Like Tree25Likes
Old 03-31-2016, 03:09 PM   #2896
does anyone have a good indoor dirt setup for low/med bite track ? thanks
DIRT DIGGER is offline   Reply With Quote
Old 03-31-2016, 03:14 PM   #2897
Same here! ^^ need a setup also
Photographer/Racer | Youtube rctrains | t5m | scte 2.0 |22 sct | Bd7 | 8ight E 3.0
rctrains is offline   Reply With Quote
Old 03-31-2016, 03:56 PM   #2898
mblgjr's Avatar
Trader Rating: 86 (100%+)
Rc10.com
Use the Brent Thielke setup at the bottom of the list.
Use white front/green rear truck springs; or white rears & inboard tower hole.
Setup works great with shorty or square depending on taste.
Use with 3gear trans for more aggressive feel.
mblgjr is offline   Reply With Quote
Old 03-31-2016, 04:56 PM   #2899
Where would I find how to convert a B5m into a T5m?
RaisinBagel is offline   Reply With Quote
Old 03-31-2016, 05:04 PM   #2900
aeRayls's Avatar
Well I'll put it this way, it'll cost almost as much as buying a whole new kit! Here are the differences:
Chassis
Chassis cradle
Front and rear arms
Front and rear shock towers
Turnbuckles
Front and rear shocks
Front axles
Cva bones
Rear wing mounts
Rear hexes
aeRayls is offline   Reply With Quote
Old 04-03-2016, 06:05 PM   #2901
just ordered mine today how is the box setup does it work well?
Old 04-03-2016, 06:42 PM   #2902
I don't think it's 1/2 bad out of the box.
BruceR. is offline   Reply With Quote
Old 04-04-2016, 03:55 AM   #2903
Braxamus's Avatar
With the exception of shock oil and springs box setup was really close for my local track a mid to high bite indoor track.
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 04-04-2016, 10:27 AM   #2904
Well, I tried the new truck white springs on the T5M yesterday. Also had 37.5F/32.5R oil in it. Shorty battery, 1 thin spacer to the rear. I seemed to have a lot of issues with front to rear weight transfer. (This is on a carpet track). On throttle the front got light, and it didn't want to turn very well. On the brakes, it wanted to snap the rear end around in the corners. So I went to gray springs front & rear and it seemed to help. I wanted to add limiters, but I understand that's to help with traction rolling and I don't think that's my issue. I also raised my ride height to 27mm f/r and it seems to be better. Am I headed in the right direction? A friend suggested to cut the chassis brace and run the battery inline to keep weight centered. Not sure I want to do that just yet.
Old 04-04-2016, 10:43 AM   #2905
Braxamus's Avatar
Think about it battery side ways as designed or in-line the weight is centered side to side either way. If I am thinking about it correctly the only change will be the weight displacement front to rear, and not actually "centering it up" sideways as designed and ran 7mm forward off rear wall (thin foam spacer) would keep more weight to the rear, while having it inline would move more weight to the front. I do not race carpet and never have so not sure what to tell you other than to me raising the ride height may hurt you.
Team Raw Speed
Old 04-04-2016, 12:00 PM   #2906
Yeah, not sold on running the shorty lengthwise either. As for raising the ride height, I agree it was counter-intuitive to do so. But, trying to get the ride height lower, using +5 offest spring cups, I had the collars backed up all the way against the shock cap. Adding a few milimeters actually allowed me to add some preload to the springs, which seemed to help me out. I could always use the 0 offset cups and set ride height. I was actually messing with the front arms- with the front tire spinning if I compressed the arm it will eventually hit the body. So seems like something wasn't quite right up in the front. I'm of the opinion that carpet or clay, high grip tracks are high grip tracks so trying to set this beast low like a buggy is foolish.
Old 04-04-2016, 06:13 PM   #2907
Default newbie questions
i was into this 15 years ago i had a t3
im wanting to get back into this again but at the local track they said the stadium trucks arent that popular anymore
but they said i can still use them
i really like the new mid motor design
i remember always hitting my motor after a jump
anyway im looking for eather the rc10t5m
or the rc10b5m
now should i go for a factory lite kit? i only see them for the buggy not the truck
eddie7978 is offline   Reply With Quote
Old 04-04-2016, 11:35 PM   #2908
Cridd's Avatar
Trader Rating: 16 (100%+)
Things to try on toy car. That ride height feels high for carpet, when you raise it that transfers more weight and makes the other end feel light. l
Lower it and go the stiffest springs you have, go up with washers on front and rear towers, for less sway. You want to transfer weight quickly since you have grip and want a flat car thru turns, braking and gas. Make sure diff and slipper are set properly for carpet. I think you want a stiffer car so cutting braces would loosen you up. May even want hard parts if you don't crash, all this is what I would try during practice prior to racing. Tires would be what everybody else uses with stiff inserts.
Cridd is offline   Reply With Quote
Old 04-05-2016, 05:44 AM   #2909
JRSlash's Avatar
B5M is a more popular car and 2wd buggy is a more popular class. I think the factory lite is the only b5m kit they offer now. It seems the CE (Champions Edition) was a limited run and appears to be discontinued but towers still has them in limited quantities.
SOAR Seiki 998 TD1 Nitro
SOAR Seiki 998 TD1 E-buggy
PR Racing SB401
Dialed-RC Hobbies (www.dialedhobbies.com), SOAR Seiki USA
Bellgate Distributor (www.bellgatedistributor.com), PR Racing USA
JRSlash is offline   Reply With Quote
Old 04-05-2016, 06:17 AM   #2910
Stadium truck races are sensational. Like driving a Tahoe after a Focus
Team NovakŪ (1-touch programming)
Team Orion
ProLine
Dialed-RC Hobbies
TEN-SCTE 3.0/22SCT 3.0
Keith B is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
coaltrain, trick25
