Like Tree33Likes
Old 02-12-2015, 07:19 PM   #466
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by JDM_DOHC_SiR View Post
I'm thinking it would sit in the place of the "C" mount but be 4mm shorter..??
lol, what?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-12-2015, 07:24 PM   #467
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
OK... lets see if I can explain it a little bit better...
Notice the shorter arm on the right and the C mount sits in front of it right.... well ...maybe ( and it's a big MAYBE ) they added the 4mm to the C mount to remove the normal gap.... best guess
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-12-2015, 08:07 PM   #468
Suspended
Trader Rating: 61 (100%+)
As seen here:
I used an alloy spacer, and yes, you can adjust the wheel base.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 02-12-2015, 08:46 PM   #469
tsair's Avatar
Originally Posted by Wildcat1971 View Post
I hear the FT Lite version is a year out
I know you guys are (sorta?) kidding, but how likely do you think it is that they'd come out with a lightweight chassis version? I can't quite tell if the T5M chassis is already fairly milled or not.
I have enough money next month to either buy a B5M lite, or a T5M. I'd rather buy my first ST (already got a spare set of electronics for it), but if it's likely they are likely to change the chassis, etc., I'd rather buy the B5M lite and play with that for a while.
I'm pretty new to the hobby, so don't know the history of AE putting out various Factory versions or whatever every year...
tsair is offline   Reply With Quote
Old 02-12-2015, 08:49 PM   #470
Cridd's Avatar
Trader Rating: 16 (100%+)
what is the weight difference between the t5m and t4.2 in stock finish?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 02-12-2015, 08:51 PM   #471
Suspended
I can weigh my "T5M", it shares now 100% of it's build with a true T5M.
However, I won't pull my electronics to do it. I would just assume the T5M is much much heavier.
Old 02-12-2015, 08:58 PM   #472
Default The heavy pig
You would have to think that the T5M is going to be one heavy ass pig of a truck since the B5m isn't really a paperweight in stock form
Fully loaded T5m... best guess 1800grams plus or minus 30grams
Old 02-12-2015, 09:03 PM   #473
Cridd's Avatar
I will weight my t4.2 tomorrow.
Chris
B6D / T5M / SC5M
Old 02-12-2015, 09:05 PM   #474
Cridd's Avatar
what is the lowest weight limit in stock truck class?
Chris
B6D / T5M / SC5M
Old 02-12-2015, 09:06 PM   #475
Would be interesting to see what a CT4.2 Centro comes in at as well
Old 02-12-2015, 09:08 PM   #476
Cridd's Avatar
My centro was a heavy bastard with pucks it was over 1600, I think around 1625. truck centro has to be a monster truck.
Chris
B6D / T5M / SC5M
Old 02-12-2015, 09:12 PM   #477
I'll put mine on a scale this weekend
Old 02-12-2015, 10:57 PM   #478
ISH
ISH's Avatar
I'm thinking that 13.5 is going to be the most popular class for this truck, correct?
that being the case would a slipper eliminator be ok for 13.5?
MBX7R nitro
Hot Bodies D413
B5M-FL
T5M
Team Orion, Nova Rossi, SMC, MIP, Airtronics, KO-PROPO.
ISH is offline   Reply With Quote
Old 02-13-2015, 04:23 AM   #479
Trader Rating: 90 (100%+)
Looks like my centro for the next month in a half....... Amain says March 27th arrival
dan-o is offline   Reply With Quote
Old 02-13-2015, 07:15 AM   #480
Suspended
That's a lot of heavy speculation. I would assume ST will take over what SCT has been doing, which is 17.5 and modified.
I can not fathom any situation beyond smooth carpet where a slipper eliminator is actually "standable". On dirt, the drivetrain gets shocked a lot with bumps and landings, and it's very hard on the transmission. I'd rather have a slipper with cut gears, than an eliminator with regular gears.
