Like Tree22Likes
Old 09-19-2016, 10:47 AM   #3286
wrightcs77's Avatar
Trader Rating: 517 (100%+)
Originally Posted by G the Menace View Post
They are racing gas truck at the dome next month Casey
I know. Trying to make it Sunday.
wrightcs77 is offline   Reply With Quote
Old 09-20-2016, 03:10 PM   #3287
Not enough demand for a Team Associated T6md, dang that was going to my step up. Probably he say she say.
Team NovakŪ (1-touch programming)
Team Orion
ProLine
Dialed-RC Hobbies
TEN-SCTE 3.0/22SCT 3.0
Keith B is offline   Reply With Quote
Old 09-20-2016, 05:35 PM   #3288
Trader Rating: 27 (100%+)
Lost an outdrive bearing after 500ish laps. Love the pretty yellow avid bearings, and back on the track today with a 17.5 and a WTF installed. Wow, that thing is sweet! That's one of the reasons I wanted to go to a midmotor was to hopefully the motor would get less dust, but also so I could blow a fan on it. I don't use a temp guy, but as an old nitro guy, the finger test tells me all I need to know. Diggin' the WTF fan!
And, also have to add I topped my best hot lap time as well as my best ten minute run using the 17.5 today. Grr. My previous times were with a 10.5. Today though traction was stellar, due to rain this past Saturday. Also traded the white rear springs for the longer truck green springs. Truck was ripping today! lol
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 09-23-2016, 10:56 AM   #3289
monty c's Avatar
Location: Dont get any more northwest than me..........
okay without going thru all 220 pages, quick question.....rear arms, hard or soft, benefits of each, running on 2 indoor tracks, 1 high bite clay running dirtwebs/electrons and the other ozite carpet running slicks.
i see setups with both types, currently running soft but have hards in the bag.
thanks ahead of time
Maclan Racing // Garcia Graphix // FactoryRC.com
Team Associated T5M // B6 // B5MCE
monty c is offline   Reply With Quote
Old 09-23-2016, 11:19 AM   #3290
aeRayls's Avatar
The tend to land better and more predictable. The stock arms have a plenty of flex which helps in med to lower bite situations but causes a weird feel in high grip tracks.
Hard will take away some grip and are more fragile.
On high grip tracks use hard arms all around. Even on med-high grip.
aeRayls is offline   Reply With Quote
Old 09-23-2016, 02:44 PM   #3291
Trader Rating: 54 (100%+)
Yep, what aeRayls said!
Greg Menor
G the Menace is offline   Reply With Quote
Old 09-25-2016, 11:29 AM   #3292
Has anyone bought the shock spring cup set lately? Ever since I built my b6 I've been wanting to replace the cups with the new ones, they seem tighter and my truck is always having a spring pop off the bottom cup but not sure if its a running change or not.
jswo is offline   Reply With Quote
Old 09-25-2016, 12:45 PM   #3293
aeRayls's Avatar
It'll be a running hmage but my guess is that'll be a while before old stock of that particular part is gone. Best bet would be to order direct from AE but even then no guarantee. I'd imagine it's a not a high selling item.
Old 09-25-2016, 01:32 PM   #3294
Thanks, that's what I figured so thought I'd ask.
Old 09-25-2016, 06:03 PM   #3295
Brit_racer's Avatar
Trader Rating: 130 (99%+)
looking for any help here. The rear of my truck is a little lose. I've tried many things to dial it out. Shocks, wheelbase etc... Running mod. I have the three gear in and i was thinking of switching back to the 4 gear to calm it down on the rear a little.
Think this would work? Anyone noticed the differance?
Rc10B5m, Serpent SRX4, Xray XB2, T5m, RC8B3e, RC8T3e
Innovation Raceway
Brit_racer is offline   Reply With Quote
Old 09-25-2016, 06:22 PM   #3296
tedstryker's Avatar
Trader Rating: 74 (100%+)
I was experiencing this myself this worked really well for me. Layed the rear shocks down. Lowered the rear roll center -2 on camber link. With 4mn washers under the ballstud Shortened the camber link also.
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
tedstryker is offline   Reply With Quote
Old 09-25-2016, 06:40 PM   #3297
aeRayls's Avatar
Mount the shocks inside on the tower, inside on the arm. 1.7 Pistons, 32.5 oil. 1 limiter 34.75mm exposed shaft. Green truck rear spring.
Camber mount down with 2mm washers. Middle hole on rear hubs or the inside back row on alum hubs with 3mm under stud.
I also prefer the brass c mount with the 3 gear.
Old 09-26-2016, 02:25 AM   #3298
eper's Avatar
Trader Rating: 14 (100%+)
Run brass c and d. Helped out my truck a lot.
eper is offline   Reply With Quote
Old 09-26-2016, 04:59 AM   #3299
Brit_racer's Avatar
i put the 4 gear back in last night and moved the shocks and put green springs on. Next ill try the brass mounts. Thanks for the help!
Innovation Raceway
Old 09-27-2016, 02:55 AM   #3300
eper's Avatar
I run 3 gear with brass mounts just so u know
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
