Like Tree25Likes
Old 04-05-2016, 06:31 AM   #2911
im leaning more towards the stadium truck actually since i dont really care for racing but whats the champions edition different from factory lite?
eddie7978 is offline   Reply With Quote
Old 04-05-2016, 06:47 AM   #2912
The T5m is good all around the spectrum. The B5m is narrow and requires less torque for turning the wheels and will have an overall greater top speed
Team NovakŪ (1-touch programming)
Team Orion
ProLine
Dialed-RC Hobbies
TEN-SCTE 3.0/22SCT 3.0
Keith B is offline   Reply With Quote
Old 04-05-2016, 08:37 PM   #2913
i have a question that i have no idea about and would love some help on this. i run on a low bite indoor track if i run zero shock limters will that help give me more traction or should i run limiters and if so how many should i use? thanks alot of any help i can get.
DIRT DIGGER is offline   Reply With Quote
Old 04-05-2016, 09:34 PM   #2914
monsterbrad's Avatar
Been running this truck most of the winter indoor on clay.
2 things
the limiters will do you no good try tires and set the ride height to 30mm front and back.
the stock springs fatigue after a few races so check that and the tall spring perches are prone to crack watch that as well.
Some guys where I run use Kyosho springs front and back .
others use truck whites all the way around.
I still have the stock box springs on my truck but i store it on a stand all the time never sitting on the wheels.
The 1 thing I have noticed after all the racing this season with the truck is tires and ride height.
monsterbrad is offline   Reply With Quote
Old 04-06-2016, 06:03 AM   #2915
henry's Avatar
Does anyone know of a decent outdoor setup? I primarily run on a track that holeshots 3ds and even sometimes goosebumps hook up on. I haven't really seen anything online for a setup for these conditions.
henry is offline   Reply With Quote
Old 04-06-2016, 07:24 AM   #2916
try it stock it may surprise you
Old 04-06-2016, 10:23 AM   #2917
Default T5M vs B5M handling
Have both a B5M CE and a T5M, and while I love driving the B5, the T5 always feels like a handful and I would like some input on where I need should start looking at getting the T5 to be more controlled and predictable.
Some background:
- Both the B5 and the T5 are setup up to essentially the manuals' recommended configuration.
- Both running 4 gear transmissions
- Both have 13.5 motors with a mild boost setting on the ESC
- Both run shorty packs in the rearward position
- Both run blue-dot Electrons
Track (SMAC-Track) is med-high grip indoor clay, with a lot of tight corners.
The B5 feels very stable and predictable on track. Steering is reasonably tight and when the rear does kick out, it feels controlled and predictable. I am certain it isn't the fastest setup going (it's the driver certainly isn't) but it is a lot of fun to drive.
The T5 on the other hand is definitely more toward the twitchy side, and a lot less controllable than the B5. The T5 is far more likely to kick-out the rear end and far less predictable when doing so, making the truck a handful to drive compared to the buggy.
So before I go tweaking too many things, any experience on a good place to start. Once suggestion was to stiffen up the front springs to take out some of the steering, but I wanted get feedback here.
Jake
Freejack is offline   Reply With Quote
Old 04-06-2016, 10:48 AM   #2918
Some background:
Jake
I was told to run a square pack or the battery weighs to help settle the T5m down some. I raced it for the first time this past Saturday. I ran a square pack and the truck was very planted and stable
Beaker151 is offline   Reply With Quote
Old 04-06-2016, 10:56 AM   #2919
I have both packs for mine
practice on the shorty and race with the square
the trucks is much better with bigger battery or weight added
Old 04-06-2016, 11:41 AM   #2920
the factory lite kit seems nice it has the lightened chasis that the champ kit doesnt come with
Old 04-06-2016, 02:19 PM   #2921
I liked the fact that a three gear transmission was standard too
Team Orion
ProLine
Dialed-RC Hobbies
Old 04-06-2016, 02:38 PM   #2922
yea i wish tbey had a factory lite kit for the t5m
Old 04-06-2016, 03:08 PM   #2923
monty c's Avatar
Location: Dont get any more northwest than me..........
this setup worked for me really well the last loose dirt race i ran, this is what im starting the season with. i ran double dees in the front with holeshots or flipouts in the rear.
Maclan Racing // Garcia Graphix // FactoryRC.com
Team Associated T5M // B6 // B5MCE
monty c is offline   Reply With Quote
Old 04-06-2016, 03:27 PM   #2924
will they be coming out with the lite version?
Old 04-06-2016, 05:43 PM   #2925
BorackBasher's Avatar
Send a message via Yahoo to BorackBasher
i would like to say yes my friend but i think AE has something else cooking in area51.
Team Associated - MIP - OCD - SC10.2 - SC10 4x4 - T4.2 -B4.2 - Reedy - XP Digital - LRP - Airtronics - Pro-line - AKA - JCONCEPTS - OCRC - THE RANCH - LRH Hobbies - Hanna's Restaurant & Bar.
BorackBasher is offline   Reply With Quote
