Like Tree24Likes
Old 04-13-2016, 04:30 PM   #2971
thecman26's Avatar
Trader Rating: 98 (100%+)
Originally Posted by aeRayls View Post
Yes the older trucks always had longer specific front spring, the rear springs were ways shared with the buggy.
When AE released the big bore shocks they determined through testing that just using different height cups and using the buggy springs worked very well... and it does. Since then, testing of these new springs has shown an improvement that's why they got made. It's not that they are just longer...They are wound differently! I've met several drivers who don't prefer them on really bumpy tracks though.
Very true!
I haven't ran on terribly bumpy tracks myself, but I prefer the truck springs where I run, a LOT cheaper than the Kyosho springs for sure!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is online now   Reply With Quote
Old 04-13-2016, 05:40 PM   #2972
aeRayls's Avatar
Originally Posted by Keith B View Post
Are you suppose to run the Reedy lipo weights with the saddle pack also
Saddles and squares are already plenty heavy enough. Doesn't mean you can't to try it.
All of the team setups for mod are based around the static weight of a square pack. Saddles are very close. Shorties are anywhere from 45-60 grams lighter.
Plus at any roar event squares are not legal. That's a big reason the team just runs the shorty with weight added so they aren't swapping diff lipo styles all the time.
aeRayls is offline   Reply With Quote
Old 04-15-2016, 04:53 PM   #2973
eper's Avatar
Trader Rating: 14 (100%+)
hey guys im looking at some set up sheets and the rear upper shock mount is marked between location 2 and 3 is that just a weird marking or are they drilling the tower.. thanks
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 04-15-2016, 11:54 PM   #2974
aeRayls's Avatar
Just a weird marking
Old 04-16-2016, 04:25 AM   #2975
eper's Avatar
kinda figured thanks for takin the time to answer
new milford ct,
Old 04-16-2016, 04:29 AM   #2976
thecman26's Avatar
Yeah it's just weird marking on the sheet, its either 1, 2, or 3... No in-betweens that I know of!
Old 04-17-2016, 07:12 PM   #2977
has anyone tried 1 degree in the rear hubs? im using zero now but looking for more rear bite. would this help?
DIRT DIGGER is offline   Reply With Quote
Old 04-17-2016, 08:55 PM   #2978
mblgjr's Avatar
Trader Rating: 86 (100%+)
Yes....lol
mblgjr is offline   Reply With Quote
Old 04-18-2016, 11:55 AM   #2979
Originally Posted by mblgjr View Post
Yes....lol
Thanks for the reply I'm gona change that. Also what would be my shortest option for the rear camber links using the stock hubs? I thinking the shorter links will give me more bite also?
Old 04-18-2016, 01:09 PM   #2980
aeRayls's Avatar
Try lowering it first on the inside!
But to answer your question, the 3 hole insert all the way inside is the shortest link
Old 04-18-2016, 05:06 PM   #2981
mblgjr's Avatar
Staneck its me...
And what the guy above stated; lowering the inner stud by 0.5mm is often better than purely shorter link.
Old 04-20-2016, 09:42 AM   #2982
Hey guys,
Associated tech support tells me that the kit shock pistons won't work with the new V2 screw shafts (part # 91620, 91624). They tell me that to get 2x1.7mm piston I need to buy blanks and then drill them. Is this right? I wanted to run 2x1.6 front, 2x1.7 rear. Also should mention I'm getting the Kashima coated bodies, aluminum caps, xrings. Looking to keep the kit shocks as spares.
BruceR. is offline   Reply With Quote
Old 04-20-2016, 09:48 AM   #2983
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by BruceR. View Post
Hey guys,
Correct...standard pistons will not work with the screw shafts. You need V2 pistons. They come in various sizes, but not the 2x1.7's. You can get 2x1.6's and then drill them out yourself with a 1.7mm bit.
Pistons: http://www.amainhobbies.com/search?s...on&fb=13&lg=fb
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-20-2016, 10:11 AM   #2984
CCristo's Avatar
Trader Rating: 55 (100%+)
Schelle offers 2X1.7 pistons for the AE V2 shock shafts.
http://www.schelleracing.com/Schelle...2-12mm-Pistons
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 04-24-2016, 04:28 PM   #2985
thecman26's Avatar
Anybody know if there are any plans on AE making gold shock shafts for the T5M?
I just rebuilt my buggy shocks and truck shocks, the buggy shocks are WAY smoother than my truck shocks. Buggy has gold shafts and both have low friction X-Rings...
Crap, nevermind, I found them on Amain! Lol!
