Like Tree27Likes
Old 07-14-2016, 09:25 AM   #3136
tedstryker's Avatar
Trader Rating: 74 (100%+)
Originally Posted by aeRayls View Post
Always cut the brace behind the servo, between the battery posts and the piece between the waterfall screws.
Running mod the weight under the shorty is a huge help!
Drilling the 3rd hole in the front arms just like the b5 is huge as well!! This helps so much on med to high grip. Just increase the the front droop 1-1.5mm
I'd like to see pictures if you can
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
tedstryker is offline   Reply With Quote
Old 07-14-2016, 09:59 AM   #3137
aeRayls's Avatar
I never can get pics to upload from my phone. It's just a 3rd outer hole. Same as we did on the 44.3 and b5's. Drill the hole the same distance apart as the other two are. Then use a cone dremel bit to take away material so that the shock eyelet can go in and move freely. I also use a fresh xacto to trim it a bit finer. This calms the steering a ton and it's way smoother to drive. I and a lot of the team have been running this for a solid year.
Also remember to add 1-1.5mm of droop into the front shock.
aeRayls is offline   Reply With Quote
Old 07-14-2016, 05:55 PM   #3138
OK played around with my 13.5 some more and can make the double most of the time. Had to go back to std gearing 26/78. Have a 9.5 coming
Drbrake is offline   Reply With Quote
Old 07-14-2016, 10:02 PM   #3139
Woulvesbaine's Avatar
Originally Posted by Wildcat1971 View Post
If you are looking for aluminum bell cranks, avid has them at reduced pricing. I have these in my sc5m.
http://www.avidrc.com/product/5/acce...cessories.html
Nice info. Thanks.
Was looking at the JC, but those look pretty cool as well.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is online now   Reply With Quote
Old 07-15-2016, 07:01 AM   #3140
Originally Posted by Woulvesbaine View Post
Nice info. Thanks.
These are nice just got a set.
jslider is offline   Reply With Quote
Old 07-15-2016, 07:18 AM   #3141
tedstryker's Avatar
can someone point me in the direction of the 50g weight
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
Old 07-15-2016, 08:42 AM   #3142
aeRayls's Avatar
Yokomo saddle type weights. They're 25g apiece and fit perfectly side by side in the T5. Just search Amain. That's where I picked mine up
Old 07-15-2016, 10:03 AM   #3143
tedstryker's Avatar
Thanks man
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
Old 07-18-2016, 06:48 AM   #3144
Since cutting the cross braces is not reversable what is the benefit and do I really want to do this on a high bight clay track running slicks? (RC Clubhouse)
Old 07-18-2016, 08:09 AM   #3145
aeRayls's Avatar
We have done this on the b5,t5 and sc5 on any and all conditions. It allows the chassis to flex in the correct way. You'll notice in the B6 none of these braces exist.
Old 07-18-2016, 08:36 AM   #3146
wrightcs77's Avatar
Trader Rating: 521 (100%+)
Do people think there is a T6 on the way?
wrightcs77 is offline   Reply With Quote
Old 07-18-2016, 09:39 AM   #3147
aeRayls's Avatar
Not any time soon
Old 07-18-2016, 05:23 PM   #3148
Trader Rating: 22 (100%+)
Hey guys, i tried putting weight plates under my shorty and i am unable to secure the brace. Any ideas?
Team Associated T5M Discussion-img20160718_170914.jpg   Team Associated T5M Discussion-img20160718_171001.jpg
Agama A215T, Red R5R, Savox
Agama A8T E, tekin, Savox
Agama A8e Evo, Tekin, Savox
go4broke is offline   Reply With Quote
Old 07-18-2016, 05:49 PM   #3149
aeRayls's Avatar
Just remove some material from the slot in the waterfall where the strap goes in. I also took some off the lip of the strap
Old 07-18-2016, 08:51 PM   #3150
Thanks a bunch that helped out.
