
dan-o is offline   Reply With Quote
Old 02-16-2015, 05:38 PM   #512
aeRayls's Avatar
Thanks, I figure it's the simplest break down of all racing
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 02-16-2015, 05:47 PM   #513
Trader Rating: 14 (100%+)
Yeah its good.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 02-16-2015, 06:32 PM   #514
"I want my two dollars" kinda sums it up as well. haha
Mike Ryan is offline   Reply With Quote
Old 02-16-2015, 10:01 PM   #515
Suspended
Trader Rating: 61 (100%+)
My truck weighed in at 1800 RTR.
A friends centro came in much heavier, and after reduction, is still in the 1830 range.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 02-17-2015, 01:30 AM   #516
Flyintaco138's Avatar
Trader Rating: 9 (91%+)
Pre-ordered my truck today can't wait
Flyintaco138 is offline   Reply With Quote
Old 02-17-2015, 07:37 AM   #517
Originally Posted by wiringnatzi View Post
The truck I made before the T5M was actually released is 1905 grams complete with square battery.
It is basically a B5M kit with the following T4parts: front and rear arms with hubs, front shock tower, and front shocks.
It has 3 gear tranny with aluminum top shaft and pucks.
Just an FYI, when I was racing the T4.2 it was 1765 grams (used a shortie)...
Now my hybrid T5M is 1905 grams (with square to get more traction).
Battery weights: shortie is 220 grams and square is 296 grams (76 gram difference).
Using all the same electronics, but added a fan to keep the motor cool in mid motor configuration to run the same gearing.
wiringnatzi is offline   Reply With Quote
Old 02-17-2015, 10:39 AM   #518
Trader Rating: 478 (100%+)
I'm going to ask the dumbest question ever...anybody know if the T5M will come with a 3 gear transmission? If not, why?
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 02-17-2015, 10:42 AM   #519
Rather than changing my post I'm going to answer my own question....I looked and it comes with the 4 gear and an aluminum top shaft. If the 3 gear is so much better why wouldn't they include it? Don't answer that question.....I know they need to make money.
Old 02-17-2015, 11:16 AM   #520
dbowen's Avatar
The 3 gear is really only better for high bite tracks because it reverses the rotation of the motor to pitch the car forward on power vs towards the rear thus creating on power traction, so the 3 gear takes away on power traction and the car stays flatter in the corner; and for stock where there is one less idler gear and less rotating mass and stock doesn't have enough torque to really notice the loss of on power traction and a lot of times you want to free up a stock car which is why it is better.
The 4 gear will still be way better in mod for medium to low bite tracks and therefore most tracks around.
B5M Fantom IonV5 Short Stack 17.5 Hobbywing 3.1 Stock Spec Fantom Batteries
T5M Fantom Ion V5 9.5 Hobbywing ESC Fantom Batteries
Proud To Represent: Fantom Racing - Schelle Racing - FastTraxx Hobbies
dbowen is offline   Reply With Quote
Old 02-17-2015, 12:11 PM   #521
The AE three gear tranny does not reverse motor rotation.
rctinman is offline   Reply With Quote
Old 02-17-2015, 12:13 PM   #522
dbowen's Avatar
Ya it does that is the whole reason they went to the 4 gear in the first place so that the motor rotation went the same way as the tires to generate more on power traction from the torque of the motor rotation. I do not mean the the car goes in reverse when you hit the throttle I mean the motor spins the opposite way as compared to the four gear.
Old 02-17-2015, 12:20 PM   #523
dbowen's Avatar
Here is a good article to read up on that explains the difference between a MM 3 gear and MM 4 gear
http://www.petitrc.com/setup/durango...gurationGuide/
Old 02-17-2015, 12:23 PM   #524
Trader Rating: 137 (100%+)
Trucks are too heavy for normal stock. Should only run then in 13.5 super stock and mod...
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 02-17-2015, 12:34 PM   #525
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Little bit more data on the +4mm D mount
• Used for B5M/T5M
• Makes rear pivot 4mm wider (requires flipping insert in D plate)
• Gives improved stability
• Recommended to use with #91609
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
