Like Tree27Likes
Old 07-20-2016, 09:53 AM   #3151
Trader Rating: 120 (100%+)
Just got a T5M used and need to rebuild the ball diff and replace worn out drives. I have a brand new T4.2/SC10.2 ball diff kit (ASC9853). I see that the part number is different for the T5M/S5M (ASC91421) Can I use it? Are any parts compatible? It would save me another $50.
Thanks in advance.
B5M Lite Schuur Speed 17.5
T5M Schuur Speed 17.5
SC10.2FT Schuur Speed 13.5
Tekno EB48SL HW SCT Pro/Tekin 1900
Axial Yeti
jamr1130 is offline   Reply With Quote
Old 07-20-2016, 08:37 PM   #3152
thecman26's Avatar
Trader Rating: 99 (100%+)
Thanks in advance.
That's a negative Ghost Rider, the T5M is all metric hence different diff.
Diff rebuild kit is dirt cheap.
https://www.amainhobbies.com/mip-ass...p14194/p402205
https://www.amainhobbies.com/team-as...c91420/p275203
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 07-20-2016, 09:00 PM   #3153
aeRayls's Avatar
Well, the b4.2/t4.2/sc10.2 out drives and outdrive bearings were metric. However, I think there's still a reason it doesn't work.
aeRayls is offline   Reply With Quote
Old 07-20-2016, 09:07 PM   #3154
I had a hunch as all AE parts numbers were different but had to ask. I run the MIP pucks in my B5M so I probably go with that too for the T5M running 17.5 too. Plus MIP has them on closeout for $50 Thanks for the info and help guys.
Axial Yeti
Old 07-22-2016, 01:34 PM   #3155
Cridd's Avatar
Trader Rating: 16 (100%+)
is the diff gear two more teeth on the 5 series. can't remember, but ghost rider get on associated website and look at manuals and compare part numbers that may help.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 07-23-2016, 12:22 PM   #3156
zeakemedia's Avatar
Trader Rating: 72 (100%+)
Thought I would see if anybody has their truck this light as well?
Blake
DJO Race Designs | R1Wurks | Speedy's Racing Parts | The Ohio RC Factory
zeakemedia is offline   Reply With Quote
Old 07-25-2016, 09:56 AM   #3157
Trader Rating: 27 (100%+)
This is on a T4, but I believe the spurs are the same..
Is everybody using AE spur gears, or is there a different preferred brand? I've got a bunch of ae gears and they all wobble so bad and a couple I can't believe they don't strip because I have to set the mesh so loose due to tight spots. Top shaft is not bent, it's definitely the spurs.
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 07-25-2016, 10:49 AM   #3158
aeRayls's Avatar
Jconcepts offers machined spur gears!
Old 07-25-2016, 11:46 AM   #3159
Just found one in the bag of parts that came with my last roller. Looks like a great product. Have to pick up some more. Thanks
Old 07-27-2016, 12:45 PM   #3160
kbish76's Avatar
Default B6 laydown
Has anyone tried or thought of adapting the new B6 laydown conversion kit to the T5m chassis?? I'm very curious as my local track is carpet and this could be a very inexpensive way to put a laydown tranny in it compared to the wwhd version.
kbish76 is offline   Reply With Quote
Old 07-27-2016, 05:40 PM   #3161
Trader Rating: 22 (100%+)
I am also interested in this. I was looking at laydown transmission, but wanted to get more run time first. I just got the truck and drove it once. I live in vegas and am about to run at 702 raceway. I
Agama A215T, Red R5R, Savox
Agama A8T E, tekin, Savox
Agama A8e Evo, Tekin, Savox
go4broke is offline   Reply With Quote
Old 07-28-2016, 03:11 AM   #3162
eper's Avatar
Trader Rating: 14 (100%+)
ive heard it doest fit the b5m so id imagie it wont work on the t5m either.better off getting the aftermarket set up.
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 07-28-2016, 03:39 AM   #3163
I agree, I took the laydown transmission from my B6 and tried to dry fit it in my B5m and it didn't look at all possible without major rework of the 5 series. Also in the truck, even if you did manage to get the transmission case to fit the shock towers and such would have to be custom made.
AMessy is offline   Reply With Quote
Old 07-28-2016, 05:01 AM   #3164
You can do the ACRC box for like $60 and use the stock rear tower. Or just wait a little bit for the new truck to come out.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 08-04-2016, 08:54 PM   #3165
What spur & pinion for 17.5 On your T5M? I just picked up a T5M for practice & will be running 17.5.
Thanks for the help.
Joe Maxey is offline   Reply With Quote
