Like Tree24Likes
Old 12-20-2015, 08:02 AM   #2596
Is there a big difference between the 3 and 4 gear? What are the advantages and disadvantages between the two? Thanks lots for info all
DIRT DIGGER is offline   Reply With Quote
Old 12-20-2015, 08:55 AM   #2597
urluzn's Avatar
Trader Rating: 28 (100%+)
The difference is traction. Depending on the amount of grip on the surface your on. 3 gear will loosen the rear grip and 4 gear will give you more.
Team Associated~ Reedy~ Proline~ EZcustoms~ FDJ
urluzn is offline   Reply With Quote
Old 12-20-2015, 09:02 AM   #2598
duckhead's Avatar
Originally Posted by thecman26 View Post
Stadium truck guy, truggies are 4wd...
I would say Ions, Dirtwebs, Pressure Points, or Chain Links. Pretty much any small tread height tire. In either clay or super soft/Ultra soft compound.
Thanks for the correction, always assumed Truggy was generic for all stadium trucks. Can you tell I have touched nothing besides a buggy until now?
Thanks for the tire tips, so pretty much the same deal then as with a buggy from a tread perspective, got it.
duckhead is offline   Reply With Quote
Old 12-20-2015, 09:45 AM   #2599
Lexicus's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Jpdanger View Post
You'll get more initial turn in due to more weight transferring forward on braking. Too much weight transfer forward and the rear end can break loose. Without getting overly technical, changing the springs on the front of the vehicle will affect off-power steering. Changing springs at the rear will affect on-power steering. You can also experience nose down jumping if the front end is compressing too much.
Here's a great cheat sheet to troubleshooting your set-up. I'd suggest printing the PDF at the bottom of the page and keeping it in your toolbox.
That's a good post thanks for the info. I didn't know o-rings only last a month. How often are you guys changing them out?
Lexicus is offline   Reply With Quote
Old 12-20-2015, 12:41 PM   #2600
ben42's Avatar
Aright guys I am in need of some help. I am brand new to racing and picked up a used t5m for pretty cheap. I have installed all my electronics and am now trying to match a set up I found online. The truck is bone stock with a 4 gear tranny. Working on getting the 3 gear. My question is, with the standard rear hubs, I am getting a lot of rub between camberlink ballstud and the wheel. Anyone else have this problem? Should I shave it down?
Heres a pic of what I am talking about:
ben42 is offline   Reply With Quote
Old 12-20-2015, 01:05 PM   #2601
aeRayls's Avatar
Looks like the wrong rear hex bringing the wheel in too close.
aeRayls is offline   Reply With Quote
Old 12-20-2015, 01:11 PM   #2602
ben42's Avatar
Okay that would make sense but I think this is the correct hex?
EDIT** Just measured and it does seem to be the 8.5mm
Old 12-20-2015, 01:30 PM   #2603
aeRayls's Avatar
That's a better pic! Those are the correct hexes but your hub carriers are on the wrong side.
Old 12-20-2015, 01:32 PM   #2604
ben42's Avatar
.......palm to face. Thank you ahha
Old 12-20-2015, 08:20 PM   #2605
Wheel Nut's Avatar
Don`t worry Ben we are all guilty of making mistakes
Wheel Nut is offline   Reply With Quote
Old 12-20-2015, 09:32 PM   #2606
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by duckhead View Post
Hey guys, just finished my T5M build, and I am looking for some tires recommendations. I am a buggy guy so this whole truggy thing is new to me.
The track that I am looking to run on is indoor clay, smooth, relatively high bite and sometimes wet.
Thanks!
Electrons, dirt webs or chain links. Personal preference from there.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 12-22-2015, 06:26 AM   #2607
Is anybody using T5M on Carpet Track ??!
Any setup help will be appreciated.
Thanks a lot.
Team Xray T4 '16
Team Xray X1 16
Team Xray XB2
Team Xray XB4 16
Team Associated T5M
ringa is offline   Reply With Quote
Old 12-22-2015, 01:23 PM   #2608
frankf's Avatar
Thanks a lot.
Stock setup plus the following, lower ride height, thicker shock fluid and maybe stiffer springs but not necessary, gear diff with 3 gear trans, tune camber links to suit.
frankf is offline   Reply With Quote
Old 12-22-2015, 07:26 PM   #2609
anyone know what a good shock length for the front would be using 1 shock limiter? Can u run it with no limiters in the shocks?
Old 12-22-2015, 11:49 PM   #2610
DJ919's Avatar
Thanks a lot.
Basically the stock set up. I'm running 35 front 30 rear shock oil. Ball diff ( Diff preference will come down to your driving style and preference.) The biggest thing in my opinion is tires. Schumacher staggered ribs or Vee 2s (front) / Micro Spikes in the rear. Worn Vee 2s work in the rear as well. Any minor up grades like harden A-arms, weight shaving upgrades are totally up to you. The truck handles great in stock build form on carpet.
I use to be fast >>> A very long time ago.
www.facebook.com/DJ919
DJ919 is offline   Reply With Quote
