Like Tree27Likes
Old 08-04-2016, 09:37 PM   #3166
thecman26's Avatar
Trader Rating: 99 (100%+)
Originally Posted by Joe Maxey View Post
What spur & pinion for 17.5 On your T5M? I just picked up a T5M for practice & will be running 17.5.
Thanks for the help.
Last time I ran stock, I was at 32-33/69 on mine
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 08-04-2016, 10:03 PM   #3167
Jpdanger's Avatar
32/69? That seems more like buggy gearing. Kit recommendation is 29/78 IIRC. I think I have mine geared at 27/78 for a small indoor track.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 08-05-2016, 11:04 AM   #3168
Trader Rating: 15 (100%+)
Pretty stumped here. Hope someone can help.
front camber on one wheel looks incredibly off. and it is by more than a few degrees. they were both perfect and matched but i am starting to think something broke or bent and i cannot figure out what.
the camber links are exactly the same length and has been verified with digital calipers.. many times. I actually measure the outside dimension to verify it.
Is there a component in the steering assembly i should look into that is prone to damage/breakage/bending?
thanks
radioctrlhead is offline   Reply With Quote
Old 08-05-2016, 11:11 AM   #3169
LOW ET's Avatar
Trader Rating: 96 (100%+)
did you use a camber gauge to check camber while sitting on a flat surface? is the camber the same on both sides?
LOW ET is offline   Reply With Quote
Old 08-05-2016, 11:23 AM   #3170
Yes with camber, and no they are different. I am baffled because the camber length NEVER changed and all of a sudden its off.
Old 08-05-2016, 11:25 AM   #3171
LOW ET's Avatar
what type of front axles? maybe a bent front axle? if you spin the front tires, does the tire in question wobble?
Old 08-05-2016, 11:41 AM   #3172
nope, stock axles, I checked it and it spins true.
Old 08-05-2016, 11:45 AM   #3173
LOW ET's Avatar
are all the ballstuds in the correct location? maybe a bent ballstud?
Old 08-05-2016, 12:25 PM   #3174
Trader Rating: 22 (100%+)
So with XRay confirming that the XT2 will be coming out soon hopefully it will spark some more interest in the stadium truck class. I don't see the XRay making a huge impact on its own, but if it drives TLR, Koyosho, and AE to bring their stadium trucks up to their current buggy designs the cumulative impact could lead to increased stadium truck participation for a little bit anyways.
The T5M is probably the least in need of an update but I'd be all about a T6D.
AMessy is offline   Reply With Quote
Old 08-05-2016, 12:47 PM   #3175
big james's Avatar
Trader Rating: 119 (100%+)
I just bought a new t5m, havent even built it yet. so im good with the current model.
AMAIN HOBBIES |Protek RC | AXIAL | TEAM TEKIN | Airtronics/Sanwa | Factory R/C | Kyosho Mini-z | PN Racing | Rite Eye Designz... Painting Vegas.....
big james is offline   Reply With Quote
Old 08-05-2016, 01:27 PM   #3176
It's the normal progression of a product line, so the safe bet says a T6 is coming. Just a matter of when.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 08-06-2016, 12:02 AM   #3177
figured it out. turns out earlier i broke a rear arm and replaced it. replaced it with the wrong side. undfortunately there is no way to know which is left or right but i noticed the lower shock mounting positions were not shaped concave up like they should have. instead it was shaped concave down, opposite of what the other arm looked like (which was not replaced).
I did wonder why the truck was not as "dialed" the last race and well.... found the answer.
Appreciate your efforts in trying to help me with this! Thank you!
Old 08-06-2016, 01:18 AM   #3178
thecman26's Avatar
You are correct, even though I have ran my truck only a few times in stock, I am pretty sure I was around 30-31/72 med sized track with a pretty ballsy 17.5t.
Old 08-06-2016, 02:21 AM   #3179
LOW ET's Avatar
great! glad you got it all figured out
Old 08-06-2016, 07:42 AM   #3180
Trader Rating: 54 (100%+)
76x29 on a larger track, 76x26 for small track when running a 17.5
Greg Menor
G the Menace is offline   Reply With Quote
