Like Tree33Likes
Old 03-01-2016, 08:47 PM   #2821
Cridd's Avatar
Trader Rating: 16 (100%+)
Didn't somebody post a picture of old cup bag compared to new ones, but get a set at Amain and you get new stuff. No problems on mine.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 03-01-2016, 09:22 PM   #2822
Originally Posted by thecman26 View Post
Some were saying they were, I got a first run truck so the ball cups were crap.
This.
highenuff89 is offline   Reply With Quote
Old 03-02-2016, 03:02 AM   #2823
Braxamus's Avatar
When I built mine several months ago I got the original cups and yes they were stiff but easily fixed.
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 03-02-2016, 09:47 AM   #2824
sduffy77's Avatar
Trader Rating: 18 (100%+)
Buy 'em from Amain, they cycle through supply fast enough you're pretty sure to get an updated set. That's what I did.
Originally Posted by QDRHRSE View Post
I haven't seen a kit in a long while that had the old cups. As long as you didn't buy a truck from a retailer that has had it sitting around for 6 months you should be fine.
I got mine from tower hobbies in Dec '15 and it still had the old ball cups. I emailed support and they sent me the updated ball cups.
Team Associated SC5M | Team Associated T5M | Team Associated RC8b2e
Bumps & Jumps | Pit Stop Hobbies | Backhills RC
Pro-Line Racing | Maclan Racing | Xpert RC USA | Boca Bearings | Gens Ace | Mattox Designs | Race Ready Products | Sticky Kicks
sduffy77 is offline   Reply With Quote
Old 03-02-2016, 05:27 PM   #2825
68pontiac's Avatar
Originally Posted by highenuff89 View Post
Picked up a reedy 8.5 will be running in the mod stadium class..
As I have stated I have not raced since the 90s..
There is no stock stadium class were I will run. Most at the track run 7.5, 8.5..
Just wondering if there will be a learning curve, i.e. To much power.. If so do you recommend going to a 13.5 or just setting the esc..
Thanks again!
I'd recommend trying the motor out first before deciding if it's too much horsepower for you to handle. It'd be almost impossible to say if you'd be able to handle it unless you give it a try. Having said that, I run a 7.5-turn in my 22T and it feels just about right for my low-traction track when dialed down to 90-95%.
The easiest way to deal with a motor that's too powerful is to just turn your EPA down on the transmitter. If it's too fast/too punchy just turn your throttle EPA down about 10% and try again. It'll reduce the total amount of power delivered to motor, making your "full throttle" feel a lot less explosive. Also, if your motor has mechanical timing advanced you can reduce it (don't go negative) and it'll help to calm the motor down, too.
68pontiac is offline   Reply With Quote
Old 03-02-2016, 05:46 PM   #2826
gticlay's Avatar
Yeah, I run a 6.5 in mine most of the time and it's not so much power. Just don't yank that trigger so much
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 03-02-2016, 06:42 PM   #2827
Jpdanger's Avatar
Turning the punch down on your ESC will help too.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 03-02-2016, 06:50 PM   #2828
b57
I went 10.5 > 8.5 > 6.5 ... the 6.5 is way too much motor for our track, but I got it so I could turn the timing all the way down to keep motor temps down. I still can't go more than 1/4 throttle or it wheelies out of control. I love it.
b57 is offline   Reply With Quote
Old 03-06-2016, 11:58 AM   #2829
super excited to be getting my t5m this week for my bday im currently running the t4.2 wih no upgrades other then the fox shock bodies which I highly recommend I didn't think they would make a huge difference but it really does and don't mind supporting the fox collaboration since fox builds all my mx shocks anyways point of this post now , im running gear diff in my t4.2 because I really don't like ball diffs , are the gear diffs between the t4.2 and the t5m different, I did see a different part number but i've seen companies do this before to make a customer think the had to buy it because they were different I don't notice a difference between the images but maybe its minimal any help would be great any other things I should look into getting aswell would be appreciated to
microsprint998 is offline   Reply With Quote
Old 03-06-2016, 06:51 PM   #2830
I just built my T5M, glued the tires, installed the front and the wheel is just barely rubbing the front ball cup. I have the block inserts set at 4mm, which the manual says is the standard setting. I have checked the manual and everything looks like it is installed correctly. I have also checked to make sure the wheels are correct, Team Associated wheels.
Any suggestions?
Tony Tillman is offline   Reply With Quote
Old 03-06-2016, 10:14 PM   #2831
frankf's Avatar
The t5m uses metric bearings but the t4 doesn't so I doubt the gear diff you have will work
frankf is offline   Reply With Quote
Old 03-07-2016, 07:47 AM   #2832
xyzracer's Avatar
Any suggestions?
Ball cups on upside down
xyzracer is offline   Reply With Quote
Old 03-07-2016, 08:35 AM   #2833
I'm considering getting the Chrome V2 shafts with the screw on machined V2 pistons and using the stock bodies (with X-rings). I'm not sure that the fox bodies would make as big of a difference vs the cost to purchase them.
Does this make sense?
WRXnItUp is offline   Reply With Quote
Old 03-07-2016, 08:41 AM   #2834
Thanks again!
I started with an 8.5 and it just wasn't enough for me. 7.5 was MUCH better.
I have the 4 gear... Probably why 8.5 didn't feel like enough.
Rabidtrout is offline   Reply With Quote
Old 03-07-2016, 01:14 PM   #2835
thecman26's Avatar
Trader Rating: 99 (100%+)
Any suggestions?
Are your caster blocks shimmed correctly, with 4mm trailing they should be shimmed forward. Also are the cups backwards?
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
