Like Tree33Likes
Old 08-26-2015, 09:11 PM   #2101
Trader Rating: 488 (100%+)
Originally Posted by JEFFs SC10 View Post
I ran a big race and just didn't have the speed to keep up.
t5m with 3 gear, trinity d4 , 34/72.
talked to one of the faster guys, they run a 29/30 with 78 spur?
any other ideas? slipper elim? is it worth doing mip axles?
That's taller than the gearing I run in my buggy (30/69). With a D4 17.5 short stack I run 24-25/75 using a slipper eliminator with 50 (or more) degrees of timing. My T5M is very fast. If you're running a regular D4 for can go up a tooth or two. Your track must be long and the climate mild. My T5M would come off the track on fire @ 30/78.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 08-27-2015, 11:09 AM   #2102
Braxamus's Avatar
Got everything built, and all I have to do is paint body, glue tires and wait on electronics to get here, and a servo. I think the manual calls for a starting point of 84/20 for a 8.5 motor so think I will start there and see how it goes and watch the temps.
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 08-27-2015, 11:26 AM   #2103
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Unless you were running your timing at 0, you are WAY over-geared. I run 74/24-25 in my Fantom Trinity based motor, with a HT rotor, timing around 40-45. You are actually slightly over-geared for a buggy! let-alone the truck that is both A) much heavier, and B) has a DRASTICALLY higher roll-out due to it's giant tires.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-27-2015, 03:38 PM   #2104
Braxamus's Avatar
Looking at getting this servo:
http://www.amain.com/rc-cars/savox-s...1258tg/p183316
will it work ok with this ESC
http://www.falconsekido.com/products...combo-x-series
Team Raw Speed
Old 08-27-2015, 07:05 PM   #2105
Trader Rating: 82 (100%+)
I too have struggled to find the right gear ratio. Running a fantom ion short stack, currently running 25/78 with a slipper eliminator and 50-55 of timing. It feels like it lacks low end acceleration.
dpcardoza is offline   Reply With Quote
Old 08-27-2015, 09:06 PM   #2106
Super Moderator
short stack? over-geared.. or over-timed. Those motors, at least in offroad, i find to do a lot better with less timing than that, unless you're on a huge track. drop to a 24, and 45 timing.. see what you get.
- RCSpecialties -
Old 08-28-2015, 01:31 AM   #2107
frankf's Avatar
I started at 81/20 and it was slow, I am now at 81/25 in blinky mode.
frankf is offline   Reply With Quote
Old 08-29-2015, 03:13 PM   #2108
hogdaddy77's Avatar
Have a T5M on the way. What is a good motor/esc/gearing combo for running on grass in theback yard? Going to mow down/mark off a track.
hogdaddy77 is offline   Reply With Quote
Old 08-29-2015, 06:52 PM   #2109
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
so what do you advise?? I run a regular D4 right now with timing turned up.
I need the nuts, this truck needs more powah!
XRAY T4 17' //CRC Gen X SE- 17.5 GT//Xray X12-17' GT12//Xray X12-18' 17.5
check out the new 12th scale GT class!
https://www.facebook.com/groups/148391312353349/
JEFFs SC10 is offline   Reply With Quote
Old 08-29-2015, 06:56 PM   #2110
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
This should do the trick:
http://www.amain.com/rc-cars/trinity...ep1705/p360836
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-29-2015, 07:15 PM   #2111
Originally Posted by Matt Trimmings View Post
This may work, in some applications, with some modifications
http://www.amain.com/rc-cars/castle-creations-2028-1-5-scale-brushless-motor-800kv-cse060-0054-00/p384850
BrandonBreh is offline   Reply With Quote
Old 08-29-2015, 07:32 PM   #2112
Trader Rating: 36 (100%+)
Is anyone using clamping front hexes, I noticed on some setup sheets people are using them on the t5m and sc5m
mxturd is offline   Reply With Quote
Old 08-29-2015, 07:54 PM   #2113
Super Moderator
Yes. It really doesn't matter though. Just personal preference
Old 08-30-2015, 07:55 PM   #2114
Does anyone on here run a stadium truck on a carpet track? Looking for a good start point for what I think is mini golf carpet, where proline carpet tires are used for buggy.
jswo is offline   Reply With Quote
Old 08-30-2015, 10:01 PM   #2115
YoG
YoG's Avatar
I would start with yellow compound Schumacher tires.Make sure to get some foams like aka or proline as foams are not included.Stagger for the front and vees for the back.
http://www.amain.com/rc-cars/truck-1...0&fb=326&lg=fb
XRAY XB2ce/AE T5M/AE SC5M/HB D413/TEKNO SCT410
http://www.corvictoria.com/
YoG is offline   Reply With Quote
