Like Tree24Likes
Old 11-28-2015, 09:19 PM   #2536
i notice most of the setups are using 3 shock limters front and 1 in back. what would change if i went to that setup from 2 limiters front and rear? thanks
DIRT DIGGER is offline   Reply With Quote
Old 11-28-2015, 10:40 PM   #2537
Tandum4056's Avatar
Trader Rating: 106 (100%+)
What ride height is suggested with the new T5M springs? I was running 24mm all around with the old kit springs. I installed the new white springs all around and with the shock collars fully backed out the lowest it will sit at is 28mm.
Tandum4056 is offline   Reply With Quote
Old 11-28-2015, 11:17 PM   #2538
Cridd's Avatar
Trader Rating: 16 (100%+)
Put on the different shock cups that hold the springs and will fix that.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 11-29-2015, 03:46 AM   #2539
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
Do you run on carpet? 24mm is awful low for a stadium truck
pink_sleeve is offline   Reply With Quote
Old 11-29-2015, 07:32 AM   #2540
hello all i need a part number im trying to get some 1mm plastic spacers for the caster block spacing can anyone help me please? thanks
Old 11-29-2015, 07:37 AM   #2541
Jmuck69's Avatar
It comes with plastic spacers, 2mm for the caster block. Refer to instruction manual.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 11-29-2015, 07:39 AM   #2542
Jmuck69's Avatar
Try changing the spring cups. Kit is 9mm cups but with the longer truck springs you need to switch to the 5mm, same as the buggy.
B6D | B64D
Old 11-29-2015, 07:55 AM   #2543
i know it comes with 2mm. im putting a different setup on and it calls for 1mm spacers front and back of block.
Old 11-29-2015, 09:08 AM   #2544
Jmuck69's Avatar
Try these.
http://www.schelleracing.com/Schelle...H1211?limit=50
B6D | B64D
Old 11-29-2015, 01:06 PM   #2545
Do you really need to buy a new top shaft to convert to a 3 gear? The part numbers are the same. Am I missing something?
dayjef is offline   Reply With Quote
Old 11-29-2015, 01:13 PM   #2546
LOW ET's Avatar
Trader Rating: 95 (100%+)
nope
LOW ET is offline   Reply With Quote
Old 11-29-2015, 01:34 PM   #2547
thecman26's Avatar
Trader Rating: 98 (100%+)
Yeah, 31mm front and 30mm rear here.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 11-30-2015, 04:59 PM   #2548
Please forgive me if I've missed this somewhere in the thread. When I scale my truck, it's 61.8% in the rear. I've been working with a very experienced 2wd driver and he said that the sweet spot is 64-65 rear. I've moved stuff around and the best I can get at the moment is 62.4 rear. I run on an outdoor track with medium traction. The track is a little bumpy and has some decent sized jumps. I just can't get the rear of the truck planted as well as I'd like. That being said, I also have a push in higher speed, sweeping turns. I have the 3 gear tranny and a viper 7.5 motor. Maybe it's more my throttle control but I feel that the truck could be so much better than what it is. The total weight of the truck is 1947 grams. Any suggestions would be appreciated.
450rdawg is offline   Reply With Quote
Old 11-30-2015, 09:31 PM   #2549
Trader Rating: 478 (100%+)
try the 4 gear tranny.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 12-01-2015, 12:34 AM   #2550
Cridd's Avatar
+1 and heavier D and C mount possibly.
Chris
B6D / T5M / SC5M
