Like Tree25Likes
Old 08-05-2017, 12:06 PM   #3751
So question there is a lot of talk about using b6 to make a t6 and taking a t5 and put a b6 rear setup in it...what is the better option money aside, I need to make a decision soon because I got a race in 3 weeks and need to make a decide on a route I'm going to build
Medium to high traction clay
bLamey470 is offline   Reply With Quote
Old 08-05-2017, 04:05 PM   #3752
E-Mann's Avatar
Trader Rating: 24 (100%+)
Money aside B6 to T6 is the best option. Money dependent T5 with B6 laydown and new rear tower will be cheaper. Converting the B6 gives you all the benefits of the updated B6 front steering, caster blocks, axel height adjustment, adjustable Ackerman plates, optional chassis weights for best balance and with some modification using the B6 front sway bar kit.
T6 / B6 / B64 / B64D / XRAY XB4
Maclan / Savox / Airtronics
E-Mann is offline   Reply With Quote
Old 08-08-2017, 10:27 AM   #3753
rgrg2's Avatar
Trader Rating: 41 (100%+)
Default Gearing
I'm searching for the best gearing for a Reedy M3 8.0, and a Hobbywing V10 G2 10.5 with a Reedy 510r speedo and Tekin RS on the T5M. It's for a medium/large clay track, medium/ high traction.
Associated B6D B6 MT4S Jconcepts Reedy Schurr Speed Hobbywing Tekin
rgrg2 is offline   Reply With Quote
Old 08-08-2017, 10:35 AM   #3754
Do you know anyone else that makes the towers other than vision racing they're on back order right now
Old 08-10-2017, 08:46 AM   #3755
E-Mann's Avatar
Not that I am aware of. May want to shoot them an email and see when the next batch will be available.
Old 08-10-2017, 08:51 AM   #3756
Start with 22/78 for the 10.5 and 20/84 for the 8.0, that's what the manual recommends
roysays is offline   Reply With Quote
Old 08-10-2017, 11:25 AM   #3757
rgrg2's Avatar
Thank you!!
Old 08-11-2017, 06:50 AM   #3758
Trader Rating: 17 (100%+)
Looks like Cavalieri is running a plain old T5m this weekend at Roar Nats
Big_Show likes this.
Associated TC7.1
Associated B6 x2
Associated T5M
Tekno EB48SL
Scott R is offline   Reply With Quote
Old 08-17-2017, 04:03 PM   #3759
CrawJac's Avatar
Hello all, my track is talking about starting a 17.5 stadium truck class. I have a spare B5M and I know it shares a lot of parts with the T5M. I'd need it to be within the ROAR specs once completed.
I've looked around and have seen where it looks possible, but I can't find the details. Is there a conversion kit and/or write up on the process?
Blue Heron Racing homepage -> www.BlueHeronRC.com
Our track homepage -> www.PhilHurdRC.com
CrawJac is offline   Reply With Quote
Old 08-17-2017, 04:23 PM   #3760
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Chassis, body mounts, arms, front shocks, front axles, rear hexes, turnbuckles... it really starts to get cost prohibitive. But I have an old chassis if you give it a go. $25 shipped.
CrawJac likes this.
Jon Carlson is offline   Reply With Quote
Old 08-18-2017, 05:49 AM   #3761
Trader Rating: 26 (100%+)
You forgot shock towers, chassis cradle. cvd's, the rear shocks are longer to,
its not worth converting, they really dont share that much in the grand scheme. All the expensive stuff like chassis, shocks, cvds, are all different. Its just cheap stuff like hubs and knuckles that are the same, you would be better off selling the b5m and buying a t5m roller,
CrawJac likes this.
bobf24 is offline   Reply With Quote
Old 08-18-2017, 10:11 AM   #3762
jabroni racing's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to jabroni racing
if anyone is looking for some tires, I have for sale. Hard to find losi red compound taper pins.
New 1/10 Stdium Track Tires
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 09-03-2017, 06:39 PM   #3763
Originally Posted by BruceR. View Post
Curious why the need for the Lunsford axles? Wouldn't the normal T5M axles work? I was looking at ROAR specs and all I saw was a maximum width measurement. Or are the longer axles so the rim will clear the turnbuckle mounts? Either way, I already have a T5M donor for most of the parts so my price is about 1/3 of the listed. Sweet.
The B6 steering block is a little wider than the T5 steering block so you need to make a spacer to make up the length to use the T5 axle, so you need to basically extend the length of the T5 axle with the spacer to make it long enough.
I put the B6 Front steering/caster block and rear axle carriers on the T5.
I race on astroturf so being able to raise the axle height to keep the arms straighter when lowering the ride height is a big advantage.
I raced it the last two weeks and it worked great
Old 09-03-2017, 06:48 PM   #3764
Is anyone out there making a T6 Chassis? I have a B6 with all of the other stuff converted except the Chassis! I think that the extra 10mm or so would make a big difference!
Turtle Speed is offline   Reply With Quote
Old 09-04-2017, 10:11 AM   #3765
Kremzeek's Avatar
Looks like Exotek is.
https://www.facebook.com/exotekracin...75693309260103
Kremzeek is offline   Reply With Quote
