Like Tree24Likes
Old 11-03-2015, 06:48 PM   #2416
1/4milecrazy's Avatar
Originally Posted by lewis4x4 View Post
I am finishing up building the Associated 2wd Buggy and truck fleet and have a few questions. If you could help me out understand thing the following, it would greatly appreciated:
1.) The Kit setup has 2mm washer on the steering rack. By taking away the blue washer or changing out to a 1mm, what will that do to the steering feel?
2.) On the T5M, I see several people are using the +4 C Block and a different rear D Block with arrows pointed outward. Again, what would be the purpose for making this change. How does it affect the truck?
3.) What would the difference be on the buggy instead of using 25 + 5 in caster to using 30 + 0...
THANKS!!!
Do you have the owners manuals with your cars/trucks? It explains the ackerman adjustments in the back. Also should tell you about the camber settings too. It shouldn't be any different but if you want to try 25 degrees you have to take the bulkhead out instead of just the knuckle.
1/4milecrazy is offline   Reply With Quote
Old 11-06-2015, 10:18 PM   #2417
---- more ackerman. Less aggressive steering into a corner.
---- makes the rear end more stable. You also need to run the HD rear axles with the +4 mount.
---- overall caster would be the same for both setups. But more kickup would make it turn into the corner a little harder.
THANKS!!!
See notes added below your questions
KW Raceway https://m.facebook.com/kwraceway
Mugen Seiki/Yokomo Usa/Protek/Amain/R1 Wurks/Flashpoint/KW Raceway
robbie_gtc is offline   Reply With Quote
Old 11-07-2015, 09:46 AM   #2418
who has a good setup for low bite indoor??
DIRT DIGGER is offline   Reply With Quote
Old 11-07-2015, 08:07 PM   #2419
I haven't read through all of this thread but was wondering if anyone has experimented with the gear diff on high bite clay. If so, what weight diff are have you tried and what turn motor? Thanks
If your not first your last! Shake N bake!
FPMX772 is offline   Reply With Quote
Old 11-07-2015, 10:11 PM   #2420
can anyone help me out? im running the c and d brass rear hinge pin holders with 35f 27.5 r shock oil 1.6 f 1.7r pistions and i cant get the rear locked in around corners. when i come into corner the rear steps out bad. any ideas please??
Old 11-07-2015, 11:15 PM   #2421
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
Rear oil could be to light for running both brass pieces. Also running both brass pieces creates a greater pendulum effect making the rear want to swing more on entry
pink_sleeve is offline   Reply With Quote
Old 11-08-2015, 07:53 AM   #2422
So whats the best opinion to do take off the rear D brass mount?
Old 11-08-2015, 08:12 AM   #2423
Trader Rating: 478 (100%+)
wow....its early, wrong forum.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 11-08-2015, 08:23 AM   #2424
go back to the book set up and take the shock oil and springs down 2 steps. you may want to try that w/o the brass D mount. if traction is low you have to run a ball diff.
My T5M is dialed on our low traction winter layout and all I did is what I told you to do above. I'll have to check but I'm pretty sure that I ended up with white/green and 27.5/25. I'm sure about the oil.....but not the springs.
Old 11-08-2015, 02:33 PM   #2425
TravisS27's Avatar
Trader Rating: 25 (100%+)
I bought my T5M used and it has yellow springs front and white rear with 35wt front and 30wt rear. It drives pretty good but I think I'm going to soften the oil frt & rr. Both tracks I race on are pretty smooth with med sized jumps. What are you guys running spring and oil wise on similar tracks?
TravisS27 is offline   Reply With Quote
Old 11-08-2015, 03:00 PM   #2426
Over the summer with awesome traction I ran Kyosho Gold fr/rr.
Old 11-08-2015, 06:47 PM   #2427
thecman26's Avatar
Trader Rating: 98 (100%+)
Fwiw the new AE truck springs are phenomenal! I like em even more than the Kyosho springs! White rear and gray fronts for me. DIALED!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 11-08-2015, 07:13 PM   #2428
just curious what would make them different than the buggy springs?
Old 11-08-2015, 07:23 PM   #2429
thecman26's Avatar
For one, their longer, secondly they have a lower turn count with larger space between coils, kinda like the Kyosho springs. Since they are made for a truck with longer shocks they work way better, since you don't have to turn down the shock collar halfway down to achieve ride height. Marvel concept I know, since back in the T4/B4 and older series there was truck rear springs and buggy rears aka truck fronts. Thankfully it's coming back for AE with the new springs!
Old 11-08-2015, 07:51 PM   #2430
Nice!!
