Like Tree24Likes
Old 11-22-2015, 07:44 PM   #2506
sanderson373's Avatar
Originally Posted by gawith0413 View Post
Is there an option to run a closed ball cup, compared to the stock open ball cups?
the capture ball studs are bigger than the ball cups. but in imo the capture ball is the way to go i convert all my buggies even vintage buggies to capture ball
Rc8b3e
B4.2, B5M,B44.3, t5m, SC5M, B5M Lite
Extreme Hobby Shop in Spring Hill,TN
Slash 4x4, tekno 410, slash 2wd, blue eagle, radicator
85' goldpan, rc10 worlds car, losi xx4
sanderson373 is offline   Reply With Quote
Old 11-22-2015, 07:51 PM   #2507
gawith0413's Avatar
Trader Rating: 78 (100%+)
It's just with the stock ones, they make the suspension really stiff. I'm converting this truck into a SCMod for dirt oval, so setup is everything.
gawith0413 is offline   Reply With Quote
Old 11-22-2015, 08:05 PM   #2508
mblgjr's Avatar
Trader Rating: 86 (100%+)
Originally Posted by dayjef View Post
Is there a real difference in steering if you take the spacers off of the ball studs at the bell crank?
Yes, it changes the ackerman significantly & thus, the steering feel.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 11-22-2015, 08:50 PM   #2509
Trader Rating: 137 (100%+)
So heres the deal. Had one T5m that worked great, decided I wanted to give the SC5M a shot, s I sold the T5M, which I immediately replaced cause I missed my truck. Here is the problem, same exact setup, same exact tires, same exact everything that was on the old truck, and this new one drives like crap. Wont track straight during breaking, hooks around turns, is not smooth anywhere on the track. Ballcups are reasonably free (better then the old truck), I am at a total loss, the SC5M which has basically the exact same setup, (expect for grey front springs (and front/rear pistons) in so in the pocket, I threw a 6.5 in it, and it handled it like a champ. The T5M is a squirrel monster with a 13.5. I'm baffled. My build skills are good, diff is fine, bearings have been replaced with ceramics and is free as can be. At a total loss.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 11-23-2015, 04:08 PM   #2510
TravisS27's Avatar
Trader Rating: 25 (100%+)
Getting ready to install the alum 25* bulkhead and do the "Cavalieri mod" to the front bumper and "delete" the front hinge pin.....
AKA Tires
BOOMrc Graphics
Exotek Racing
RickyRacer Lidz
Jake's RC Topeka KS
TravisS27 is offline   Reply With Quote
Old 11-23-2015, 04:36 PM   #2511
Trader Rating: 36 (100%+)
Default Xrings
Originally Posted by bprc10T3 View Post
Can't speak on the fox shocks but the x rings are a must IMO
Is there a noticeable difference in leakage, I hate the stock associated orings
mxturd is offline   Reply With Quote
Old 11-23-2015, 06:07 PM   #2512
frankf's Avatar
Please explain what holds the arms on without hinge pins?
frankf is offline   Reply With Quote
Old 11-23-2015, 06:10 PM   #2513
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
grub screws
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-23-2015, 06:11 PM   #2514
TravisS27's Avatar
LOL I meant hinge pin brace!! The 4 pinch bolts in the bulkhead hold the pins in place. I trimmed them flush with the front of the a arms. I didn't do near as good of a job bending my plastic bumper up though. I'll get a new bumper and use a heat gun this weekend, then I'll post pics
AKA Tires
BOOMrc Graphics
Exotek Racing
RickyRacer Lidz
Jake's RC Topeka KS
Old 11-23-2015, 06:16 PM   #2515
I just recently added a t5m to my race aresenal and have a question on tires and inserts. Do the inserts on these stadium truck tires typically wear out before the tires do? I'm running on clay with Chainlinks in the clay compound with dirt tech inserts.
FWIW I wear out the tires on my buggy before the inserts every time.
afm223 is offline   Reply With Quote
Old 11-23-2015, 06:41 PM   #2516
is there any disadvantages to cutting the cradle?
DIRT DIGGER is offline   Reply With Quote
Old 11-23-2015, 06:53 PM   #2517
1/4milecrazy's Avatar
I like the dirt tech inserts after them being broken in. After wearing a set of tires I save the foams and put them in my new tires. Granted that is with my buggy. I have a set of Primes on my T5M and they are getting towards the end of their life and I cant wait to get the foams out and mount them up in some new Primes.
1/4milecrazy is offline   Reply With Quote
Old 11-24-2015, 08:06 AM   #2518
Trader Rating: 478 (100%+)
I thought about this and off the top of my head there are 2 things that I could think of. I know you said "same tires" but try to swap them or try another set....and check the diff. If its all the same I cant see anything else that would cause it to feel funky.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 11-25-2015, 01:19 AM   #2519
frankf's Avatar
So I purchased the ae clamping rear hex's, what false advertising that description is, I used pliers and squeezed them together and then did the screw up until there was no gap, with the hex not even mounted to the car, and it just slips on and off, how can ae sell us this junk that clearly doesn't do the job it's meant to, what's the solution do I need to stick with the plastic ones?
Old 11-25-2015, 05:12 AM   #2520
TruggyDude91's Avatar
Ease your storm there guy. I installed the clamping hexes on my T5M and they are great. I did not have any problems with the screws breaking or anything sliding off. Because the screw is tiny on these hexes, you need to tighten them down slowly and gently. When they feel tight, they are tight, no need to bear down on them because that is when guys break the screws and write on here that they are crap. In your case, squeezing them together defeats the purpose of the clamping hex. You have already squeezed them down so there is no clamping force to hold the hex onto the axle. How can the hex clamp to the axle surface if you already smooshed it down? By clamping them down with pliers, you most likely deformed the inside mating surface of the hex. Aluminum is soft and does not take much to deform it. I would bet the hole that the axle slides through is oblonged and hence why it is not clamping. I call user error in this case like most cases I have heard with people having problems with the aluminum clamping hexes.
TLR - O.S. Engine's - Bone's Brew - JConcepts - Airtronics - Protek R/C - Diggity Paints
8IGHT 4.0 - B2101 W/2090, Protek 170s, RX472
8IGHT-T 4.0 - XZB VER. III W/2090, Protek 170s, RX472
TruggyDude91 is offline   Reply With Quote
