Like Tree25Likes
Old 12-17-2016, 01:21 PM   #3451
jonski's Avatar
Trader Rating: 237 (99%+)
Anyone have an extra manual that you want to get rid of? I just picked up a used T5M and didn't get a manual. I am OCD about having the manual in my toolbox.
jonski is offline   Reply With Quote
Old 12-17-2016, 01:34 PM   #3452
LOW ET's Avatar
Trader Rating: 96 (100%+)
https://www.teamassociated.com/cars_...anuals_setups/
look under instruction manual and click print
LOW ET is offline   Reply With Quote
Old 12-17-2016, 01:37 PM   #3453
aracefan's Avatar
Trader Rating: 40 (100%+)
Hey jonski, I hear'ya, I'm the same way. Why not just print one out though?
Here is the T5M Team manual
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is online now   Reply With Quote
Old 12-17-2016, 02:01 PM   #3454
jonski's Avatar
I thought about printing one, but nothing beats the real one.😀
Old 12-17-2016, 02:17 PM   #3455
But.. it's the same. Just put it in a little folder.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 12-17-2016, 02:22 PM   #3456
aracefan's Avatar
I'm at work, but I'll look for mine tonight (should be in the box or workbench drawer) and if I have it - I'll send it to you. I can print one out here at work and staple it together. . . I'll let you know later today.
Old 12-17-2016, 02:36 PM   #3457
jonski's Avatar
Thanks, I'll pay for the shipping
Old 12-17-2016, 05:12 PM   #3458
aracefan's Avatar
Default Here'ya go
Look what I found?!
It does have a slight crease down the middle longways, but otherwise good shape. You can have it if it's that important to you.
PM your address and I'll try and get it out Monday.
Old 12-17-2016, 05:41 PM   #3459
jonski's Avatar
Look what I found?!
You are the best!!!
Old 12-18-2016, 04:50 PM   #3460
ptracer13's Avatar
Found one, thanks guys.
ptracer13 is offline   Reply With Quote
Old 12-18-2016, 09:16 PM   #3461
71schaeffer's Avatar
Trader Rating: 8 (90%+)
Guys i have a quick question, with this truck if it need some sidebite going through a shicane what do i do? If i add a ballstud shim to the rear i have found that the car acts a little lazy. Im basically using kit setup besides a yellow buggy spring in front and white kit buggy spring in rear. Also i engineered a b6d battery strap to work because why not lol
71schaeffer is offline   Reply With Quote
Old 12-20-2016, 08:42 AM   #3462
Hey guys just picked up a T5M, Curious as to whats a good starting setup for an astroturf track? Haven't run it before and wanna make sure i have whatever i need. Will be running 17.5 if it makes a difference!
13dibttgt is offline   Reply With Quote
Old 12-20-2016, 09:31 AM   #3463
jabroni racing's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to jabroni racing
personally, I always try the kit set-up on any surface, find out what tire works, try the kit set-up & adjust from there, if you change it all up you can wind up chasing set-ups constantly..
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 12-20-2016, 05:55 PM   #3464
Hey all, having a little set up dilemma. I run almost exclusively on carpet. But I don't like the way the truck sits with 19mm f/18mm r ride height. If a clay track setup for very high grip calls for a higher ride height, why wouldn't that also work for carpet? I mean, I think the steering geometry won't be right with a too low ride height. Am I right, or smoking bad weed?I'm thinking somewhere in the 20's at least.
BruceR. is offline   Reply With Quote
Old 12-21-2016, 08:51 PM   #3465
Trader Rating: 18 (100%+)
Anyone running the shapeways laydown transmission? Looking to try a laydown but want to hear the good and bad.
Chris Brown is offline   Reply With Quote
