Like Tree22Likes
Old 11-22-2016, 06:07 PM   #3406
Butch Mann's Avatar
Trader Rating: 27 (100%+)
Originally Posted by racingnewb View Post
I ran mine for the first time ever at bumps last Sunday. I really enjoyed it a whole lot, so much fun. I enjoyed more then my b44.3, the truck is so easy to drive(still learning how to brake and turn consistently w/ a 2wd). My truck was owned by a team driver so it is pretty set up already. I bought the aluminum hubs and want to try some different pistons since mine has a ton of pack. Is it normal to run lots of pack in a t5m? I love the looks of these trucks and for the first time that I can ever remember I ran 2 heats w/out a crash(I did end up stuck front end against the pipes but that was it). The only bad thing that happened on Sunday was that some how I cracked my new body, It has my personal best paint job to date. So some drywall tape and shoe goo will have to fix that.
Great truck/class and thanks for the help guys, I really liked the 27Gram (I think not the 40 something) brass weight under the shorty. I've never been so consistent before.
Originally Posted by rregl0612 View Post
I was running with you at bumps, I'm on 1.6 front and 1.7 rears for pistons and think the packs pretty good, truck transfers weight easily maybe a little just a tad too much, but it isn't super twitchy and on 13.5 I feel it let's me cut into corners a bit better.
I do want to try 3x1.4 and a few springs also.
Ps. We talked there I had the black n gold truck
Bumps Stadium Truck Thread?
Are you guys running white truck springs front and rear?
What wt. oil?
It was my 1st time at bumps with the truck I was pushing and loose.
I ran a broke in set of tires I borrowed from Troy so they were not the issue.
Pit Stop Hobbies www.pitstophobbies.net
Bumps and Jumps RC www.bumpsandjumpsrc.com
Butch Mann is offline   Reply With Quote
Old 11-22-2016, 06:33 PM   #3407
rregl0612's Avatar
Trader Rating: 33 (100%+)
What wt. oil?
Butch, Running blue buggy fronts and white rears. When it was warm I was at 37.5 front and 32.5 rear. Will likely drop if it stays cold
Want to try silver fronts I actually have just a touch too much steering. Also running battery a few mills from max front.
I'd tell you both to have a look, but I won't be there till 12/11. 6th n 7th are possible practice also
rregl0612 is offline   Reply With Quote
Old 11-23-2016, 07:47 AM   #3408
Originally Posted by boucher View Post
If the bolt on one side will loosen it, then logic states that having it on the other side tightens it. It's not going to tighten or loosen depending on what side it's on. Just pick a side that's easiest for you to adjust it from.
You forgot about the spring tension preventing the screw from tightening when installed correctly. If it is installed incorrectly the spring tension and the rotation will cause the bolt to loosen up.
Spikesef is offline   Reply With Quote
Old 11-23-2016, 04:44 PM   #3409
Butch Mann's Avatar
So your running the stock springs. Pistons too? 3 gear or 4?
Might have found a set of broke in Jc DW to try also.
see ya on 12/11!
Old 11-23-2016, 04:45 PM   #3410
rregl0612's Avatar
And There it is!!
Old 11-23-2016, 04:49 PM   #3411
rregl0612's Avatar
see ya on 12/11!
4 gear, correction 12/10. No sunday that's the Christmas classic weekend!
Old 11-24-2016, 07:19 PM   #3412
Thanks for your shock set up man, I moved my shocks around yesterday at critters and may have found my magic set up. I still want to try some things but I think I'm getting close to a real easy to drive and consistent set up. I was really loving this truck on Wednesday. If I know what I know now I would of done much better last time at bumps. My truck had a very aggressive set up on it and it was a handful to drive fast for me.
racingnewb is offline   Reply With Quote
Old 11-27-2016, 01:20 PM   #3413
Can someone help me with a parts list to convert the truck to a 3 gear transmission?
Support your local track!!
rpc07 is offline   Reply With Quote
Old 11-27-2016, 02:11 PM   #3414
big james's Avatar
Trader Rating: 119 (100%+)
Motor plate, trans case is all i think
AMAIN HOBBIES |Protek RC | AXIAL | TEAM TEKIN | Airtronics/Sanwa | Factory R/C | Kyosho Mini-z | PN Racing | Rite Eye Designz... Painting Vegas.....
big james is offline   Reply With Quote
Old 11-27-2016, 02:16 PM   #3415
Is the top shaft the same?
Old 11-27-2016, 02:25 PM   #3416
big james's Avatar
Yes
Old 11-27-2016, 02:42 PM   #3417
and gear cover
mac gregor is offline   Reply With Quote
Old 11-27-2016, 02:47 PM   #3418
big james's Avatar
Thanks forgot that one
Old 11-27-2016, 02:53 PM   #3419
So trans case, motor plate and gear cover? I appreciate the help guys
Old 11-27-2016, 03:16 PM   #3420
zeakemedia's Avatar
Trader Rating: 70 (100%+)
I don't even run the gear cover anymore. Never had an issue with it off.
Blake
DJO Race Designs | R1Wurks | Speedy's Racing Parts | The Ohio RC Factory
zeakemedia is offline   Reply With Quote
