Like Tree30Likes
Old 10-04-2015, 05:43 AM   #2236
anyone know the part numbers for a 3 gear transmission? can u just give me all the numbers i would need to complete this. thanks
DIRT DIGGER is offline   Reply With Quote
Old 10-04-2015, 06:01 AM   #2237
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
The process is pretty simple. Take the tranny out, swap the parts and put it back in. Just make sure the adjusting nut on the diff still faces the same way when you are finished.
3 Gear motor plate- Blue part #91603, Black #91602
3 gear tranny gearbox- part #91607
3 gear gear cover- part #91604
Have fun!
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 10-04-2015, 06:13 AM   #2238
Braxamus's Avatar
If you have the 4 gear tranny that came with the T5M these are all you need to switch to 3-gear as far as I know because you should already have the top shaft.
#91603
#91604
#91607
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 10-04-2015, 06:24 AM   #2239
#91603
#91604
#91607
ok cool thanks alot i didnt know if the gears that came with the 4 gear were the same as the 3 gear
Old 10-04-2015, 07:05 AM   #2240
Regional Moderator
Yes, it's the same gears. It just uses one less idler. Glad to help.
Jon Carlson
Old 10-04-2015, 07:19 AM   #2241
ok great thank you soo much jon! Glad to have such a helpful website and helpful people!
Old 10-04-2015, 08:50 AM   #2242
Other than getting used to driving a 2 wheel drive again I do think I am going to look into another slipper as they put the old ones on the new trucks.
I know a lot of people switch to Avid or Schelle slippers, but I have been happy with stock AE slippers except for the T5m. It really should have come with the larger pads or the VTS slipper like the B5m and SC5m. So my 3 cars are the same, I bought the VTS conversion (part 91175) for the T5m. I do run the slipper pretty tight as I run on carpet.
islandscott is offline   Reply With Quote
Old 10-04-2015, 09:05 AM   #2243
LOW ET's Avatar
Trader Rating: 96 (100%+)
when running the avid slipper, which pads are everyone running and in which class? like stock truck is all white pads and mod truck is all red pads, do you mix and match pads, whats the majority running, etc...?
LOW ET is offline   Reply With Quote
Old 10-04-2015, 01:21 PM   #2244
1/4milecrazy's Avatar
This weekend was my first time racing a stadium truck, and I really liked it. one thing I was wondering if anyone has a printable tuning guide like TLR has for the Tenscte 2.0
http://www.tlracing.com/ProdInfo/Fil...uning_Tips.pdf that thing is sweet, does Associated have anything like that for their trucks? or does anyone know where to get a good reliable guide like that for these. Other than getting used to driving a 2 wheel drive again I do think I am going to look into another slipper as they put the old ones on the new trucks.
Check out the RC cheat sheets app from Associated. Its really easy to use and helps out a lot. Definitely worth the couple bucks. You can also look at the back of the owners manual. It also gives tuning tips and explains what changes do what.
Apparently "equal" and "partners" means different things to different people.
1/4milecrazy is online now   Reply With Quote
Old 10-04-2015, 03:39 PM   #2245
carcrazy699's Avatar
So I am looking to buy a T5M to go along with my B5MFL buggy. How does this truck handle? I have a T4 that I used to play around with but I want to get into racing with something better for the ST class. I was thinking just the kit with of course wheels and tires and do the 3 gear transmission for it. I run on outdoor low to medium bite track. I am pretty decent from what I am told and make a mistake here and there but the majority of the time I keep my buggy planted and flying around the track.
For right now I would be running a 10.5 LRP motor until I can get something better along with a better ESC.
Losi Ten-T
Losi M8T
Lost M8DB
carcrazy699 is offline   Reply With Quote
Old 10-05-2015, 06:28 AM   #2246
Braxamus's Avatar
Was looking at some pics of Ryan C. 2015 T5M and seen one that showed the battery in it top view what size battery is that? I can see its a Orion 4500 I mean outside dimension wise, is that a shorty pack. I got the square packs for mine and it fills up the battery area side to side and I can only move it front to rear the thickness of the small piece of foam it came with. Was just wondering as it seems a shorty pack if that's what it is would give you more adjustment as far as weight placement front to rear. Here is link from the pics I am talking about you got to scroll down to the T5M
https://www.teamassociated.com/pdf/c...ts_Desktop.pdf
Also I noticed looking at the springs they are a lot longer than the ones that came in the kit what are they?
Team Raw Speed
Old 10-05-2015, 06:50 AM   #2247
Suspended
Trader Rating: 61 (100%+)
Have fun!
What happens if the nut ends up on the opposite side?
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 10-05-2015, 07:59 AM   #2248
Braxamus's Avatar
if you look at the B5M lite tranny build instructions it will give you the proper orientation for every thing
Team Raw Speed
Old 10-05-2015, 08:15 AM   #2249
Then you take it out and flip it back around lol
BrandonBreh is offline   Reply With Quote
Old 10-05-2015, 09:12 AM   #2250
Suspended
I want to hear what happens when you run it "backwards".
Why would you flip it? Why not...just leave it?
