Like Tree33Likes
Old 03-24-2016, 05:35 AM   #2881
thecman26's Avatar
Trader Rating: 99 (100%+)
Originally Posted by rctrains View Post
Just ordered my t5m and got extra arms front and rear, super hype about it, moving up from a t4.1, any tips on building?
If you have a shop nearbye, the gearbox bearings are pretty rough, if you can get the schelle oiled ceramic bearings. If not that should be an upgrade to order soon.
Otherwise a great build and a great truck! 2000% better than the T4.1!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 03-24-2016, 08:49 AM   #2882
Jpdanger's Avatar
Buy a good degreaser, pop the bearing covers off, and degrease the kit bearings and they'll be nearly as good. You could fill a jar of Vaseline with the amount of grease in the kit bearings.
I recommend the 3gear tranny too.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 03-24-2016, 08:57 AM   #2883
Jpdanger's Avatar
Haha that bad huh?, will try that for sure!, I was gonna ask that to 3 or 4 gear, tracks here are super lose and dry, hardly any grip unless I go indoors, hmm...
If it's loose than 4gear would probably be best.
Old 03-24-2016, 04:39 PM   #2884
Woulvesbaine's Avatar
Has anyone tried a Hobbywing v10 17.5 in their T5m? I'm looking for a new stadium truck motor and considering the HW v10 or the Reedy M3. I'm pretty sure the Reedy will be a good choice, but am wondering if the slightly less expensive HW would perform as well.
Anyone try one or both of these?
Other options are Schurr, Savox, Tekin Gen3 or even LRP, but I'm leaning towards the Reedy M3 or the HW.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 03-25-2016, 08:05 AM   #2885
I run stock class with my hw v10 17.5/ v3.1 esc and love it. Smooth! Easily programmed !
Is anyone else experiencing a little play between the front axle and caster block? I have like 0.5mm to 1mm of play.? Shim it? New blocks? Spacer problems?
CoastalERC1 is offline   Reply With Quote
Old 03-25-2016, 09:34 AM   #2886
If you're talking about the steering block inserts wiggling: a lot of people just glue them. If they want adjust trail they'll pay a couple $$ for a new pair of steering blocks + inserts.
PetRock is offline   Reply With Quote
Old 03-25-2016, 04:05 PM   #2887
Sorry I mean the screw and axle where the front bearings are? Little play. Like the screw is too long? Not sure yet.
Old 03-27-2016, 10:42 AM   #2888
Finished bulding my first kit!;0 it was so easy and very fun! Got all my electronics in and tested just gotta wait till next weekend ugh, only one problem, I have some slop in my right rear arm in the chassis pin, any way to fix?
Photographer/Racer | Youtube rctrains | t5m | scte 2.0 |22 sct | Bd7 | 8ight E 3.0
rctrains is offline   Reply With Quote
Old 03-28-2016, 02:55 PM   #2889
thecman26's Avatar
That's an issue with the plastic rear hinge pin blocks. The Aluminum/Brass upgrades fix this problem. A quick fix is a shim or two and you'll be good to go.
Old 03-28-2016, 03:02 PM   #2890
Thanks for the tip! Well quick fix then get the upgrade!
Old 03-29-2016, 07:38 AM   #2891
Braxamus's Avatar
I am currently running the recommended gearing for a 8.5 motor per the instruction manual in my truck, I however have changed the tranny from the 4-gear to a 3-gear, and still running the same gearing, should it be different for a 3-gear or remain the same.
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 03-29-2016, 08:37 AM   #2892
lbckevin's Avatar
Trader Rating: 91 (99%+)
Same gearing for both.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 03-29-2016, 08:41 AM   #2893
Anyone have an area to start. T5m, hw ss v3.1 17.5, 78/27 wasn't in the ballpark for a local SoCal track Sdrc. Maybe 72/30? Any ideas thank you!
Old 03-29-2016, 08:45 AM   #2894
lbckevin's Avatar
I run a 75/27 or 28 for both OCRC and SDRC with my Schuur Speed 17.5
Kevin Smith
Old 03-29-2016, 10:47 AM   #2895
Thank you!
