Like Tree33Likes
Old 09-08-2016, 05:15 PM   #3241
Trader Rating: 29 (100%+)
What wind is everybody using for mod in this truck?
DustinEich is offline   Reply With Quote
Old 09-08-2016, 05:17 PM   #3242
LOW ET's Avatar
Trader Rating: 97 (100%+)
6.5t
LOW ET is offline   Reply With Quote
Old 09-08-2016, 08:40 PM   #3243
Trader Rating: 28 (100%+)
Originally Posted by LOW ET View Post
6.5t
Braaaap! I'm afraid to put a 6.5 in mine! lol Not setup for me yet. With traction, she's fast enough with a 10.5 and I'd probably be faster with a 13.5! lol Truck is a huge transition from the T4 I'm so used to. Loving it though
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 09-09-2016, 03:10 AM   #3244
thecman26's Avatar
Trader Rating: 99 (100%+)
6.5t
Holy flaming stadium truck!
I would say 7.5t unless your a pro level driver who never crashes.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 09-09-2016, 06:51 AM   #3245
Yeah I'm thinking 8.5 for outdoors. I race a few indoor tracks a year, but am thinking an 8.5 should be plenty.
I have a 6.5 in Mod 4wd and it is stupid fast.
Old 09-09-2016, 07:59 AM   #3246
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
Go 6.5 . you can always turn down the power with the transmitter. when you get used to it. You can increase the power.
TEAM ASSOCIATED Rc10, rc10B6D ,FUTABA , TEAM ORION, KYOSHO RB6.
mdwaeracer is offline   Reply With Quote
Old 09-09-2016, 12:56 PM   #3247
8.5 is a good choice IMO. I used to up the pinion and turn down the epa and run a 6.5 everywhere. These days I find doing that often leaves you driving in the beginning part of the trigger pull, rather than having the full range of the trigger at your disposal. Most likely b/c everybody will almost always go with more motor (epa) than they need. Meaning, they (I) never chose by practicing and defining what was "fastest" with lap-times. I just put it where it didn't feel stupid fast on the track, and didn't look slower than the other trucks.
Since you already have a 6.5, it would be interesting if you could do a practice day and run both the 6.5 and the 8.5 and compare them over a bunch of laps. But they have to be timed. How they "feel" is useless without times to prove what you actually did the best with.
Old 09-09-2016, 01:03 PM   #3248
I read somebody mention turning down the steering epa the other day. I've never had a truck I felt steered too much, only 1/12 scales! But I haven't had time to play with the setup on the T5, so decided to try it.
First try was yesterday, and gained a lap. Turned it down about the same amount again today, and it felt like I'm used to a truck feeling. Stayed off the tubes, and gained another lap. The truck has so much potential, just need to find some wrenching time to go through it and start making changes and see how good it can really be.
Is it just me, or do these new trucks seem to accelerate faster than the T4 based trucks? Thing just seems like a smooth rocket.
Old 09-09-2016, 01:36 PM   #3249
Yeah, I don't like to tune with the Tx either, it makes the throttle curve feel un-natural... I think I will give the 8.5 a try there is no doubt the 6.5 would be great indoors, but i am confident it won't be the ticket outdoors.
Old 09-10-2016, 08:36 AM   #3250
What's the favorite battery style for the t5m? I'm running a saddle pack right now, works well. I'm not current on all the batt configurations these days.
Old 09-10-2016, 11:20 AM   #3251
Trader Rating: 55 (100%+)
For me it's shorty packs only, end of discussion. Need more weight, add it.
Greg Menor
G the Menace is offline   Reply With Quote
Old 09-10-2016, 12:18 PM   #3252
I'll be looking into that. I had bought a saddle pack for an ae wheeler that I didn't end up running, so was just sitting around. I probably wouldn't have picked up the T5 had I not had a battery to work with it. Now it's time to try some different configurations.
Couple more questions..
Can I get 0* antisquat? I run rough outdoor tracks and don't feel like I need the 1* it has.
The dang truck keeps wanting to nose land jumps, and cartwheels if I don't pre-load the suspension by letting off then goosing it up the face. Recommended change? I've raised rear ride height, didn't help. THere's no drag brake at all, so that's not it. At this point I've just adapted my driving around it. The truck will kill my times with my T4 once I get this problem figured out!
Any recommendations on 30mm fans for the motor? Already got the waterfall, just need to pick up a fan now.
Old 09-10-2016, 12:53 PM   #3253
Try a heavier shock oil in the rear....
Old 09-10-2016, 05:26 PM   #3254
IMO you want go heavy oil or stiffer spring in front to keep the nose up. Blip the throttle after you get of the face of the jump to bring the front up, giving it throttle with thicker rear oil will raise the rear and drop the front end, IMO.
Greg Menor
Old 09-11-2016, 06:30 PM   #3255
Thanks for the input guys. I just cranked the rear spring collars down as far as they'd go, and it was the first time the truck has even thought about jumping level.. Stock setup. Rough, loamy track, not typical for any setups you see today..
What reasons do folks go to kyosho or other brand springs, are they longer?
