Like Tree30Likes
Old 11-12-2015, 09:31 AM   #2461
Anyone run the slipper eliminator on their truck if so how did it work out I run my slipper pretty much locked out, I run at SRS high bite clay track.
thanks
jslider is offline   Reply With Quote
Old 11-12-2015, 06:45 PM   #2462
hello all curious if anyone is adding weight and how much to the truck running on med/low bite tracks and where u are putting the weight? thanks
DIRT DIGGER is offline   Reply With Quote
Old 11-12-2015, 08:27 PM   #2463
TravisS27's Avatar
Trader Rating: 25 (100%+)
Originally Posted by QDRHRSE View Post
Ever consider swapping the 8.5 for a 13.5 or 17.5? I bet that's worth a second a lap. I'm fairly experienced and I don't feel like I could adequately make use of that much motor. Just a thought. Personally, 13.5 is like mod to me but then again, I'm the king of stock. I even run a 13.5 in my 4x4 buggy.
I run a Novak Vulcan 13.5 at about 35 can timing in my truck and it's very competitive and always in the top half of the A main.
TravisS27 is offline   Reply With Quote
Old 11-12-2015, 08:30 PM   #2464
LiL CeeZ's Avatar
Trader Rating: 15 (100%+)
thanks
I run the exotek and it works great also running on high bite clay
Team Associated B6D
LiL CeeZ is offline   Reply With Quote
Old 11-12-2015, 10:37 PM   #2465
Jpdanger's Avatar
I use the x factory infinity chassis which is similar to the exotek chassis. It's brought the weight down quite a bit, but I've found myself adding weight back to the truck in the rear. I felt there wasn't enough weight in the rear with the pucks and a shorty all the way back. I took the pucks out and that helped a lot. I've since pit the pucks back in and added the brass c block, but I haven't had it on the track yet.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 11-13-2015, 09:53 AM   #2466
lbckevin's Avatar
Trader Rating: 91 (99%+)
Most don't add any weight. The truck is very heavy stock. Most take weight out and adjust the setup to compensate.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is online now   Reply With Quote
Old 11-13-2015, 07:10 PM   #2467
most at my track have been trying to add weight to get more bite
Old 11-13-2015, 07:18 PM   #2468
Trader Rating: 44 (100%+)
Adjusting your esc/radio to smooth out the throttle is also a good idea, A friend of mine has an 8.5 in his T5M and it's buttery smooth. I don't know what his setup is, I normally run a more aggressive setup.
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 11-14-2015, 08:58 AM   #2469
+1. I was struggling with rear bite last night and made a small adjustment to the throttle speed on my radio and lowered the punch in my esc from 7 down to 5 and instantly dropped my lap times by more than a second. Adding weight is my last resort, and I have yet to get to that point.
afm223 is offline   Reply With Quote
Old 11-14-2015, 12:44 PM   #2470
Im the same way, i like to try a car out without weight first to see if/how it helps. I think weight should only be used as a tuning aid and not just thrown on without having the car be pretty good already. I'm not certain but I believe you can add to much rear weight and that would make the car sketchy as well
T5M 7.5
22 3.0 7.5
Old 11-14-2015, 08:06 PM   #2471
whats a good ride height for running on a med bite track? also curious if anyone has ran the truck with 0 anti squat?
Old 11-15-2015, 08:35 PM   #2472
steelers82's Avatar
if I wanted to switch to aluminum front clamping hex's what width do I need? same as sc10 12mm,or same as a B5?
John 3:16 " For God so loved the world that he gave his one and only son,that whoever believes in him shall not perish but have eternal life"
steelers82 is offline   Reply With Quote
Old 11-15-2015, 09:14 PM   #2473
aeRayls's Avatar
8.5mm same as the T5/sc5 rear
aeRayls is offline   Reply With Quote
Old 11-15-2015, 09:50 PM   #2474
steelers82's Avatar
cool thank you
Old 11-16-2015, 03:52 AM   #2475
30 front, 28 rear is a good starting point.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
bobf24
