Like Tree25Likes
Old 01-14-2016, 03:37 PM   #2686
Send a message via AIM to MMT4 Send a message via Yahoo to MMT4
Hello, I just put together this truck and aside from one or two areas I'm very impressed by the quality. I see that the stiff ball cups issue has been noted in the thread and I'll be trying some of these fixes, but has anyone had excessive slop in the A-arms? My rear left A-arm has a lot of slop at the hinge-pin while the rear right A-arm is fine. The rear bearing carriers have a lot of slop as well, both sides. I double-checked the assembly manual and made sure that I used all of the spacers. When I disassembled the rear A-arms and put them back together, I found the rear bumper caused the slop.. any advice??
MMT4 is offline   Reply With Quote
Old 01-15-2016, 07:47 AM   #2687
HappyHippo's Avatar
this is what I'm going to test this weekend..... EOS Truck getting ready
Team Associated T5M Discussion-img_9374.jpg   Team Associated T5M Discussion-img_9379.jpg
HappyHippo is offline   Reply With Quote
Old 01-15-2016, 08:44 AM   #2688
Jpdanger's Avatar
What gearing/timing recommendations do you have for a T5M equipped with XFactory CF chassis with a 17.5T blinky Fantom FR1 Type T on a medium sized high bite clay very technical track.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 01-15-2016, 08:44 AM   #2689
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Nice..also looks like there has been a change to the gearbox so that you can run the OEM shock tower
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-15-2016, 03:33 PM   #2690
Cerevo's Avatar
Mine has bushings that go on the hinge pins to take most of that up but there's still space enough to put another slim washer in there and that's what I plan on doing.
Retired: RC10T3 Mtroniks ESC, Feigao sensorless 7t,
Currently run: Associated T5M
Radio-Active Raceway in Wingo, Ky
Cerevo is offline   Reply With Quote
Old 01-17-2016, 04:47 PM   #2691
moto44's Avatar
Trader Rating: 9 (91%+)
Default T5M
Today was the first day driving my T5M truck I put the three gear trans and I am running Tekin Gen 3 Motor 9.5 with a tekin RS Pro. The gearing I was running is 84 spur 21 pinion. The car felt flat and it was running hot. I did not have my temp gun but I could tell by the touch. Being that I am running a three gear trans should my gearing be totally different. Any help would be appreciated. Thanks
Barnstormers Raceway
Critters
________________________
moto44 is offline   Reply With Quote
Old 01-17-2016, 06:34 PM   #2692
sanderson373's Avatar
Sounds like you are under geared.....I had a 8.5t and I was running a 24t pinion try going up to like 25t and up
Rc8b3e
B4.2, B5M,B44.3, t5m, SC5M, B5M Lite
Extreme Hobby Shop in Spring Hill,TN
Slash 4x4, tekno 410, slash 2wd, blue eagle, radicator
85' goldpan, rc10 worlds car, losi xx4
sanderson373 is offline   Reply With Quote
Old 01-19-2016, 04:36 PM   #2693
moto44's Avatar
Schelle Racing told me to run 81T -22T pinion. I'll give that a try.
Critters
Old 01-21-2016, 10:34 AM   #2694
Hi all - I'm building a T5m and will be using the Associated Aluminum Rear Hubs. I've found Associated's installation instructions for these online, but only as they pertain to a B5 (xxx.teamassociated.com/pdf/cars_and_trucks/shared/91548.91549-Alum-Rear-Hubs-for-B5-B5M.pdf[/url]). I have to imagine that the geometry is different between the B5 and the T5. Any recommendations from the group as to (i) which hole to use to mount the ballstuds, and (ii) how many mm in spacers to use under the ballstuds?
Thanks - I've read through this ENTIRE thread and found it super helpful!
Rossifumi is offline   Reply With Quote
Old 01-21-2016, 11:01 AM   #2695
sduffy77's Avatar
Trader Rating: 18 (100%+)
I went off of the Cav setup as a baseline when I built mine.
https://www.teamassociated.com/pdf/c...lieri_ROAR.pdf
You are my hero LOL I haven't been able to do that yet
Team Associated SC5M | Team Associated T5M | Team Associated RC8b2e
Bumps & Jumps | Pit Stop Hobbies | Backhills RC
Pro-Line Racing | Maclan Racing | Xpert RC USA | Boca Bearings | Gens Ace | Mattox Designs | Race Ready Products | Sticky Kicks
sduffy77 is offline   Reply With Quote
Old 01-22-2016, 10:17 AM   #2696
Thanks!
Read through the thread off and on over a month - was time well spent
Old 01-24-2016, 10:56 AM   #2697
Tim W.'s Avatar
Just ordered a T5M kit. Does the current kits have the updated top shaft that will go in the 3 gear trans or do I gotta order that too? Thanks
Mugen Seiki, AKA, Werks Racing USA, Flashpoint, Upgrade
Tim W. is offline   Reply With Quote
Old 01-24-2016, 11:00 AM   #2698
LOW ET's Avatar
Trader Rating: 96 (100%+)
already in there
LOW ET is offline   Reply With Quote
Old 01-24-2016, 12:24 PM   #2699
Tim W.'s Avatar
Originally Posted by LOW ET View Post
already in there
Thanks! Can't wait to get the kit!
Old 01-24-2016, 02:41 PM   #2700
thecman26's Avatar
Trader Rating: 99 (100%+)
Yup, came with it from the get-go. No worries here! Not sold on the 3 gear in the truck personally. I feel the 4 gear is better on a dirt track. Carpet maybe?
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
