Like Tree26Likes
Old 12-26-2015, 06:13 PM   #2611
Trader Rating: 115 (98%+)
anyone run 3x1.4 all around high grip indoors
ashxxx is offline   Reply With Quote
Old 12-26-2015, 07:09 PM   #2612
The local track has a off road carpet set up now and I am going to buy a t5m. My question is they allow 8.5 to 13.5 motor and what ever esc. The trach is a tight track longest straight away is 40' I have no clue what I should be running on this thing. I have a old flip flow esc and a old Novak 10.5 motor is this worth messing with. I really want this thing to be as light as possible.
Coryjones26 is offline   Reply With Quote
Old 12-26-2015, 09:21 PM   #2613
mblgjr's Avatar
Trader Rating: 86 (100%+)
I really don't see this working all that well for the truck.
I have tried them in the rear in med/lo grip conditions to find a little more traction.
3x1.4's have a touch less pack than 2x1.6 but the 1.4's react very quickly to small cst/fluid changes.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 12-27-2015, 10:06 AM   #2614
Is anyone else having issues with the ball studs in the rear hubs breaking? I have the aluminum hubs and I've broke 3 of them already. Have to replace the hubs now.
450rdawg is offline   Reply With Quote
Old 12-27-2015, 10:10 AM   #2615
sanderson373's Avatar
i broke 1 or 2 of them in my rear hubs i dont know why its happening but i can only see if you over tighten it and the pressure from the corners and people hacking
Rc8b3e
B4.2, B5M,B44.3, t5m, SC5M, B5M Lite
Extreme Hobby Shop in Spring Hill,TN
Slash 4x4, tekno 410, slash 2wd, blue eagle, radicator
85' goldpan, rc10 worlds car, losi xx4
sanderson373 is offline   Reply With Quote
Old 12-27-2015, 10:14 AM   #2616
thecman26's Avatar
Trader Rating: 99 (100%+)
Not here but I'm running old-school stock plastic hubs here.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 12-27-2015, 10:16 AM   #2617
mblgjr's Avatar
Yes Ive seen and had the threads pull out. I had to JB Weld my studs in place. With AE
The Schelle alloy is better, threads are tighter. Plus if something does happen you can replace the stud mount.
Old 12-27-2015, 10:39 AM   #2618
yes the ae hubs on the truck dont last theres is just too much weight when landing on 1 tire or when people nail u.
Old 12-27-2015, 10:42 AM   #2619
whats better in the rear on med bite 2x1.7 0r 3x1.4 for the rear shocks? curious what the diffence between the two would be
DIRT DIGGER is offline   Reply With Quote
Old 12-27-2015, 01:39 PM   #2620
Trader Rating: 42 (100%+)
I have seen 3 break on the the same night. All 3 of them DID NOT use loctite. If they come unscrewed just a little, you loose the support of the spacers and now have more leverage on the threads. Speaking of spacers, 1 plastic one max on the stackup and put it closest to the stud flange. I prefer all alum spacers for strength and always use blue loctite when going into alum.
Bartman42 is offline   Reply With Quote
Old 12-27-2015, 03:31 PM   #2621
I've tried them both with and without loctite and have broken them both ways. Guess I'll try the Schelle hubs. Getting frustrated with this truck. Thinking of going to the 22t. I hate to because I'll lose so much in it but I just can't get it as dialed as my buddies Losi that's basically box stock. Just can't explain it.
Old 12-27-2015, 03:47 PM   #2622
buckeye dan's Avatar
+1 locktite
Buckeye Dan
buckeye dan is offline   Reply With Quote
Old 12-27-2015, 04:27 PM   #2623
Jpdanger's Avatar
I broken several ball studs in the alum rear hubs and even the rear camber mount, but I haven't broken a single stud when using the kit plastic rear hubs.
Don't give up hope just because you can't use alum rear hubs. The T5M is an outstanding truck!
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 12-27-2015, 06:40 PM   #2624
This is a general question but are there any other shock changes that should be done when using the new truck springs? Had 35wt f&r 1.6f 1.7r blue springs f grey springs rear, went to green front white rear truck springs. Felt like it was more tippy in high speed corners.
jswo is offline   Reply With Quote
Old 12-27-2015, 06:49 PM   #2625
Big Features's Avatar
Try using ball stud with bulkhead shim instead of ball stud shims, I've never broken a ball stud.
Big Features is offline   Reply With Quote
