Like Tree33Likes
Old 09-26-2015, 06:43 AM   #2206
CCristo's Avatar
Trader Rating: 55 (100%+)
Originally Posted by Dough Boy View Post
I am completely stumped the only way I can get the T nut deep enough into the out drive I have had to remove the thrust spring and with the bolt ran down tight my diff now feels useless its really loose without the thrust spring.
Any and all help is appreciated I have spent 4 hours trying to remedy this on my bench I can't so I came here to ask should i use a gear diff with the MIp 3 gear?
Sounds like you have the t nut in the wrong outdrive. It should go in outdrive that has the bearing support for the diff gear.
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 09-26-2015, 07:47 AM   #2207
Braxamus's Avatar
I just built my new kit a few weeks ago and had no trouble at all was one of the smoothest builds I have ever done. I don't have the alum. trans case but still it should be built to closer tolerances that than the injected molded plastic ones.
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 09-26-2015, 08:55 AM   #2208
I will check it again today I have only had time to build it this week really late at night midnight or later so today with fresh eyes I will take the 3 gear back apart and see where I might be going wrong. I have a Kyosho RT6 the diff went together no problem, my Rc10T4 same thing and my B4 all went together without a hitch.
Dough Boy is offline   Reply With Quote
Old 09-26-2015, 01:57 PM   #2209
LOW ET's Avatar
Trader Rating: 97 (100%+)
im looking at one of cav's setups and it says the battery is taped in and from the pictures i see, he is not using the battery strap. has anyone else played with this setup, and what were the results of the chassis flex?
LOW ET is offline   Reply With Quote
Old 09-26-2015, 09:16 PM   #2210
slakr's Avatar
Trader Rating: 28 (100%+)
What is needed to put clamping hexes front & rear? (*maintaining stock width)
Clamping Front Axle Set 71013
7mm Clamping Wheel Hex Set 91610
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 09-26-2015, 11:46 PM   #2211
aeRayls's Avatar
You need the front axles and the 8.5mm hexes front and rear.
aeRayls is offline   Reply With Quote
Old 09-27-2015, 02:34 AM   #2212
I thought the 7mm hexes were for the T5m and the 8.5mm hexes for the SC5m. Placing an order tomorrow for both, but maybe I have the sizing wrong. It's just not labeled clearly in any AE documentation that I can find.
islandscott is offline   Reply With Quote
Old 09-27-2015, 09:26 AM   #2213
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
7mm is for the rear of the buggy.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 09-27-2015, 09:51 AM   #2214
Trader Rating: 488 (100%+)
I run one of my B5Ms with the battery taped in and I'm not sure that it really makes a huge difference. You could run the strap loose and it would allow for some of the same flex. You would be better served to cut the cradle into 2 pieces. You can also trim the rear support piece off the front chassis plate (the piece that crosses behind the servo). I don't rail my cars hard enough to get them to flex like Cav's rigs do.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 09-27-2015, 09:54 AM   #2215
Thanks for the confirmation.
Old 09-28-2015, 03:29 PM   #2216
Cridd's Avatar
Trader Rating: 16 (100%+)
I did that one time, thrust bolt in the wrong side, flip flop and it was all good.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 09-28-2015, 03:50 PM   #2217
Cridd's Avatar
My T5 feels a litte rolly polly, lazy, I guess that would be soft. What is the best way to make it feel better, thicker shock oil or springs?
Chris
B6D / T5M / SC5M
Old 09-28-2015, 06:18 PM   #2218
tony montana's Avatar
Trader Rating: 65 (100%+)
Finally got mine on the track and the truck felt great. Only issue I see is when turning left I see some wheel chatter. Any one else experience this?
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 10-01-2015, 06:54 PM   #2219
buckeye dan's Avatar
was so excited building T5M then get to tranny it is missing slipper and spur gears . Anyone else missing parts?
Sent email hope it doesn't take to long to get response...
Buckeye Dan
buckeye dan is offline   Reply With Quote
Old 10-01-2015, 08:21 PM   #2220
I had multiple wrong parts in my kit.
