Like Tree27Likes
Old 05-23-2016, 11:16 AM   #3076
aeRayls's Avatar
Originally Posted by Braxamus View Post
I probably already know the answer, but if I already run the brass D block and I am going to add the plate under the shorty which I have been told on here it was 50g. should I add less under the battery to account for the D block or still add the the 50g. ? or would it be better to remove the D block and just add the full 50g. under the shorty?
Just add the weight under the battery and consider that the standard. Change anything for tuning or driving preference.
Just an FYI out there to anyone running the T5M in outdoor loose and bumpy/rough conditions.... If you're running the newer truck springs and not happy with the truck. Take them off! After some testing last weekend, the stock (buggy) springs were so much better in these conditions!
aeRayls is offline   Reply With Quote
Old 05-23-2016, 05:19 PM   #3077
Hi , I'm seriously thinking about getting this truck but first anyone hear anything about assoicated comming out with a newer truck since the b6 and b6d are comming out soon . Don't know what to do 🤔🤔
BRIAN77 is offline   Reply With Quote
Old 05-23-2016, 09:48 PM   #3078
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I dont think a new platform with be out till next year. Will they release an updated t5m with bling....maybe. they might want to reduce inventory. a good way is to deck out the current platform with option parts. For example the B5m CE....
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-24-2016, 09:50 PM   #3079
Trader Rating: 25 (100%+)
Raced a 22T 2.0 last year and thought for this year I would try a T5M but I need a little advice on setup for our out door very low traction track. My TLR was ran in rear motor and worked very well so what do I need on the T5M to get as much rear bite as possible?
Sandfreak is offline   Reply With Quote
Old 05-25-2016, 07:42 AM   #3080
aeRayls's Avatar
There a few items that will help. Get the brass c block and inserts. Stick with the buggy springs that come with it. Don't bother with the newer truck springs for outdoor low grip. If you're running mod use a square pack of a shorty with 50 grams of weighty under the lipo.
Space the rear arms forward. Use the 3.5 inner toe inserts. Use whatever gearing combination that moves the motor further back. I use the 81/19 with a 7.5 instead of the usual 84 spur gear.
Look into using the front castor block spacers to move the spindle down! This helps a lot.
My usual shock setup is:
Front:
1.6 35 oil 3 limiters 26.5mm droop. Blue or yellow spring. Middle tower/outside arm
Rear:
1.7 30 oil 1 limiter 36mm droop white or green spring. Inside tower middle on arm
Old 06-03-2016, 06:47 AM   #3081
chevydc44's Avatar
Trader Rating: 31 (100%+)
I have a mod truck 8.5t is it a good idea to run 3 gear tranny of just leave it a 4 gear?
chevydc44 is offline   Reply With Quote
Old 06-03-2016, 08:09 AM   #3082
Braxamus's Avatar
I run mine with a 8.5 and the 3 gear, on an indoor mid to high bite track and really like it.
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 06-03-2016, 10:21 AM   #3083
Trader Rating: 23 (100%+)
Hi Guys,
for those of you still racing hard and going fast with your Associated T5M, we have our entire Associated T5M option parts line on sale this week (sales ends this Sunday)
http://www.teamstrc.com/index.php?ro...egory&path=155
S
Steve Wang
ST Racing Concepts: www(dot)teamstrc(dot)com
teamstrc is offline   Reply With Quote
Old 06-04-2016, 10:24 AM   #3084
I'm going to be converting my SC5m into a T5m, got the chassis, cradle, body posts, and front axles on the way. Is there anything I should look out for or be wary of with doing the conversion?
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 06-04-2016, 12:56 PM   #3085
big james's Avatar
Trader Rating: 119 (100%+)
wich parts do i need to convert from 4 gear to 3 gear? or is there a kit for this?
AMAIN HOBBIES |Protek RC | AXIAL | TEAM TEKIN | Airtronics/Sanwa | Factory R/C | Kyosho Mini-z | PN Racing | Rite Eye Designz... Painting Vegas.....
big james is offline   Reply With Quote
Old 06-04-2016, 02:11 PM   #3086
transmission case, motor plate and gear cover.
Old 06-04-2016, 06:08 PM   #3087
big james's Avatar
thanks. whats everyones take on the lightened top shafts, such as the mip one?
Old 06-04-2016, 07:09 PM   #3088
RoundEye's Avatar
So while working today I tried to quickly browse through and find someone talking about a direct drive for the T5M. No one at my track uses them so I cant get any answers here.
exotekracing.com/b5-t5-sc5-direct-spur-mount/
For the 17.5 stock class would this be a improvement or not? The track is a medium bite.
RoundEye is offline   Reply With Quote
Old 06-05-2016, 04:10 AM   #3089
wildfire86's Avatar
I've stripped out 2 idler gears using the slipper eliminator running 17.5. It's very high bite @ Beachline Raceway. High grip + big tires + on throttle landings = stripped idlers I've gone back to a tight slipper.
Doug
Doug Hudson
Beachline Raceway / 386 Raceway
wildfire86 is offline   Reply With Quote
Old 06-05-2016, 06:36 AM   #3090
RoundEye's Avatar
That's what I was thinking. Thank you! So glad the ST are coming back to the track.
