Like Tree30Likes
Old 02-11-2015, 04:29 PM   #451
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Hmmmm T4 axles
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-11-2015, 04:46 PM   #452
Also the Standard B5/B5M axles are the same size as the new 71019 HD axles.. so let me know if I'm getting closer
Now for the front... the RB6 for SC6 front axle should work with a 3~4mm spacer if that..
Old 02-11-2015, 05:03 PM   #453
Suspended
Trader Rating: 61 (100%+)
Don't mind the front hex, I drilled it to 5.5mm, not 5.0. My fault. Need to go pickup a new drill bit here in a bit.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 02-11-2015, 05:16 PM   #454
Rear looks legit... .... But the Front looks like that axle is way too long..
Now that I think about it.. I think a Losi 22sct front axle and hex should work on the front... or at least the axle...
Should be around this length ..no..??
Last edited by JDM_DOHC_SiR; 02-11-2015 at 05:23 PM. Reason: Added picture for reference
Old 02-11-2015, 06:41 PM   #455
Suspended
Nothing wrong with the length. Just will have a few extra threads hanging out inside the wheel. I'm really excited for the durability. SRS has a huge quad that is a little hard to clear, but I like to send it. I DNF'd both qualifiers because I was snapping the castor blocks. I took it easy in the main and got the win in Modified stadium truck.
Old 02-11-2015, 07:18 PM   #456
Nice... so the B4/T4 parts were giving you trouble.... looks like you will have a Tank on your hands now...... so do plan on putting your car on a Scale to see how much it weights in at.??
Old 02-11-2015, 07:19 PM   #457
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I hear the FT Lite version is a year out
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-11-2015, 07:28 PM   #458
Suspended
No. Because I'll never be concerned with weight in modified. I am running a shorty right now, and looking like I should consider a square pack.
I was obliterating T4.2 parts in really odd spots. I think the T5M arms added more rigidity over the arms that were on it, and this caused them to be the breaking point. Now with the new metric stuff, I'll be just fine.
Old 02-11-2015, 07:59 PM   #459
Cool.... please let us know when you have some sort of set up starting point... if and when you have time.... Even though the rest of us have to wait another month... ..
Old 02-11-2015, 08:00 PM   #460
Old 02-12-2015, 12:16 PM   #461
AlanHall's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
I am not. I have a custom built chassis that is 10mm longer to match the T5m chassis.
Everything bolted up for available T5M parts, rear arms did require a 1mm spacer on the inner hinge pin mount.
The part that is killing me is not having the t5m front axles.
Sweet. I need one about 50mm longer lol
Alan Hall
AlanHall is offline   Reply With Quote
Old 02-12-2015, 05:30 PM   #462
Looks like Associated listed 2 new parts on there site today for the T5M
91609 CLAMPING WHEEL HEX [5.0mm]
91608 ALUMINUM ARM MOUNT +4mm [C], B << Might be the reason the rear arms are about 3~4mm narrower than the B5 ones... might be a tuning option for wheel base adjustments
Old 02-12-2015, 05:53 PM   #463
pumpkinfish's Avatar
On an indoor clay track (med size, bumpy and tacky for most of the day) will the truck be better with a 6.5 or 8.5 motor?
pumpkinfish is offline   Reply With Quote
Old 02-12-2015, 05:59 PM   #464
+4mm c-mount? wtf is that
Old 02-12-2015, 06:06 PM   #465
Questions??
I'm thinking it would sit in the place of the "C" mount but be 4mm shorter..??
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
