Team Associated T5M Discussion
#3438
That is true. However, depending on your ride height target, you might need to change the lenght of the shock retaining cup to get there.
#3439
Im kinda of confused what its really for? say you run 24mm ride height, if you use the thickest then you you shock collar would be higher on the body then if you used the thinest it would be lower to obtain same ride height so what does it actually do or the point to having them??
#3440
#3441
Thanks for the explanation, NO clue why they wouldnt just give the truck, truck springs like they did on the previous 3 model trucks.. WHy the frig doesnt the damn manual explain that crap???? I dont understand some of the tuning stuff they leave out, like shock location, they used to be in the older model manuals.. OK, DOne venting, thanks for the info
